Thinking about getting myself a welder, but...
   / Thinking about getting myself a welder, but... #11
The other day I took a draft arm clevis from my 7-Iron deck to a shop to have rewelded, they told me it took them about 20 minutes and it cost me $25 for the work. I thought that rate of $75 an hour was more than fair as I have priced welding equipment and that shop is a fair sized place with a lot of overhead.
Have long dreamed about buying a smaller MIG welder, one that can be operated on 115 volts...which would cost me about $400-450. Then I have to buy an auto-darkening helmet and leather gloves, plus the expense of a bottle of gas. In the 23 years I have lived in the country, the experience with the clevis was only the second time I needed to to have welding done, and although there are probably a few times I COULD have used a welder to fix or create something.
How many of the members here can actually justify the expense of their welding equipment, has it paid for itself yet? Or is it basically something you just wanted because you needed it once in a while, never mind the cost? Thanks for your input.
I have a $400 Hobart Stickmate LX AC/DC stick welder that paid for itself at least 10 times over in the 5 years I've had it. It gives you immense freedom to design and construct new stuff and to repair almost anything you encounter. ONe of these days I might even take a whack at MIG and TIG.
I would at least consider a 110/220 stick machine. 110 won't get you very far... I've got a 110 FC mig welder and I can't weld anything thicker than 1/8" with it. YMMV but I'd try to listen to Shield Arc. He is humble but is one of the most knowledgeable and helpful people you could find on here.
I have been reading many of the threads here, agree that Shield Arc is very helpful and a wealth of information. My broken Deere deck clevis was 1/4 inch and that would be the thickest material I forsee the need to work with, and that is well within the capabilities of a 150 amp 110 volt MIG. The issue of having to run 220 to my garage 150 feet away is the main reason I want to avoid that voltage. I would be running new wiring under an existing ten foot deep concrete patio, then under an 8 foot wide concrete driveway, and then under a 20 foot deep garage pad. It's not like I can simply dig a trench and run the new wiring.
   / Thinking about getting myself a welder, but... #13
Two of the items I have built using my SP135 Lincoln using .035 fluxcore . Sure it is not the fastest welding when in a high range with limited duty cycle , but then neither am I . :thumbsup:
The ripper use to be a single gang old disk , the curved metal was there as was the some of the frame . Will have to look for the pictures of the boulders and 8" cement drain pipe that I yanked out of the ground .
Fred H.
   / Thinking about getting myself a welder, but... #14
i'm assuming the garage at 150 feet away already has 120v power, or are you planning on running an extension cord to use the planned welder? either way, you may be close on the power you have out there already. a 120v welder will probably only have a 20% duty cycle when drawing maximum power, but you may still find yourself heating up the supply line pretty well due to that long distance. if you ever do have a new line run to the garage, plan ahead and spend the extra on heavy wiring for future use. the labor is the same to lay one run of 12-2 as it is to lay three stands of 1/0 and a #2 ground.
many people on here like stick welders and consider them more versatile because they can weld thicker material at a cheaper initial cost. i actually consider them to be far less useful because they don't deal well with material less than 1/8" thick, and they don't leave the clean finish of mig. if you have heavy equipment then that's one thing, but i own all sorts of things made out of metal - dump truck, equipment trailer, farm implements, etc. and probably 95% of the material is under 1/4" thick.
i got by with an older 120v flux core welder for years, and it only had a 110a rating, but i managed to find ways to effectively weld everything i needed up to 1/2" by either leaving a gap or beveling the edges, or both. 1/4" is a good guideline for what can be easily welded with most 120v welders though. i now have a slightly larger unit (miller 211) and I use it for everything. i have only turned the stick unit on for an aluminum repair (tig) in the last year. i will need to use it soon though, for a cast iron repair.
as far as paying for themselves... well, if you buy a used / inexpensive welder you can probably financially justify it easily, but a larger one will likely take many years. as another poster noted: how much does a flat screen cost compared to its return? leather interior upgrades in a car, a cruise that is over in two weeks, ski lift tickets, golf memberships, and the list goes on and on... it's all a matter of what is important to you and your family. i work a desk job most of the time, and often when i work i end up doing 10-12 hour stress filled days, so the welders, mill, lathe, automotive tools, finished workshop, and so on are like having a vacation every time i come home.
   / Thinking about getting myself a welder, but... #15
smaller MIG welder, one that can be operated on 115 volts...which would cost me about $400-450. .
small 115v mig for 450$?
you can get one about 300$ cheaper, name brand...
I'd avoid a 115v welder, and get a 220v stick if nothing else.
soundguy
Garage is wired directly from house panel, have no problems running 20 amps, have one big air compressor that draws that much and it has never tripped a breaker.
   / Thinking about getting myself a welder, but... #17
OK, here comes my 2 cents.
