Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2002
    Posts
    73
    Middletown,PA
    BX2200
    Default New Welding Table
    Always wanted a good heavy welding table,so I
    glued one together. 6 x 6 legs, 4" channel and
    3/8" plate, estimated weight 750 lbs.
    Attached Images Attached Images
  2. #2
    Join Date
    Mar 2002
    Posts
    73
    Middletown,PA
    BX2200
    Default Re: New Welding Table
    Painted and in position, took a couple buddy's
    to roll it over.
  3. #3
    Join Date
    Mar 2002
    Posts
    544
    Jackson County, Michigan
    Bolens HT-20
    Great lookin' job! That's one of the to-do's for me. I'm looking to cover it mine a thin copper sheet. All I have done so far are the vise jaws!!!!!!![img]/w3tcompact/icons/laugh.gif[/img]
  4. #4
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    11,418
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC 2042
    Looks great..plenty of room for selfing.
    Nice big vise at one end w/portable chop saw sitting in the middle,and set of chain falls on rollers above plus a coffee maker to one side..it shall become home away from home. [img]/w3tcompact/icons/wink.gif[/img]
  5. #5
    Super Member
    Join Date
    May 2002
    Posts
    5,576
    Wylie, Texas
    JCB165HF
    That's nice.
  6. #6
    Elite Member
    Join Date
    Apr 2000
    Posts
    3,685
    Stowe, Vermont
    Kubota L3240HST, KX-121-3S
    That's a nice set up! I dream of the day I have enough room to devote some of it to a fixed welding table. Till then, it's a hunk of grating on top of a metal barrel...something I can wrestle from place to place!
    Pete
  7. #7
    Join Date
    Jan 2002
    Posts
    1,265
    Western Michigan
    NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
    Nice job on the table. Is the top solid? When I make mine I plan on having some elongated slots in the top so I can clamp things down in various spots. I use those Vise Grip clamps (see attachment) a lot when I weld and some elongated slots in various positions would be helpful to clamp things down in the middle of the table.
  8. #8
    Join Date
    Apr 2002
    Posts
    79
    Omaha Nebraska
    Yanmar 1500D
    Nice table. It won't be moving around on you.
  9. #9
    Join Date
    Mar 2002
    Posts
    73
    Middletown,PA
    BX2200
    Yes, Spence the top is solid 3/8". I set the channel back
    2 inches because of clamping things down. Slots would be nice but they have there drawbacks also. Thought if I need a clamp in the middle i would tackweld something to the table and grind it off later, thats why i used 3/8 instead of 1/4 plate.
  10. #10
    Join Date
    Apr 2002
    Posts
    874
    Monroe,Washington
    New holland TC29-9x3 Woods 1012 FEL, Woods, 7500 Backhoe / Kubota L345DT 4WD, Kub FEL, Kub Backhoe
    Your shop is so clean it looks like the Health Dept. could certify it for food prep.
    Great job on the table.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
