Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jul 2010
    Posts
    1,624
    Central Coast of CA
    Massey Ferguson 1010
    Default gas welding carbon steel to stainless
    Is there anything other than brazing that can be done to join these two dissimilar metals? It's a gas only proposition.
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    Default Re: gas welding carbon steel to stainless
    Quote Originally Posted by handirifle View Post
    Why is that?
  3. #3
    Approved Advertiser
    BXpanded's Avatar
    Join Date
    Jul 2008
    Posts
    717
    Knoxville, TN
    They're compatible. Just go ahead and weld it with steel filler rod.
  4. #4
    Member
    Join Date
    Oct 2010
    Posts
    35
    Default
    TIG will do it
  5. #5
    Gold Member E/S's Avatar
    Join Date
    Aug 2009
    Posts
    469
    Reno, NV
    Kubota M8540HDC12-1 4x4 w/ Cab
    Quote Originally Posted by DiverDarrell View Post
    TIG will do it
    x2
    MIG also.
    E/S
    2009 Kubota M8540HDC12-1 4x4 w/ Cab
    LA1353 FEL w/ 7' Bucket & Pallet Forks
    McMillen X1475 Earth Auger w/ 9", 18" & 24" augers - Land Pride RCR3596 Rotary Cutter
    Gearmore 4G4 Series 7' Box Scraper w/ hydraulic rippers
  6. #6
    Join Date
    Jan 2009
    Posts
    6,064
    Port Orchard, WA.
    John Deere, 4200
    I found a little, (very little) bit about welding stainless steel with O/A in one of my old books.
    Tig, and SMAW are probably the two cheapest processes to get going. Mig would mean a tri-mix gas which most people don't have on hand.
    Attached Thumbnails Attached Thumbnails gas welding carbon steel to stainless-1-jpg   gas welding carbon steel to stainless-2-jpg
  7. #7
    Veteran Member Kays Supply's Avatar
    Join Date
    Jul 2006
    Posts
    1,119
    Southern Illinois
    Iseki TA 207
    When I worked at a cannery, all the shoots were SS. We put legs and braces on them that were mild steel. We just used a SS rod on a DC stick welder. No big deal.
  8. #8
    Join Date
    Jul 2010
    Posts
    1,624
    Central Coast of CA
    Quote Originally Posted by Shield Arc View Post
    Why is that?
    Due to space. It's a small part and I silver brazed it before, but it didn't hold. So I am wondering if welding with the steel filler rod idea will, indeed, work?
    I don't have a tri-mix gas for the mig, and would be afraid to try it. Would sil-fos work? I have tons of experience with sil-fos, but never with these two metals. I have a lot of silver solder time as well, but this did not take well to it, for some reason. Maybe it got dirty by my earlier attempts, not sure.
  9. #9
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    2,265
    South GA
    In "Normal" welding techniques, its proper to use stainless filler to make the connection between steel and stainless...not steel filler.
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  10. #10
    Join Date
    Jul 2010
    Posts
    1,624
    Central Coast of CA
    Quote Originally Posted by Mark @ Everlast View Post
    OK thanks, I was told by others, before, to use the silver solder.
Similar Threads
  1. IMPORTANT! Welding Galvanized!!!!!!
    By wroughtn_harv in forum Welding
    Last Post: 11-14-2010, 10:08 PM
  2. Welding with Gas **WOW**
    By mcd176 in forum Welding
    Last Post: 06-24-2009, 07:03 PM
  3. high carbon tool bar steel
    By bjr in forum Build-It Yourself
    Last Post: 05-29-2009, 04:33 PM
  4. gas welding gauge
    By JNB in forum Welding
    Last Post: 05-05-2008, 01:34 PM
  5. Welding on Diesel Storage Tank Steel
    By gmason in forum Welding
    Last Post: 04-02-2008, 02:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
