ford 951, my next victom
   / ford 951, my next victom #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Update...
have been fixing leaks and neating up wireing and replacing broken fasteners.. etc. had to drill out a broken bolt inthe front pedistal, and replace a few small parts.. belts.. etc.
found some tinwork on ebay ( machine used to be LPG, but was converted to gas.. thus old tinwork was discarded. ). Might have to fudge the tin as it came from a 900 not a 901.. alldepends on if my gas tank is from a 900 or a 901.
I need to weld up a new steering arm, and then I'm ready to chase a few more leaks.. past that.. I'll be ready to prime the chassie soon. Probably get to the steering arm tomorrow.
Unit came with a ford 711 1-arm trip loader ( basket case ). i can't wait to stat playing with that... will be my 3rd 1-arm loader..
soundguy
   / ford 951, my next victom #2
Soundguy, Nice picture looks like a fun project. I'd be afraid to run that around my property it's pretty hilly. I do like the old iron.
Frenchie.
If I lived in real hilly country.. I might not run it around too much either!
soundguy
   / ford 951, my next victom #4
Chris, a freind of mine used to have a 961 w/ps and a one arm loader that worked great . I couldn't tell that it was any less stable than our 4 cyl 4000 with a one arm on it. His had a hyd bucket and ours was a trip bucket. His was a lot easier to mount the loader on than the wide front 4000 also. Later, Nat
I have two hundred series fords with a wide front.. 850 and 660 both with ford 1-arm laoders, hyd dump.... and now this NF 951. I have a trip 1-arm laoder for it. it *looks* like it will be easier to mount the loader on this one.
soundguy
   / ford 951, my next victom #6
Soundguy said:
Update...
soundguy
Good progress. You work a lot faster than I do.
I'm anxious to hear your comments on the ride you get out of a tricycle tractor like yours. I'm looking at a tricycle Allis Chalmers WD and can't decide whether to make an offer. Don't particularly like the tricycle arrangement (possibly tippy). Prefer wide fronts.
I have a JD-B already.. narrow front ( 2 wheels ).. this ford 951 drove about the same with it's single front wheel. It's higher up.. but don't feel tippy.. even when I trailered it..
soundguy
   / ford 951, my next victom #8
I have an A-C WD-45. I take that all thru the woods, hillsides, wherever. Just keep the speed reasonable and watch for big rocks under the uphill reat tire and you'll be fine. I prefer a tricycle in the woods, I can go about anywhere an ATV can go.
   / ford 951, my next victom #9
I really like the trikes in the woods also. They are easier to manuver with steering brakes (can do a 360 in place) and the forward visibility (stumps, etc) is a lot better. I don't think they can legally be made any more for liability reasons concerning stability, although there is a fella on this site who swears they are more stable than wide front tractors. I think he is dead wrong for the following reason: If a hollowed out ground-hog home collapses under one of your rears, there is nothing to stop the trike from flipping over. If this happened on a wide front tractor, the front would drop down, but the rear would hold the tractor up. This makes trikes a particularly bad choice for work in hayfields or pastures where these furry creatures live. I still think the trikes have thier place, for cultivating and woods work, but they are definitely not for inexperienced operators. The Allis WD is a heck of a tractor, I own its little brother trike, the C, and have often ran my uncles WD. That 951 probably has some serious value due to its rarity, but I would keep it out of the pasture.
This one will likely be on light duty... It will ahve a ford 711 1-arm trip loade ron it.. but I doubt it will ever do much more than haul feed down tot he animal pens. i have a 660 and 850 ford both with 711 and 722 1-arm full hyd loaders for larger chores.. like moving hay.. etc..
soundguy
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
John Deere 772-A Grader (A52384)
John Deere 772-A...
ITEM LOCATION (A53084)
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
