Results 1 to 3 of 3
  1. #1
    Member
    Join Date
    Dec 2010
    Posts
    41
    TOO MANY, TOTAL OF 17 NOW: PRINCIPAL UNITS ARE JACOBSEN T422D & T528D & MANY JACOBSEN MORE MODELS & TORO GROUNDSMASTER 325D
    Default Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment
    Currently own a mechanical PTO driven snowblower which must be converted to hydrostatic PTO driven snowbloer to mount to a Jacobsen T422D TurfCat II tractor.
    Jacobsen does not support this series 400 tractor nor asseccories for this 400 series tractor any longer.
    So must come up with something.
    For refenence purpose to get across an idea of what is needed - Reference Jacobsen and Ransomes Jacobsen - Jacobsen Online Parts List for 51" Snowblower Mounting Adapter, link:
    ' + objMainFrame.getCopyrightMessage(objMainFrame.getC urrentOEMDesc()) + ' -- Jacobsen Turf Care: [066066 51\" Snow Blower Mounting Kit - Hydraulic]* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
    Graphic is exploded assembly drawing for combine mechanical and hudrostatic PTO drive is shown.
    Applicable parts list (PROVIDED JUST AS A REFERENCE EXAMPLE):
    1 116623 FRAME MEC 20225 1 Incl. Ref. No. 2
    2 312414 BUSHING 4
    8 362484 DR SPRKT 20225 1
    9 463021 WOODRUFF KEY 1/4 X 7/8 PLAIN 2
    10 415524 SCREW - 5/16-18 X 1/2 SOCK HD 4
    11 471227 FITTING 45 DEG. STEW. WARNER 2
    12 362487 CHAIN 20225 12 Incl. Ref. 36
    13 122210 OBS-USE 2721769 1
    14 131468 SPROCKET 25685 1
    15 337693 LWR BRACE 2
    16 352418 SPRING 2
    17 390495 COVER 1
    18 362496 $BLOCK 1
    19 441672 BOLT 5/16 X 2-1/2 REG CARRIAGE 1
    20 444718 LOCKNUT, 5/16-18 CENTER 1
    21 452006 FLATWASHER 5/16 1
    22 322166 KEY 20225 1
    23 400626 SCREW, 5/8-11 UNC X 3.50 HEX HD 2
    24 446166 LOCKWASHER 5/8 HVY 1.093 OD, 2
    25 443126 HEX NUT 5/8-11 PLATED 2
    27 441685 BOLT 20225 2
    27 446154 LOCKWASHER 1/2 HVY 2
    28 443118 HEX NUT 1/2-13 2
    29 400416 SCREW 1/2-13 X 2-1/2 HEX 1
    30 453017 FLATWASHER 1/2 2
    31 446154 LOCKWASHER 1/2 HVY 1
    32 443118 HEX NUT 1/2-13 1
    33 400108 SCREW 1/4-20 X 3/4 HEX 3
    34 453023 FLATWASHER, 1/4 3
    35 446130 LOCKWASHER 1/4 HVY 3
    36 470510 LINK 5/8" P. X 3/8 W. 1
    37 400196 SCREW 5/16-18 X 2 HEX 2
    38 444718 LOCKNUT, 5/16-18 CENTER 2
    39 353020 EYE BOLT 2
    40 443110 HEX NUT 3/8-16 PLATED 4
    41 162883 CHAIN ASY 1
    42 460014 COTTER PIN 3/32 X 3/4 PLATED 1
    43 461457 CLEVIS PIN 3/8 X 2-1/4 PLATED 1
    44 361854 DECAL, CAUTION WARNING 2
    45 131466 HYD MOTOR 21297 1 Not used on Mechanical Drive
    46 358944 MALE CONN 1 Not Used on Mechanical Drive
    47 360567 ELBOW 1 Not Used on Mechanical Drive
    48 354065 ELBOW 1 Not Used on Mechanical Drive
    49 400408 SCREW 1/2-13 X 1-1/2 HEX 2 Not Used on Mechanical Drive
    50 443118 HEX NUT 1/2-13 2 Not Used on Mechanical Drive
    51 446154 LOCKWASHER 1/2 HVY 2 Not Used on Mechanical Drive
    52 400108 SCREW 1/4-20 X 3/4 HEX 4 Not Used on Mechanical Drive
    53 453023 FLATWASHER, 1/4 4 Not Used on Mechanical Drive
    54 446130 LOCKWASHER 1/4 HVY 4 Not Used on Mechanical Drive
    55 443102 HEX NUT 1/4-20 1 Not Used on Mechanical Drive
    56 463031 WOODRUFF KEY 1/4 X 1 PLAIN 1 Not Used on Mechanical Drive
    57 352011 GROMMET 1
    58 163017 MTG BRKT 21297 1
    59 360178 DECAL 1
    60 470515 LINK 5/8" P. X 3/8 W. - PLAIN 1
    Attached Thumbnails Attached Thumbnails Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-hydrostatic-mounting-adapter-jpg
  2. #2
    Member
    Join Date
    Dec 2010
    Posts
    41
    Default Re: Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment
    Found out kubota supplies a very nice competative front mount hydrostatic motor snow blower for the Kubota F series front mower tractor using a quick connect adaptor (like me) - This little fact opens up my chioces and searches.
    There is also a snow plow with angle adjustment (need the 4WD model) & a circluar brush pavement sweeper - all front mount hydrostatic motor snow driven for the Kubota F series front mower tractor using a quick connect adaptor (like me) - These little fact opens up even more my chioces and searches - for goodies.
  3. #3
    Member
    Join Date
    Dec 2010
    Posts
    41
    Jacobsen OEM Snowblowers, Hydraulic Drive Frame Adapters, Mech Drive Frame Adaptors, AQUILLON Quick Connect Adaptor, and kubota F Series Front Mower Quick Connect Adaptor.
    Attached Thumbnails Attached Thumbnails Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-mechanical-mounting-adapter-jpg   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-oem-snowblower-without   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-oem-snowblower-without   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-oem-snowblower-without   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-heavily-modified-oem
    Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-heavily-modified-oem   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-heavily-modified-oem   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-heavily-modified-oem   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-heavily-modified-oem   Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-20110117-jacobsen-oem-snowblower-without
    Jacobsen Hydroststic Mounting Adaptor - SnowBlower Attachment-200110119-kubota-f-series-mower
    Attached Files Attached Files
Similar Threads
  1. Help us design on our Mulcher Attachment
    By bubenberg in forum Attachments
    Last Post: 01-25-2005, 08:53 PM
  2. TCC (Top n Tilt) Prelim Report (long)
    By MadDog in forum Attachments
    Last Post: 05-07-2004, 02:18 PM
  3. Virus
    By Bird in forum Related Topics
    Last Post: 09-20-2001, 09:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
