Quote:
Originally Posted by flyer91 The problem is that since the LITW hoe has had O-rings replaced, then it's entire valve block replaced, then more O-rings replaced after verifying the return line is not obstructed, there is some uncertainty to exactly what/where the issue is/lies (hoe or TYM). |
Sorry to hear of your ongoing problems with the LITW hoe, FLYER. That
is supposed to be well-made Korean unit.
If I had your setup, here is what I would try. First, I would plumb the
hoe return line straight to the sump. It would require a new QD fitting.
This will greatly reduce the back-pressure you are getting by returning
the hoe's fluid thru the restrictive AUX valve. Powering the hoe thru
the AUX valve is not the best setup, in my experience. My current
main tractor uses the AUX valve for the hoe, and its restriction does
cause significant oil heating if I use the hoe for more than 15 min
or so.
The best solution would be to plumb the hoe thru a power beyond port
of your
FEL or AUX valve, with the return going straight to the sump.
