Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 70
  1. #21
    New Member
    Join Date
    Oct 2012
    Posts
    10
    Niagara Falls
    Default Re: Millermatic 350P (first welds)
    Crazy Crazy Crazy weld quality, looking forward to the pulse mode, question for ya! with owning the 350P why would you still use the 252?
  2. #22
    New Member
    Join Date
    Oct 2012
    Posts
    10
    Niagara Falls
    Quote Originally Posted by 4shorts View Post
    Congrats on your new Miller. It is hands down the best unit I've ever used. Crazy weld quality and that's added up to more work for it and happy customers. I also run the Millermatic 252 and like it as well but the 350P is the machine I really like to use.
    Here's a job I did about a month ago for a machinist friend of mine. I used our Miller Dynasty 200 DX and tigged the root pass then I switched over to the Millermatic 350P in pulse mode to complete it. I setup the welding postioner and here's the result.
    My buddy was happy and so was the ships engineers. I was pleased when they said it passed the pressure test
    Pictures were taken with my Iphone
    [/COLOR]
  3. #23
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,254
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Quote Originally Posted by hotrodstones View Post
    The MM 252 is an all around general purpose machine. Fast to set up and great quality welds and that's why I have it here. The 350P is used for those larger jobs that require deep penetration on heavy metal along with a great looking strong weld but very hot to use, much hotter than the 252.
    Attached Thumbnails Attached Thumbnails Millermatic 350P (first welds)-gu9-jpg   Millermatic 350P (first welds)-dsc05945-jpg
    ...Excellence is not a skill. It is an attitude...
    Check us out on the web at www.specialtyrepairscustommods.com
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  4. #24
    Join Date
    Mar 2007
    Posts
    1,925
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    Pulse is the way of the future. I am seeing lessor cost units like the Miller and Lincoln 350P doing well with Pulse. European and Japanese technology is way ahead of the USA. OTC, Lortch, Fronius, Kempi. Have been running pulse for a long time. They also have Twin Pulse which is even more amazing than Pulse alone. You can run aluminum all position with no troubles. You can set these machines up like a Tig welder. Pulse frequency, Relationship, Trim and Crater fill. You simply pick your material thickness and the machine does the rest..They are little more money but we are trending toward pulse. Cored wires start to go to the wayside with pulse as well. Welders have really not changed much in the last 40 years. Look out for ten years from now. Digital High Def Twin Pulse Synergic machines will be in the 5k range and the 251/252 style welders will be collectors items much like a typewriter. That's how fast it's going to go.
  5. #25
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    [COLOR="#0000CD"]
    Great work as usual Paul.
    Beautiful welds. Sure nice to have the horsepower that the 350P provides.
  6. #26
    Join Date
    Mar 2007
    Posts
    1,925
    Midwest
    When the 350P's 1st came out they were a quite different animal. 90+% failure rate. Miller quickly sourced a better Pulse board and changed the dynamics a little bit and now it's nearly a top seller for them. Good unit. If didn't have a Digitsl High Def unit I would go with the 350P. You know, L-Tec and Hobart had pulse units out way back in the 80's. Thermal Arc and Lincoln started in the 90's and now Miller has an affordable unit. This is the trend.
  7. #27
    Join Date
    Oct 2010
    Posts
    784
    Yep I can attest to that.
    We bought two of them three or so years ago, I've got one that I use and there's another one that floats around the shop. Mine, I blow out everytime I change the wire, let it cool off if the fans running before I shut it down etc., I look after it.
    So far, mines been down 3 times each time with a circuit board problem that was fixed under warranty for around $1500 a pop and it's only got 60 or so arc hours and 6k or so starts on it. The other died a month or so back, just a big 'POP' when it was turned on. Almost $6K to repair it, all three boards gone so that's toast, that one has only 48 welding hours and 7K arc starts on it.
    When they work they are a beautiful working machine, the pulse is great, throw on a spoolgun or a Cobra or Python gun for aluminum and it'll lay a bead like you wouldn't believe.
    Salesman came in last week and a bunch of us we shotting the crap and we happened to mention the problems with them, his reply "Yeah, they're not really along lasting machne, we've had a lot of problems with them, I wouldn't buy one' . This is the same bird that siad these were a lifsaver machine LOL......Mike
    Would I buy one for myself....not a chance in he77.
  8. #28
    Join Date
    Jul 2008
    Posts
    3,254
    Kubota 5740,BX25D
    Quote Originally Posted by Scooby074 View Post
    Thanks Jason. Ya it's all in the tooling. here's a part I repaired off a rock picker yesterday and used the 350P.
    I've had the 350P for close to three years now and never an issue. I've visited the repair fissility that repairs all the major brand welding units on the island and never seen a 350P there. All I can say is this one has been flawless. It's welded for eight hours straight at times in hot weather in the shop doing excavator buckets and performed flawlessly. I have the 30 amp Miller spool gun as well for it and its just great.
    I will say that I do on occasion remove the tins and blow all the dust out of my welding equipment and been doing that for years. To date I've never experienced any down time with any piece of Miller equipment ( knock on wood)
    Attached Thumbnails Attached Thumbnails Millermatic 350P (first welds)-image-jpg
    Kubota ZTR ZG 222 Z
  9. #29
    Join Date
    Jun 2011
    Posts
    599
    kubota L4400
    Default
    You do some fine quality work! Beautiful!
  10. #30
    Join Date
    Jul 2008
    Posts
    3,254
    Kubota 5740,BX25D
    Quote Originally Posted by weldermike View Post
    Gee thanks Mike. Really appreciate that
    Kubota ZTR ZG 222 Z
Similar Threads
  1. Replies: 35
    Last Post: 04-11-2010, 01:17 AM
  2. Bad mig welds
    By dirt clod in forum Build-It Yourself
    Last Post: 06-20-2008, 05:30 AM
  3. Protecting welds from rust, bucket hooks
    By malk315 in forum Kioti Owning/Operating
    Last Post: 03-19-2007, 08:01 PM
  4. Century 3045 wheel welds broken
    By ray4713 in forum Century & Branson
    Last Post: 02-15-2007, 09:42 AM
  5. Cracks in welds on FEL
    By RichNJ in forum Kubota Owning/Operating
    Last Post: 08-24-2001, 03:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
