rankrank1
- Joined
- May 23, 2007
- Messages
- 749
- Location
- SW OH - near Dayton, OH
- Tractor
- 1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC, 1948 Case SC
AC/DC WELDER / Lincoln Idealarc 250/250
If this is still up, grab the Idealarc and skip the Stickmate! :thumbsup: Stickmates are good, but Idealarc machines are a whole 'nother class.
Wonderful arc, and manuals are still available from Lincoln. They are tough and routinely outlive their owners.
They'll run off a 50A breaker (not maxed out, but you won't normally need to) and are fine commercial stick machines.
We trained structural and pipe welders using a fleet of the square top variety, and they make excellent scratch-start TIG machines.
I use crazedlist to aggregate craigslist results:
crazedlist.org : search craigslist like a madman
I agree the Lincoln idealarc 250/250, idealarc 300/300, or even the Miller dialarc are all a step above the smaller buzzboxes and they can be found rather cheap.
That said they are not necessarily the best choice for everyone:
a) First you need big wiring wiring to run the industrial machines on the order of 90-100 amp service to run one safely and properly. Running one of these on oversize breaker on undersized wire is NOT permitted as their duty cycle is too high. (A smaller buzzbox on the other hand will easily run off 10 gauge wire with an oversize breaker on undersized wire and is NEC code legal due to the lower duty cycle).
b) The industrial machines are immensely big and heavy - notice that each one has a lifting hook on it for a crane lift. No huge problem if you have a nice shop with concrete as you can build a cart to push it around on with vast amounts of concrete - or you can leave it parked in one spot. (If you are like me though without a good shop then I need something that I can easily move outside in the grass, gravel, or mud. With the smaller class of buzzboxes you can easily move them around. Smaller buzzbox is also easy enough to pick up and load in the truck by hand and take to a friends house. 10 gauge cord out to 95' and I can power a small buzzbox off a friend's stove or dryer power in a pinch).
Again not knocking the big industrials as they are great machines, but there are also some trade-offs to them that are not really related to their actual performance which is admittingly better.
