Gas Welding Practice
   / Gas Welding Practice #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I tried some butt welding practice on a small scrap of rusty steel I cut in two today just for fun.
Welder: Lincoln (Harris) PortaTorch.
Tip : #1
Rod: RG45 1/16
Pressure: about 2 lbs of Ace and Oxy
Metal thickness: about that of a Quarter.
Notice side 2 is more smoothed out. I practiced that technique, of running the puddle with the torch. Hit it with a hammer, and bent the base metal.
I will get better with practice.
James K0UA
   / Gas Welding Practice #2
What kind of torch are you using? I'd step up to a larger welding rod. It also looks like you have a lot of cold lap going on there. Watch for the keyhole to develop and then add the rod at the rear of the key hole using a slight circular motion, swiping from one side to the other side of the weld to create nice, smooth ripple. Keep the rod on the edge of the flame, just enough to keep the end of the rod wet but not melting. Are you using a forehand approach?
Harris torch, here are some more..pix.
the 3rd series is done with the Everlast 160 set on 39 amps with 1/16 Campbell Hausfeld rod. I moved too fast, not in a straight line:( and as expected the penetration was poor, and when tested the weld broke. to be fair if I had welded the back side, it would have held,. Metal thickness was about like a quarter. the 4th series was gas welded on the Lincold/Harris PortaTorch with the #1 tip , A little better results, expecially on one side. of course when hit with the hammer, the base metal bent, and the weld held perfectly. My technique is not good, sometimes I can get the "wetting action" I am looking for and you can chase the puddle down the seam really well. sometimes it just wants to "boil", and a puddle never really forms. Too hot?.. I need lots more practice with the torch and stick for that matter. But I could have done better with the stick if I had tried. Probably wouldnt have used CH rod either.:laughing: It was just handy and I am trying to burn it up. And now I am out of OXY!:( Oh well, done for the day.
James K0UA
   / Gas Welding Practice #4
Well,you got it stuck together but you failed the test,,,first test is to make it look good,,than you see if it will bend,,,forget about fusing two pieces together for now,,practice just running a bead on a piece of steel and making it look uniform without filler[just get a puddle going and move without melting through,,might need something a little thicker],,than try to do the same with filler,,than when you got it looking decent,,,than put two pieces together.
   / Gas Welding Practice #5
One of the interesting things I've found out about welding is if you concentrate on making a good weld it will usually turn out a good looking one. You can't say the same thing always about welds made to look good, especially with mig.
I personally recommend learning to weld first using gas. That's because you learn what's happening with the metal. It also reinforces a saying I use, "when you're almost melting it away you're closer to welding than when you're not."
Welding is about the "wet". Forge welding (blacksmithing) is done with the metal wet. So is gas, arc, mig, and tig. It's easiest to see and understand with gas welding.
   / Gas Welding Practice #6
For the stick, did you have the torch stuck in the positive side? It looks a little like straight polarity. What were your amps? What rod? Campbell hausfield should stick to air compressors. Get some real rods whether hobart, lincoln, McKay or even US forge. And get at least 3/32 to weld anything like that. It'll work just fine at about 60-70 amps. A little more for 7018. You should have easily penetrated through that.
Gauthier, the best welder I ever knew and could make anything hold did not have pretty looking welds. But they were strong and he could make and weld anything.(and fix anything too). My first welding instructor, that taught most of the commercial welders in S. GA, taught us, he'd rather have a gorilla weld rather than a nice smooth finished weld that didn't have any penetration. He defined a Gorilla weld as: Ugly as sin, but strong as a gorilla.
Mark it was electrode positive. yes Campbel Hausfeld rods are pretty much junk, I just did that for fun.. I know better, and can make pretty good welds with good rod and correct technique on the stick. It was 39 amps and 1/16 rod. this was pretty thin metal.
James K0UA
   / Gas Welding Practice #9
Well mark,thats why you're selling welding machines:),no offence really intended,,beauty can indeed be only skin deep,but in a weld,ugly goes clear to the bone,[generally speaking],,,
If you don't have the skill to put a decent looking weld on,you don't have the skill to make a quality weld,,,now you might have the skill to back yard weld something,maybe,,,
but gorrilla welds and brail welds are just for those who can't make anything else,,,plus,thats not how you learn,,thats not how you learn to do anything,you strive for perfection and never get it of course but you get better that way,you don't get better at anything saying,thats ugly and crooked but it will work...:thumbsup:
   / Gas Welding Practice #10
Gauthier,
Not sure what you meant by that comment...It sure didn't seem very friendly despite the smiley.
I haven't always sold welders. I still weld on the side, and have worked commercially welding for over 20 years.I've crew welded and owned my own business. I have been trained and hold multiple certificates in multiple processes including 6G pipe. I weld AND I can fabricate. I also have a background in VoAg where teaching welding is taught.
No, a quality weld doesn't have to be a perfect ripple weld. I've seen many certified welders who welds look like steaming pile of poo. But they pass X ray. I've seen perfect top welds full of slag underneath.
Basic needs of a quality weld are not asthetic beauty, but rather free from serious defect. Ripples can be inconsistent, but it doesn't mean it has to be poorly tied in or full of slag. A little shake in the hand can be compensated for. I agree practice makes perfect, but some people never get what I call a beautiful looking weld, but are making a good living at welding and passing inspections. There are others that make better looking welds and pass inspection. If what you say is true, then I would say: Beauty is in the sight of the beholder. To me, a properly tied in weld, free of slag, with decent heat lines is a thing of beauty.
Am I saying that because my welds look bad? No, my welds usually receive compliments. Of course every welder now and then puts one up that he knows will hold but he isn't proud of. A hot piece of slag in the wrong place can make a welder to a lot of squirming...
