Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    Default Need some scrap for practice.... so
    I thought I'd go down to the shop where I usually get my steel and see if they would let me "borrow" 10 or 20 lbs of their small drops. I go home, weld them all together and then return their scrap a little heavier and a little easier to move. I then get another 10-20lbs and repeat.
    Think they'll go for it?
    Ian
    Everlast PowerArc200
  2. #2
    Super Member dcyrilc's Avatar
    Join Date
    Nov 2009
    Posts
    5,469
    Woodinville, Washington
    John Deere 2240 MFWD
    Default Re: Need some scrap for practice.... so
    Quote Originally Posted by Haywire View Post
    Ian
    Depends on how well they know you and if it's scrap bin stuff. Good chance though. Certainly can't hurt to ask.
    Cyril
    JD 2240 MFWD (with duels now)
    145 FEL, 8ft Rear blade (now I need a 12ft blade)
  3. #3
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    It'll be a couple weeks before I can get down there. I suppose it depends on if they root through the scrap bin for stuff like gussets and such. I'm on pretty good terms with them, I've been buying odds and ends from them for a couple years and they're a small shop.
    Ian
  4. #4
    Platinum Member rjmack's Avatar
    Join Date
    Jan 2010
    Posts
    537
    cariboo wagon rd
    GC2410 May 4/10, mf10 (2)
    look for 1/2x3 and 1/2x1 flatbar.
    cut them into pieces about 8" long and tack them together like this -|-
    fill up all 4 fillets, all positions,with nice flat welds, no undercut.
    2009 mf gc2410
    1970 mf10 power wheel barrow
    1968 mf10 riding mower
    __________________________________________________ ______________
  5. #5
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    Why no undercut? I thought with stock that thick, that a 30deg bevel would be standard.
    thanks,
    Ian
  6. #6
    Veteran Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    1,952
    Northern CA
    thanks,
    Ian
    I think rjmack is referring to the edge of the weld rather than the bevel - but I don't want to speak for him.
    If you don't pause just a bit when weaving, the edge of the weld will "undercut" the metal and cause a weak, or thin, line down the edge of the weld. It is particularly noticeable on the vertical plate when welding 90 degrees (2F).
    It can happen when whipping but not nearly so much in my experience if you take it slowly.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  7. #7
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    ah.... terminology
  8. #8
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,722
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    A good rule of thumb with undercut, if you can hang your finger nail in it, it's too much.
    That's not to say a welding inspector might have a different opinion.
  9. #9
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    I think OP's idea is a good one. They should go for it, especially if they know you. They're not risking much with 20 lbs of scrap.
    Undercut ? I call it proof of deep penetration, different ways to look at things I guess.
    I thought this was a great weld I did to my 3 pt lift arms. 3/4" material in single pass. That slight undercut told me the weld penetrated deeply.
    Like I have mentioned in the past, I don't even know what I don't know about welding, but I keep making smoke
    JB
    Attached Thumbnails Attached Thumbnails Need some scrap for practice.... so-dscn5891.jpg
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  10. #10
    Join Date
    Nov 2009
    Posts
    5,469
    Quote Originally Posted by Shield Arc View Post
    What exactly is undercut? Is it the weld hanging over the base metal or burnt into the base metal?
    Cyril
Similar Threads
  1. Newbee to metal fabrication with scrap Q's
    By LotsofGreenGrass in forum Build-It Yourself
    Last Post: 03-22-2011, 09:13 AM
  2. Do scrapyards still take scrap ?
    By Renze in forum Build-It Yourself
    Last Post: 02-06-2009, 06:39 PM
  3. Anyone sold scrap lately ??
    Last Post: 01-22-2009, 07:04 PM
  4. Copper scrap: what $ to expect for "dirty" copper?
    By frank29 in forum Rural Living
    Last Post: 09-02-2007, 05:30 PM
  5. rescued sears suburban from scrap yard
    By Ryan03 in forum Craftsman / Sears
    Last Post: 12-22-2006, 03:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
