Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    4
    Default Servis box blade
    Looking for Rippers for my Servis box blade
  2. #2
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    Default Re: Servis box blade
    Quote Originally Posted by HAYSDANNY View Post
    are you wanting to make or buy them?
    Never carry gasoline in your car trunk. If you do, atleast use some sort of container.
    -red green
  3. #3
    New Member
    Join Date
    Aug 2011
    Posts
    4
    WOULD BUY IF NOT OUTRAGUS LOCAL DEALER SAID THEY COULD GET THEM FOR $100.00 EACH
  4. #4
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    Have you checked with this outfit? Their website is a little hard to get around in, but they have a lot of stuff!
    Agri Supply - Farm Supplies, Tools, Lawn Mower Blades, Cast Iron Cookware
  5. #5
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    I think the rippers would be fairly easy to make with an O/A torch, and a large angle grinder, just make a pattern, torch out the shapes, and grind until perfect. $100 sounds like alot per ripper, are you sure they meant $100 PER TOOTH?
    -red green
  6. #6
    Join Date
    Jan 2009
    Posts
    6,019
    Port Orchard, WA.
    John Deere, 4200
    When I built my ripper / counterweight I bought the shanks from Agri-Supply. Back then they were about $9.00 a piece.
    Agri Supply - Search
    Attached Thumbnails Attached Thumbnails Servis box blade-ripper-jpg
  7. #7
    Join Date
    Mar 2007
    Posts
    1,859
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    I built a makeshift tooth bar for my back blade out of Railroad Spikes. Rippers a different but Spikes could be engineered at an angle to do a fair job on a box scraper too. Plus they are usually Free and very hard.
  8. #8
    Gold Member Degolyerent's Avatar
    Join Date
    Nov 2010
    Posts
    439
    Default
    What does the teeth look like? Do they have holes in center or notches in front or back? Teeth are available for less than the price you where quoted, the types I mentioned are about 20-30 bucks each and come in different lengths( regular or long)
  9. #9
    Join Date
    Aug 2004
    Posts
    1,932
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Welcome to TBN Danny!
    If it's like this it's the standard front notch design.
    http://support.servis-rhino.com/Rhin...UB%2004-10.pdf
    Maybe you ordered these already? Let us know how you made out.
    BOX BLADE SHANK 17.52'' LONG, 3 SLOT - Agri Supply
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
Similar Threads
  1. Box Blade vs. Rear Blade
    By Perplexed in forum Attachments
    Last Post: 04-28-2015, 06:35 PM
  2. Hinged Box Blade - What's the difference.
    By PBinWA in forum Attachments
    Last Post: 05-24-2011, 10:17 PM
  3. Box Scraper Woods box blade?
    By Tractor Shopper in forum Attachments
    Last Post: 03-10-2010, 12:18 PM
  4. Box Scraper Box Blade Scraper Repairs
    By smgutsch in forum Attachments
    Last Post: 05-16-2009, 12:18 AM
  5. Box Scraper Box Scraper with Hinged Rear Blade
    By aquetrac in forum Attachments
    Last Post: 04-06-2008, 06:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
