Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
  1. #1
    Elite Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,792
    Etna, NH
    2007 MF GC2310 TLB
    Default Not pretty, but...
    Didn't know if I wanted to put a pic of my welding on here, I'm strictly a beginner!
    But I decided that I just couldn't live without hooks on my FEL any longer, and I don't have a large arc welder so I grabbed my oxy-acetylene set and started out....
    Did the first hook (center) with my right hand on the right side, then tried the torch in my left hand for the left side; won't try that again. Not pretty, but I think it'll hold OK. Second hook went better, had a better idea of how much heat to use. One more hook to go.
    Any comments? (How'd the student do?)
    Should I even bother to try the wire-feed I have, or would that just not be up to the task? (It's a Lincoln 115V SP-125 PLUS with no gas, just flux-core wire.)
    Attached Thumbnails Attached Thumbnails Not pretty, but...-1-center-rt-side-jpg   Not pretty, but...-1-center-left-side-jpg   Not pretty, but...-2-rt-rt-side-jpg   Not pretty, but...-2-rt-left-side-jpg   Not pretty, but...-two-hooks-jpg
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, DR 60" Power Grader, DR Lawn & Leaf Vac
    '05 VW Jetta Wgn TDI
    Numerous vintage Japanese motorcycles
  2. #2
    Gold Member
    Join Date
    Nov 2006
    Posts
    396
    Barossa Valley, South Australia
    Duetz DX3.70, Fendt 305LSA,260S & 205P,Kubota B6100E & 3 x B5100E & RTV900, Caterpillar 428C
    Default Re: Not pretty, but...
    Don't know if the Lincoln would be up to the job but I'd say your welds look good for O/A.
    They should certainly hold.
    When I have ****** welds I smear some "No More Gaps" in the cavities prior to painting - no one will know!
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,747
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by allenr View Post
    Oh sure, let our secret out to just everybody!
    Really I think most of the welds look pretty good, the left handed one is not as pretty, but you knew that. I bet they stay stuck!
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #4
    Gold Member HiTechTed's Avatar
    Join Date
    Aug 2010
    Posts
    296
    Indiana
    Kubota L3400
    I have a Lincoln Pro 100 wire welder and I use it for everything (including my bucket hooks). I have welded 1/4" and even thicker with it using multiple passes and it works, although I throw the breaker a lot on thicker metal. It's what I have so I use it and so far all my welds have held!
    I'd say give yours a try, but make sure to use good wire in it (like Lincoln-branded wire). It makes a big difference. And for the record, your torch welds probably look better than my torch welds would...
  5. #5
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    With a little grinding and a cover pass of flux-core that left side weld might look better. You might even use it all around to spruce things up.
  6. #6
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    The first picture looks the best, but you need to add more filler to the crater. All the other welds I'd grind out and do again!
  7. #7
    Join Date
    Jul 2005
    Posts
    1,924
    NH seacoast & Coos County
    Kioti DK45S
    Quote Originally Posted by Shield Arc View Post
    I second that !! Cleaning it up & knowing it won't fail is better than hoping it won't fail & being wrong. MikeD74T
  8. #8
    Join Date
    Feb 2008
    Posts
    2,792
    Etna, NH
    2007 MF GC2310 TLB
    Thank you all for the great suggestions! I really hadn't thought of adding wire feed as filler before painting.
    HiTechTed, thanks for the tip, though I have no idea what brand the wire is- bought the machine used, for a great price.
    I, too felt it was more important to get deep penetration (don't we all wish for that- oops, sorry!) than to have it look good, though a smooth appearance is nice. I made sure metal was good & hot and almost melting as I was adding filler; that much I learned --the hard way-- from the class I took a year or so ago. Saw a couple of my "jobs" pop right apart with a moderate hammer rap.
  9. #9
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by irvingj View Post
    and almost melting
    That's a problem right there! You want the metal melting before you dip the filler.
  10. #10
    Join Date
    Feb 2008
    Posts
    2,792
    Etna, NH
    2007 MF GC2310 TLB
    'K- Thanks for the tip! I wasn't sure if I was remembering that part correctly.
Similar Threads
  1. Recycling old implements - making them pretty
    By ctgoldwing in forum Build-It Yourself
    Last Post: 12-31-2009, 03:45 PM
  2. pretty new hoe --
    By Unregistered2013 in forum Kubota Owning/Operating
    Last Post: 04-12-2009, 02:58 PM
  3. BX24 seat is pretty comfortable . . .
    By farmerdoug in forum Owning/Operating
    Last Post: 02-22-2009, 01:22 AM
  4. building a "Pretty" Barn
    By gmason in forum Rural Living
    Last Post: 04-29-2002, 06:32 PM
  5. Pretty close to a deal
    By Mrwurm in forum Buying/Pricing/Comparisons
    Last Post: 04-12-2002, 12:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
