Drill Doctor
   / Drill Doctor #1
cmyoung2
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Not sure where to post this, but opinions on the Drill Doctor for sharpening drill bits. Thinking about one, have plenty of old bits to practice with
   / Drill Doctor #2
I have never used the Drill Doctor brand. I have a Sears that broke after many years. I am now set up with a standard drill grinding guide. I set this up on a seperate grinder. I have also done many drills by hand. A number of tool maker sharpen large drills by hand ( 1"-2 1/2" ).
It is easy to sharpen the large drills,it is the smaller sizes that are near impossible by hand ( you can not see them ).
I just bought a large replacement kit of drills with many in the smaller range ( 10 drills / size ).
You a can break them just looking at them.
Craig Clayton
   / Drill Doctor #3
I bought a Drill Doctor and even after I opened up the box and looked at it I was somewhat disappointed...plastic everywhere.
I was wrong. The damned thing works well. No more challenging than sharpening a pencil.
   / Drill Doctor #4
I noticed Canadian Tire has the Drill Doctor on sale for $49 this week and was wondering if it is any good as well.
   / Drill Doctor #5
All those gimmicks are to slow. Learn to do it on a bench grinder. ;)
   / Drill Doctor #6
I have an older one, and it works great. When I step up to a broken bolt now, I know my drills are going to cut into it. Hand grinding drill bits on a grinder was for me a hit or miss thing. Gone are the days of pressing a drill against something and getting nothing but heat. I'm a simple guy, I just want to see that little spiral of metal coming out of the hole as I drill. The drill doctor is the way to go. Perfect angle and edge. The only thing I don't like is that I cant sharpen smaller than 1/8 bits.
   / Drill Doctor #7
there's a few different versions. the lower model - the 350 only does one tip angle - 118 degrees and doesn't do split points. the 500 will do angles from 118 to 135 degrees and split points. there's also a couple other models too, but those two are the most common. looking at the site, the 350 doesn't list cobalt drill capability. maybe they use a different sharpening wheel? i've been considering getting one, but if and when i do i'll likely go for the 500. sadly, it's around $100 here.
   / Drill Doctor #8
To the Ontario boys I bought past tense ( on sale ) the Mastercraft Titanium 204 piece drill replacement kit $37.00. Lots of smaller range drills.
I was drilling out a muffer mounting stud in the exhaust system. This stud had the fluted shoulder so it was a good and tough grade. I used the Mastercraft Titanium brand. I had to resharpen every 1/16" of depth. not that the edge would not hold but I was under the truck with a hand drill. I stepped up with 3 drill sizes.
So I drilled a total of 1" of stud up the middle.
1 x 16 =16 sharpens / drill
16x 3 = 48 total sharpens more or less all by hand.
Practice makes perfect
Craig Clayton
   / Drill Doctor #10
i have a copy the seems to work great. did a big coffee can full the day I opened the box. havn't used up enough bits to try it again..
soundguy
2017 Ram 1500 Crew Cab Pickup Truck (A51692)
2017 Ram 1500 Crew...
1992 Ford E350 Box Truck (A53117)
1992 Ford E350 Box...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
