ampa
Gold Member
- Joined
- Feb 9, 2009
- Messages
- 456
Hmmmm not too sure if I post this in this section....but since it still refers to gettin' my Lincoln up and runnin'.....I guess it should be okay....now the question !....I bought 10/2 wire......and it turns out to be 230 volts.....a red a black and the bare copper.....which is fine for my 30 amp breaker...I just curious do I treat the red or the black as the neutral....the bare copper to inside the panel box...to the receptical.....I didn't realize the difference till I peeled back the tough insulation...I hate working with high voltage....but in a sense I'm not....just the same as wiring a couple or so wall recepticals to the hydro panel....which I've done lots of times....mind you I shut the mains off and double check my work to make quite sure everything is hooked up proper before switching the main back on....I had installed another adittional smaller 2 breaker 230 volt panel that I used only for 110 volt in my old 32' trailer....I was getting a little tingle from the receptical...decieded to call a buddy that was a licenced electrician to check it out....told I done an okay job...just didn't tighten the bare ground enough....and it was bleedin' through a bit....after that no more tingles.....I always check and retighten all my connections after that ordeal....thanks in advance the correct advice I'm needin'.....take care.....Ampa.....
