Results 1 to 2 of 2
02-05-2013, 03:27 PM #1New Member
- Join Date
- Jan 2013
- Posts
- 8
- Location
- Lincoln, NE
- Tractor
- Ford 1620
6 bolt 24" rear wheel discs
I am looking to put a set of Ag wheels on my Ford 1620 Hydrostatic MFWD. The sticking point is the rear wheel discs. I can find the 11.2-24 R1 tires easily enough, and the 24x10 rims are found pretty easily too. The proper ratio fronts are no problem at all, but nobody seems to make rear discs in the 24" range, and I don't relish the idea of buying a set of 26" discs and machining them down to 24"... but it may come to that.
I *am* hoping to keep the existing turf tire package, as they work fairly well with chains in the winter... but I would rather have Ag traction when I am pulling a box blade in the pasture if I can manage it.
Can anyone help?
02-05-2013, 04:26 PM #2Platinum Member
- Join Date
- Apr 2012
- Posts
- 639
- Location
- pa
- Tractor
- kubota 7040sud
Re: 6 bolt 24" rear wheel discs
Kubota makes them in 24'' thers 2 choices 103ibs each or 164ibs each call a dealer in your area
Similar Threads
JD 790 Rear Wheel Bolt ? What Size ?
By nforktractor in forum John Deere Owning/OperatingReplies: 7Last Post: 05-03-2013, 04:45 PM -
Affordable source for 24" rear wheel discs
By AlgorLangeaux in forum Parts/RepairsReplies: 0Last Post: 01-28-2013, 10:13 AM -
Ballast Bolt on rear wheel weights
By HJT in forum Kubota Owning/OperatingReplies: 12Last Post: 10-12-2010, 11:48 AM -
rear wheel lug/bolt for ym 240
By bassfishrman in forum YanmarReplies: 4Last Post: 11-02-2005, 01:13 AM -
BX23 Rear Wheel Bolt Size
By Erik2005 in forum Kubota Owning/OperatingReplies: 1Last Post: 05-24-2005, 09:58 PM
