hardfacing
   / hardfacing #21
what did you run for gas, volts and feed rate?
   / hardfacing
No gas was needed with this particular wire. I set the amperage setting on my Red-I-Arc ZR8 (basically a Lincoln Ranger) to 8, the wire speed on my Lincoln LN-25 to 175 in/min, the voltage was 25 volts.
   / hardfacing
Yellowhair42 said:
I've done lots of hardfacing with that exact same wire.Horizontal position and probably five or more 25# spools.Some were partially used.I used full leather gear.Lots of drips and splatter found any exposed holes.Most of them were the tounge of my shoes.Pretty much like running regular flux core but very sensitive to wire feed issues.Not too much roller pressure,new liner,keep cable straight and new contact tip.
I spent $8.50 on a pair of leather boot covers to keep the spatter out of my boot tongues (thanks btw) and I wore a full leather apron. In those 6 hours of welding I only had one spatter that got me and left a burn on my arm. I used a new liner, rollers, and contact tip. Since it is recommended to run with 1" of electrode stick out the tip still looks like new.
   / hardfacing #24
I did that job today, that 60-O wire was awesome. I went ahead did it horizontally on the machine, I was surprised by how little it popped or spattered. It was 6 hours of welding like I expected it to be. I wish my camera was working so I could have taken pictures.
How much water did you go through in the 6 hours?
RC
   / hardfacing
I drank at least 4 bottles, I tried to stay hydrated, luckily it wasn't too hot that day.
   / hardfacing
Stoked that I'm doing this job again on Monday. Since I already have the wire and everything else, my only expenses will be a couple twisted wire brush cups for my side grinder and the gasoline for my welder/generator. I will definitely take pictures this time.
   / hardfacing
Here are the pics I promised.
The machine is a Ditch Witch RT115
The third pic is of the wheel before I re-hardfaced it. Obviously the last pic is after.
It takes me about 10 minutes per side, per section, and there are 12 sections. So 4 hours of welding plus cleaning it up so I'm not trying to weld sand.
   / hardfacing #28
Hey...that is the kind of machine I use to floss. :laughing:
   / hardfacing #29
Nice job! Thanks for posting the pictures!:thumbsup:
Those carbide teeth sure bring back memories, I've been on several drilling jobs where there were 55-gallon drums full of those things. I've seen more knock down drag out fights over which way to angle them.:laughing:
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