A stick welder is much, much less expensive to buy and operate. There is not very much maintenance compared to a wire-feed. No gas bottles, liners, tips to replace, mechanical things going wrong, etc., etc.
Stick is very versatile for many farm welding tasks, including hardfacing. The little 200A inverter welders are light and do an excellent job even on heavy, thick metals.
110V welding is virtually useless on a farm. Running 220V to your shop should not be that much more expensive than running 110V wire. That leaves open the possibility of a decent air compressor, plasma cutter, wood saws, air conditioning :)D) and many other 220V tools. OK, so I'm dreaming a bit but if you don't wire it with 220V initially it will cost you much more later when your needs expand - and they will.
Several of the responders on here have the Everlast Power Arc 200 which is simple, runs excellent beads, is versitile, lightweight, and can be had for less than $300 with the TBN discount.
   / Thinking about getting myself a welder, but... #18
Well everyone has an opinion. :)
since you are limited to 120volts at 20 amps. have you considered the Everlast PA140 which will do 100 amps output on 120volts. It is cheap, AND comes with a TIG torch if you want to TIG for light metals later. So you can weld stick and learn that process now, and then invest in regulator (26 bucks) and argon bottle ( varies by region) later when you need to do sheetmetal work. TIG is not as fast as MIG and requires much more practice, but it is a good thing to know. You can fix a lot of stuff with a 3/32 rod and 100 amps or less. I have the PA160 and it is all the stick welder I need. Or you can invest in a Mig and enjoy that too:)
James K0UA
   / Thinking about getting myself a welder, but... #19
Nothing gets you into welding cheaper than a stick welder. Really the only thing a decent stick welder will not do well is weld steel thinner than say 1/16" (e.g. body panels and exhaust pipe type stuff). For thicker type steel, welding outside, or welding on dirty rusty metals the stick unit will actually be better than a cheap mig.
Do not get me wrong mig is probably the easiest to use, but even a cheap mig cost quite a bit to buy, and the consumables really add up over time. Certainly worth it if you weld lots of thin metal, but an expensive luxury to a hobbyist like me. (actually I wish I had never bought my Mig even though it is a good unit. I simply just have more invested in it than I will ever get back in return from use benefit or even resale value).
My AC/DC buzzbox stick welder on the other hand will only leave my arsenal when I die. To me my stick welder is a much more versatile tool than the 1-trick pony mig welder for a crude backyard shop.
a) I obviously weld with it (with zero consumables except electricity).
b) Also provides a nearly free source of intense heat via Twin Carbon Arc torch for bending metal, freeing rusted nuts, brazing, sliver soldering, etc. (Unfortunately the new Inverters will not allow you to utilize this benefit. You must have an older transformer based welder).
c) Also I can cut crudley with it too by sticking 6011 (or cutting electrodes) in the stinger and cranking up the amps - not plasma quality but works and does it cheaply.
d) Can also power a scratch start tig torch too.
My recommendations for you would be any of :
a) $75-$125 on used market will get you into an AC only buzzbox such as a Lincoln, Miller, Hobart, etc. You will need 220 volt to power one of these but you can use 10 gage extension cord out to 95' feet or so without issue - dryer plug or stove plug in the house. (welder will last for your grandkids to be using and if you ever decide to sell you will get all your investment back).
b) Better Yet: $150-$225 on used market will get you into an even better option of an AC/DC buzzbox similar to above. DC is slightly easier to use over AC and is a must have if you ever want to add a tig torch. (Again you will need 220, but still operatable with an extension cord. AC/DC may not last quite as many decades as an AC only unit, but still very durable. If you sell you will get 100% of your investment back).
c) Last Resort: $150-$225 Since you have zero interest in running better power to your shed and if an extension cord is not practical for you to temporary have 220 available then I would try one of the dual voltage inverters from either Everlast of Longetivity. It will be limited on on 110, but just might surprise you with some decent welding capability although you defintiely will not be doing any "Twin Carbon Arc" free heat or improvised cutting with these units. They are DC only and do come with a tig torch though. (As for how long it will last - there is lots of conflicting info on that but you do get a 5yr warranty).
FWIW: Before you disregard the extension cord idea for gaining 220: I do all of my welding outdoors since my shed is overfull and welding/grinding is a dirty messy process and I do not want the mess or risk of fire in my barn.
   / Thinking about getting myself a welder, but... #20
I made a living being a fabricator after a restoration business. I"ll never not have a welder. It has allowed me to build all kinds of things from scratch...
built this quad trailer from an old pop up camper frame about 15 years ago..
built this one all out of scrap...I built it to haul 15K....
I could go on for days... a 220V smaller mig like a lincoln 180-190 is an ideal choice for a homeowner/small shop owner. With flux core wire (no gas) will allow you to weld thicker (1/4-3/8")stuff relatively easily
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
5' MOWER (A52706)
5' MOWER (A52706)
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
