deereman75
- Joined
- Apr 29, 2011
- Messages
- 1,912
- Location
- canada
- Tractor
- Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well today I was doing some torch cutting for the first time in probably 2 years. All the torch cutting I had done then was melting my way through some rusty re-bar. I have been watching a few videos on it, and looked up the settings online. Well here it is. I was using 5 psi acet, and 25 psi oxy with an airco 00 tip. 1/4 inch plate covered in rust, spatter, and 6011 slag.
Here is some pictures of the top and bottom of the plate.
Here are some of the cut.
NOTE: no cleaning was done to the piece before or after the cut. The pictures are of two differnt cuts on the same piece.
So what do you think? Any tips? I wont be able to do any more cutting for a few weeks, since I am out of oxygen, and I wont be able to get to air liquide for a while. When I get more oxygen, I will be able to try any tips.
