Results 1 to 9 of 9
07-08-2010, 05:38 PM #1Silver Member
- Join Date
- Jul 2005
- Posts
- 112
- Location
- N. Central Illinois
- Tractor
- Cub Cadet 2544
First "real" weld project
Today was the day for me to bite the bullet and do something useful with my welder. I've had this project on the list for a while - the trick was figuring out how to weld it (or who).
I am in the process of restoring a 1940's vintage Iron Fireman coal stoker and cleaning up a 1960's vintage boiler that will sit on a custom designed base that also contains the business end of the stoker underneath. I started on this path a few years ago when natural gas prices went through the roof. The system will be housed in a detached garage/shop and hot water piped to a fan coil in the furnace plenum (just like the outdoor wood boilers use). The only real difference is I'll be burning Illinois coal. We can save all the acid rain and carbon footprint discussions for later.... :-)
So the boiler originally had a domestic hot water coil installed which I didn't plan to need, and over the years the gasket had leaked and corroded the mounting surfaces badly. Rather than repair the mounting area and then block it off with a plate, I simply cut the entire area out and fabricated a solid plate with the same shape.
I beveled both the plate and the boiler (1/4" steel on both) and tack welded a small tab on each side of the plate so it would drop in and sit flat. I fired up the welder and started my root pass with 6011 at 120 amps. I had a bit more gap than desired in a few spots which took a bit to fill properly, and while it wasn't the prettiest welding, it definitely had penetration! I cleaned up the weld with the grinder to level it out and get a good surface for the fill passes. I also wanted to grind down a few spots and make sure there were no slag inclusions.
I then ran my fill passes with 7014 at 140 amps and I was rather pleased at how they turned out. I burned up a pound of 6011 and almost a pound of 7014 today. I uploaded two pics - the first one is after the first 7014 fill pass and the second is after a few followup passes and some cleanup with the grinder removing weldberries. It's not the prettiest job, but it's solid (I hope!). Not bad for having never picked up a stick electrode until a few weeks ago. I also uploaded a pic of "before" - prior to cutting out the area.
I'll pressure test the boiler with water this weekend and check for any leaks. Normal operation will be 12-15 psi with probably a 30psi relief maximum, so I should be more than good.
Chris
07-08-2010, 05:54 PM #2Platinum Member
- Join Date
- Jun 2010
- Posts
- 677
- Location
- w.v.
- Tractor
- ck30 kioti
Re: First "real" weld project
Well,that looks pretty good to me,you sure picked up on this stick welding quick too,
07-08-2010, 05:59 PM #3
Good job, Ken Sweet
http://www.sweetfarms.com/
Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
Shipping Facility
1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
Ken Sweet sweet@scrtc.com
Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
The Northeast shipping corridor is a little more expensive.
07-08-2010, 11:02 PM #4Veteran Member
- Join Date
- Mar 2007
- Posts
- 1,005
- Location
- Midwest
- Tractor
- Iseki TA 247. Husqvarna, Cub.Polaris ATV's
Nice Job... You will enjoy the boiler.. I built an outdoor wood boiler 2 yrs ago and I can burn Coal too. I plan to give it a go mixed with wood this winter. good Luck!!!
07-09-2010, 09:53 AM #5Veteran Member
- Join Date
- Feb 2008
- Posts
- 1,723
- Location
- "Ranchin'" on a 1/4 of a 1/4 in Seminole County, Oklahoma!
- Tractor
- 2004 Kubota M4800 SU
Looks good Chris. Looking forward to the test results.
Jay
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
If My people who are called by My name will humble themselves, and pray and seek My face, and turn from their wicked ways, then I will hear from heaven, and will forgive their sin and heal their land. 2 Chronicles 7:14 NKJV
07-09-2010, 10:41 AM #6Silver Member
- Join Date
- Jul 2005
- Posts
- 112
- Location
- Tractor
- Cub Cadet 2544
Thanks for the compliments everyone.
I've been around welding for 15 years, mostly MIG and a little TIG, but have only picked up a MIG gun a handfull of times for "government" jobs or simple projects at work that don't have to look good. Pretty much I just ask questions and listen to what the real welders have to say. Once you understand the basic principles and "feel" of it, then it is a matter of simply looking and listening to what is going on with the weld and adjust accordingly.
I actually enjoy stick welding more than MIG. I feel I have more time during the weld to see what is happening with the joint (especially with 6011) and manipulate the puddle to get the heat where it needs to go. With MIG you're just squirtin' out metal and best you can hope for is to keep the torch speed and weave consistent for a nice bead. I must say, though, that I really like welding MIG using a 400 amp 3 phase Lincoln or Miller with .045 wire. After fiddling with a Millermatic 250 and .035 wire, the first time I welded something with Big Momma I felt like Captain Kirk with his phaser set to 10!! ZzzzzAP --ooops, didn't want to put a hole there......
Edit: Here's a link to a picture album with some various shots of the refurb on the stoker and boiler: http://tinyurl.com/25a5vfo
And here is a video of the first test run on the stoker: http://www.youtube.com/watch?v=py49seodBPULast edited by EuropaChris; 07-09-2010 at 11:32 AM. Reason: Added links
07-09-2010, 11:35 AM #7Platinum Member
- Join Date
- Jun 2010
- Posts
- 677
- Location
- w.v.
- Tractor
- ck30 kioti
Yeah,thats why your doing so good with stick,you know what you are trying to accomplish,and how to go about doing it,thats really the hard part to learn,the welding part just takes practice,but you can practice doing something wrong forever and you won't get it right,if you know what I mean.
07-10-2010, 05:21 AM #8Super Star Member
- Join Date
- Apr 2000
- Posts
- 11,418
- Location
- Lebanon,NH.
- Tractor
- Kubota L2800HST w/Frontloader & CC 2042
Nice follow w/the rod Chris,before you know it laying like dimes weld.
07-10-2010, 01:41 PM #9
Just keep at it. Technique will come. Running multiple beads is a good start.
Mark Lugo
Everlast Welders
http://www.everlastgenerators.com/
Need a welder? Give me a call at (877) 755-9353 ext 204!
Similar Threads
Millermatic 350P (first welds)
By 4shorts in forum WeldingReplies: 39Last Post: 05-03-2013, 08:23 PM -
how thick do you weld with your wire feed / mig?
By lostcause in forum WeldingReplies: 51Last Post: 05-04-2012, 10:32 PM -
Chain hooks on FEL bucket
By killdozerd11 in forum WeldingReplies: 16Last Post: 03-27-2010, 02:11 PM -
Need help with land leveling project
By Legdoc in forum ProjectsReplies: 7Last Post: 06-19-2008, 01:49 PM -
First Big Project
By EdKing in forum ProjectsReplies: 14Last Post: 04-19-2002, 09:25 PM
