02-07-2012, 12:08 AM
#1 (permalink)
| | Gold Member
| $1500 budget what to buy ? Looking at some Chinese made, with I hope American pride all-purpose welders plasma cutters. Any comments would be appreciated. Looking at the forum sponsors for a machine, everlast or longevity ?
__________________ 2011 John deere 3005, already waxed 5 times.
I drives me boat ! My wife drives me dingy ! |
02-07-2012, 01:16 AM
#2 (permalink)
| | Veteran Member
Join Date: Nov 2007 Location: Sands Township, Marquette Co, Michigan
| Re: $1500 budget what to buy ? Millermatic 211 GMAW (mig) welder with tank and everything you need, spoolgun for aluminum and stainlees steel would be about $1,500. It runs on 120 or 240. I have one and I like it alot.
I also have a used Miller Thunderbolt SMAW (stick welder) which I picked up for $20 and invested about $120 for wiring and connectors. It is a 240 machine AC/DC. If you bought an old Lincon Tombstone or Miller Thunderbolt welder (SMAW), you would have enough for a good torch set for cutting and welding. I also have a Plasma cutter - Hypertherm Powermax 600.
Buying a multipurpose American welder (Miller, Lincoln, Hobart) with the attachments for SMAW, GMAW and plasma cutting isn't going to be in your budget, not even close.
Even with a less expensive Chinese welder to have everything you need (cables, hoses, consumables, tanks, carts regulators, etc.) to do everything you want is going to be quite expensive. http://youtu.be/4HVU21qLUV4
02-07-2012, 05:22 AM
#3 (permalink)
| | Veteran Member
| Re: $1500 budget what to buy ? I've read in a couple different places to stay away from the all in one units. Most of the problems seem to be with the units with high freq for Tig, and plasma combination.
What type of welding will you be doing?
__________________
Miller Dynasty 300.
Lincoln V350-Pro w/pulse
LF-72
Lincoln SG Spool gun
Miller 330A/BP.
Lincoln LN-25.
Everlast PowerArc 200.
5 Lincoln SA-200s.
1800 Ellis saw
Hypertherm Powermax 1250, CNC table.
PROFAX Welding Positioner.
JD2 model 3 |
02-07-2012, 06:35 AM
#4 (permalink)
| | Veteran Member
| Re: $1500 budget what to buy ? If that is all I could spend and wanted a versatile shop, I would look for a good used AC/DC 220Volt stick rod machine that can be found for not more than $400 complete with fairly long welding leads of 50 or more feet. I picked up my Miller AC/DC CC/CV 350 amp machine with 150 feet of lead for $350. This would leave you enough to buy a good Victor oxy/acetylene torch for around $350. Rent your bottles for the time being rather than buy which would cost you another 300-400. So now you have spent 800-900 which leaves you plenty of money to pick up 2 or 3 Harbor freight 4.5" grinders ($20 each) and abrasive blades (10 pack assorted for $6 on sale) /wire brushes, hand wire brush, chipping hammer, AD hood ($49) and then a visit to your local welding supply for an assortment of welding rods for the stick machine, maybe some brazing rods for the oxy torch and still have some money in your pocket to pick up a used Phoenix 50 pound rod storage oven.
Shop is then ready to fab whatever you want. Later as more money is available, spring for your own bottles, maybe a MIG welder (220 volt rather than the underpowered 110v) or even a plasma torch. Since these last items would run you about what you have budget $1500 each, these would be a good to have but not necessary for the time being. Cheaper units are available for each of those, but many folks end up trying to sell the cheap stuff and buying more powerful units later so why waste your money. Wait till you can afford the best unit. Remember when buying a MIG/FCAW, you're going to need a bottle of mixed gas to run it if you want good quality welds. FCAW can be ran without gas shielding, but better results are obtained with a shielding gas. I have found that I can do anything I need with my stick machine and if I were to add to my shop it would be a TIG gun with high Frequency box so I could also weld aluminum. Leave the wire feeder to folks needing high productivity which is what they were originally developed for but have developed favor with home users because when properly set they produce good looking welds with very little practice. Good looking doesnt always equate to strong however as MIG welds are notorious for cold lap and non fusion which looks good but might not hold as well as one would think.
__________________ 2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB with 3 range hydrostatic, 1984Yanmar 4220 12F /4R Powershift & FEL, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 6 foot bush hog, 7 foot bush hog, 6 foot box blade, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using. |
02-07-2012, 08:50 AM
#5 (permalink)
| | Gold Member
| Re: $1500 budget what to buy ? I appreciate everyone's comments. The type of welding I need to do is just around my shop type, "home use". Really what I would like to have is a plasma cutter and a stick machine. So would I be better off just buying a plasma cutter separate and getting a stick machine ? I have a wire feed Hobart and its been great for small jobs, I want to able to cut and build with steel upto 1/2 inch. My next project is a enclosed cab for my tractor,
So what brand plasma ? I would buy a Hobart again in a minute if recommended.
So tombstone and plasma cutter.. Would this be a good choice.
02-07-2012, 08:59 AM
#6 (permalink)
| | Veteran Member
| Re: $1500 budget what to buy ? Quote:
Originally Posted by Jamming I appreciate everyone's comments. The type of welding I need to do is just around my shop type, "home use". Really what I would like to have is a plasma cutter and a stick machine. So would I be better off just buying a plasma cutter separate and getting a stick machine ? I have a wire feed Hobart and its been great for small jobs, I want to able to cut and build with steel upto 1/2 inch. My next project is a enclosed cab for my tractor,
So tombstone and plasma cutter.. Would this be a good choice. | I would stay away from a tombstone. The stepped amperage is a huge pain. I have got the longevity stickweld 250, and love it. They are under $500. I would highly recomend it. For plasma, it comes down to how much you want to spend. If you want to spend $1500, get a hypertherm, and you will have the best. If you dont, I would look at longevity. I have never used a plasma, but with how good the longevity customer service is, and how good the product I have tried is, the plasma would likely be perfct for a hobbiest.
__________________ "If the women don't find you handsome, they should at least find you handy" - Red Green |
#7 (permalink)
| | Gold Member
02-07-2012, 09:07 AM
#8 (permalink)
| | Gold Member
| Re: $1500 budget what to buy ? For a stick welder I would recommend a Hobart Stickmate LX 235 AC/160 DC. I have one and have been pleased with it. I do not have a plasma (yet). Hobart Stickmate LX 235 AC/160 DC Stick Welder - 3837309 | Tractor Supply Company
__________________ Chris
NH TD5030, 861 Ford Powermaster, 555 Ford backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800 |
02-07-2012, 09:10 AM
#9 (permalink)
| | Veteran Member
Originally Posted by Jamming | Overpriced IMO. That is the same price as a hypertherm powermax 45, which is a much better quality machine, and cuts thicker. Plus the hypertherms are made in NH. One of those would blow your whole budget though. I would probably get the hypertherm, and save another $400 and get a longevity stickweld 250.
02-07-2012, 09:12 AM
#10 (permalink)
| | Veteran Member
| Re: $1500 budget what to buy ? Heres a link to the longevity stick welder I have. Costs less then a hobart stickmate, and is more powerful, and has better arc control. StickWeld 250 | IGBT 250AMP E6010 DC STICK WELDER 60% Duty Cycle
