Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Apr 2010
    Posts
    975
    Default Welding bench
    Hi,
    I just pushed a hunk of steel 18"x48"x1.75" off a buddies truck into my FEL bucket. It has a lot of holes in it as it was used in some equipment or tooling. It looks to have been ground flat, but it is rusty now from being in the scrap pile. Bought it and a few other pieces for 8cents a pound. It will be a welding table eventually. Couple questions.
    How high should I make the table?
    Should I make it flush against the wall or leave some space behind it?
    What useful additions should a welding table have?
    After sand blasting it clean, what surface treatment to keep it looking decent?
    Thanks
  2. #2
    Join Date
    Mar 2008
    Posts
    208
    Default Re: Welding bench
    Comfortable height will be different for everyone. Look at what other benches you have, kitchen base cabinets and decide what would work best for you. I would also think about how you will get 'things' on and off, once welded up some can be real heavy.
    Coating it is counter productive. The good thing about a welding bench is everywhere is ground. They get pretty beat up pretty fast with slag and dust from grinding anyway. Every few years I take a disk grinder to mine and clean it up, welding isn't a neat clean operation.
  3. #3
    Veteran Member weldingisfun's Avatar
    Join Date
    Dec 2006
    Posts
    1,751
    West Bell County, Texas
    Mahindra 4500 4WD w/FEL, and Scotts S2048 lawn tractor
    How high should I make the table? Go with the advise Argosy gave.
    What useful additions should a welding table have? This too is kind of a personal preference thing. I added a bar to hang clamps and a couple of power strips to my table.
    Should I make it flush against the wall or leave some space behind it? This depends upon the size of your workspace. Being able to move around your project is a whole lot easier than moving the project around. If you have a large enough workspace, put casters on the legs of your table so you can move it out from the wall to get around it. When finished with your project, just move it back out of the way. And, if you do add casters, be sure to factor them into the overall height of the table.
    After sand blasting it clean, what surface treatment to keep it looking decent? Nothing, again, back to what Argosy said.
    You can check out my thread, maybe it will give you some ideas. http://www.tractorbynet.com/forums/w...ble-build.html Good luck and have fun.
  4. #4
    Join Date
    Mar 2007
    Posts
    184
    Moore, OK
    NH TC45DA
    Take a look at the Miller site. Miller - Welding Equipment - MIG/TIG/Stick Welders & Plasma Cutting
    They have plans for a welding table on it and one thing I like about it is it has a place for using a plasma cutter on it. Thats the one I plan on building this winter.
    Greg
    Everyday Above Ground is a Good Day
    NH TC45DA, 758C BH, Ottawa brush grapple, County Line 6' tiller, KK PHD with Power Down kit, 6' BrushHog, 6' MF finnish mower, Bionic Blade road grader, KK landscape rake, Kubota ZD326S ZT
  5. #5
    Join Date
    Apr 2010
    Posts
    975
    Thanks for the thoughts and the link. 4x8' -- that's large!
    I will try a mist coat of "The must for rust". It's a rust preventative that leaves a weldable / paintable surface. I might just paint the whole thing, then sand the top open and treat. Still debating.
    In the light of day I measured the metal. I was wrong. It's 42 1/2" wide, 24" deep and 1 3/8 thick. Has a regular pattern of what looks like 1/2" fine threaded holes and some larger tooling holes. Should work fine, even if it's been stored outside on the ground for 2 years. Hey, at 8 cents a pound it's still a good deal.
  6. #6
    Member
    Join Date
    Aug 2010
    Posts
    28
    Kubota BX23
    i wouldent go crazy with treating the top. mine seems to do fine with only a occasional shot of WD40.
    As for thing to incorporate into the design.
    leave sufficint overhang for all your clamping needs.
    make holders for grinders so you can access them easily.
    have some hooks to hold your stinger so you can easily set it down between welds/repositioning.
    Not sure how long you want the final table to be, but I wish i had incorporated a grated section into mine for flame cutting.
  7. #7
    Veteran Member jayste's Avatar
    Join Date
    Feb 2008
    Posts
    1,738
    "Sold the 1/4 of a 1/4 but still tractorin' "
    2004 Kubota M4800 SU
    Sounds like you've got the makings for a great table. You could plan in an idea for quick attach for a vice and bench grinder. You could also make the legs "telescopic" where one piece of pipe or tubing slides inside the other and have holes in it for putting pins in to so you can adjust the height. Also, I'd plan on getting some 1/2" fine threaded set screws to screw into the holes in the top while you weren't using them to keep spatter and such out of the threads.
    One more after thought. I once worked in a weld shop that had weld tables and positioners connected to a common ground strap that was ran along the floor. Each welding machine was attached to this common ground but also had the ground lead still attached to use as well, if needed. This works great if your not rolling things (tables and such) around.
    Jay
    "The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so" Ronald Reagan
    But God demonstrates His own love for us in this: while we were still sinners, Christ died for us. Romans 5:8 NIV
  8. #8
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    I have my welding table a little low, makes it easier when working on something. If I'm doing a lot of Tig welding on small parts in the vice I set down. Building bigger things I stand up. There are no hard and fast rules.
  9. #9
    Join Date
    Jun 2010
    Posts
    677
    w.v.
    ck30 kioti
    Don't paint it,piece of heavier angle on one side edge is good for laying pipe in,combination vise,thing of some sort on one edge to hang stinger,and welding curtains,,,those holes will come in handy.
    If your putting it against a wooden wall,leave room to put a welding curtain/screen behind it.
  10. #10
    Join Date
    Jan 2009
    Posts
    1,319
    upstate South Carolina, Greenville
    Kubota M6800, Massey Ferguson 240
    Dumb question, but if you use casters with rubber or synthetic wheels, does this interfer with the ground? Or does there need to be metal contact with the floor?
Similar Threads
  1. begining welding
    By greenthumb in forum Welding
    Last Post: 01-11-2011, 11:25 PM
  2. making a boom pole?....
    By StevenPaul in forum Build-It Yourself
    Last Post: 10-13-2005, 02:46 PM
  3. Finally decided on welding machine
    By chim in forum Welding
    Last Post: 10-18-2003, 01:20 PM
  4. 1st Welding Project - Bucket hooks
    By Henro in forum Welding
    Last Post: 08-09-2003, 12:01 AM
  5. welding hyd line
    By trailertrash in forum Welding
    Last Post: 11-05-2002, 04:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
