Just another chart for extension cables.
Extension cord - Wikipedia, the free encyclopedia
I am still confused about the wiring from inside the house to an outside sub panel.
Would someone compute the gage wire from the circuit breaker panel in side the house, to the outside of the house about 30 ft, then 75 ft run to a sub panel for my plasma cutter using 240 V, and the machine drawing 46 A. The input gage for the plasma cutter is 10 ft of #8. What would be the circuit breaker size on the inside panel, and the sub panel. If I made up an extension cord of 50 ft, what gage wire should it have .
Would the gage wire be different if I used 4 single stranded inside conduit, or direct burial?
ProCut-55 plasma cutter
TECHNICAL SPECIFICATIONS - PRO-CUT 55
INPUT RATINGS
Single Phase Input Input Currents Rated Output Amps
Voltage and Hertz
208/1/60 Input-60A , 55A Output
230/1/60 Input-55A , 55A Output
RECOMMENDED INPUT WIRE AND FUSE SIZES
For all plasma cutting applications based on U.S. National Electrical Code
Ambient Temperature 30ーC or Less
AC Input Voltage Fuse (Super Lag) Type 75ーC
at Circuit Breaker Copper Wire in Conduit AWG
60 Hertz (Delay Type) (IEC) Sizes
2 Input Supply Wires 1 Ground Wire
230VAC Single Phase 70 Amps #8 (8.4mm2
) #10 (5.3mm2
