ampa
Gold Member
- Joined
- Feb 9, 2009
- Messages
- 456
I'm wondering if my little 125 LINCOLN 120 volt will weld 1/4" stock to 1/8 "
I'm gonna' include a bunch of pics of what I'm doin' here....I'm tryin' to build a kind of hoist affair....I'll be attachin' a U type eyelet hook to the bolt of the hydraulic ram..... then usin' a chain from the attachin' point of the hook to somewhere convient on the "A" frame of the snowblade....I needed something to be adjustable....and this setup seems to fit my needs to a "T".
I got this idea from an OP's snowplough setup on his John Deere tractor from a past post....I've been tryin' to use up any used metal I have kickin' around the garage...got to clean up the garage and a storage area that will be my workshop/new metal work bench and all my machinery.....so nows a good chance for me to use alot of it up and make room.
So far some made up parts are okay but some need to beefed up with either 1/8" or 1/4" leanin' more towards the 1/4" stock.... My new Lincoln is set up for wire only( flux wire core only)....I've heard that the flux core welds better but you don't get a nice clean bead like you get with gas........anyhow guys please view the pics and tell me if I'm goin' about this the correct way.
"Yes" that is a mini hack saw I'm usin' to split the metal down...for the boom to ride in.......I could use my 4" grinder slap on a 1/8" thickness 4" cuttin' disc..... but it makes too many sparks and cuts out too much metal.
<<<<>>>Thanks in advance<<<<>>>> __________________AMPA<<<<<>>>>
