Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
  1. #11
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,841
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Default Re: MIG vertical up trouble
    Haven't had a chance to try it, and it will be a few days yet until I do... I appreciate the tips.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  2. #12
    Gold Member burnieman's Avatar
    Join Date
    Feb 2012
    Posts
    484
    Trinity County California
    John Deere 955 With 70a Loader and 7 backhoe, John Deere 110 Backhoe
    Default
    Keep your puddle. Move back and forth but keep that puddle. It's like anything. Keep practicing. You'll look back at that piece of scrap you started on and laugh. As we are now. Not really. But it will come to you
  3. #13
    Join Date
    Jun 2011
    Posts
    599
    kubota L4400
    Default
    This was only a quick run that I made while trying out a new machine, but my pattern was gun slight angle up, and quick tight ovals. Give it a try, it may work good for you. Hope it helps you bud!
    MIG vertical up trouble-forumrunner_20120618_074622-png
  4. #14
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    In all the years I've been welding, I have never been satisfied with my vertical up welding!
    Attached Thumbnails Attached Thumbnails MIG vertical up trouble-weld-jpg   MIG vertical up trouble-vert-2-jpg   MIG vertical up trouble-v1-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  5. #15
    Veteran Member tungularafishcamp's Avatar
    Join Date
    Sep 2010
    Posts
    1,584
    kodiak island, Alaska
    kubota L2800, 1/2 of a L48
    Quote Originally Posted by Shield Arc View Post
    LOL I would be happy with those welds even on the flat
    Rick
  6. #16
    Join Date
    Aug 2010
    Posts
    157
    Norman, OK
    Mahindra 3316HST
    Whoa, whoa! I never run Mig down hill, unless it is 10-GA or less. Run Mig down hill on a structural job and you'll be kicking rocks to the parking lot while carrying your lunch box!!!!!!!!!!!!
    SA, I'm not doubting you, but everything I've heard elsewhere says otherwise. Matter of fact, I'm in a class right now, and we discussed this (including a video) just yesterday, and everything was vertical down. You clearly have experience I'll never even dream of, so I have to ask: why the difference? What am I missing here?
  7. #17
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    The main reason is penetration. I'd say 90 to 95% of the things I've welded I had to follow a WPS, (Weld Procedure Specification) or a Prequalified Welding Procedure. The majority of them were AWS D1.1 code. When I worked in a tank shop everything was ASME boiler and pressure vessel code. I have yet to see one that doesn't have a line item of: "Welding Progression". I have yet to see one that would allow you to weld down hill on anything thicker than 10-GA. But this is my limited experience.
    One time in the early 1980s I was in a welding crew that we sheeted a 80' x 80' building 70' tall out of 4' x 8' x 10-GA sheets. All welding was done with Mig .030 wire. All joints were gapped 1/16", all vertical welds were made up hill.
    Attached Thumbnails Attached Thumbnails MIG vertical up trouble-wps-jpg   MIG vertical up trouble-pre-joint-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #18
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    2,273
    South GA
    Quote Originally Posted by OkieDave View Post
    If they are teaching you to do vertical down, they are prepping you to go weld and zip together a bunch of cheap built tag-a-long trailers somewhere. Otherwise it is vert up for anything over 1/8"-3/16"...and at that full penetration is doubtful on 3/16".
    SA is 100% correct. With his "limited" experience, he sure hits it right on the head.
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  9. #19
    Gold Member rcowan's Avatar
    Join Date
    Jul 2008
    Posts
    261
    SE Arizona
    Montana 2740M
    Our instructor made us do vert up just for practice. He said anyone can weld vert down.
    RC
    The problem with Socialism is that you eventually run out of the other guys money.
  10. #20
    Join Date
    Apr 2010
    Posts
    2,841
    W Wisc
    OK, Time to revive this. I haven't had a lot of time to practice welding the past couple months, but today I had a free day and nothing to do, and it occurred to me I needed to get back to this. So I looked over this thread and tried a few things. Executive summary: There must be some catch to this that I am not getting.
    I grabbed a couple scrap cutoffs of 3/8" angle to use as practice. I figured I would weld in the corner like a fillet. I tried all manner of the suggestions on this thread. There was only one time I said to myself that it didn't look like total sh!t. The root problem is the same as earlier - the weld pool metal drips. Here is a small 3/8" fillet coupon I did for some comparison after some other practice. I did 3 different welds on this to compare - flat position, Vertical down, and vertical up. Pictures don't seem to be as good as looking at it live, but the flat and V Down looked pretty similar. The V up was one of the best ones I did, and I would still say it looks like crap.
    MIG vertical up trouble-vertical_test-1-medium-jpg
    You can see the conditions on the coupon - about 420 ipm, 150A or so (I don't think to look at the display much), and 23v with 035 wire. These figures are right off the Miller "calculator" I have.
    Here is a better example of the crap I was still getting:
    MIG vertical up trouble-vertical_test-2-medium-jpg
    Note the section of Vert up at the top (drip, drip, drip) and the Vert down at the bottom (smooth but not well tied-in, in this case, especially on the left)
    I tried a few things here in Vert up. Gun angle - I kept it perpendicular (0 deg) and about 15-20 pointed up. I had slightly better success with 0, but not much. I did some major work on wire feed at the same voltage. The charts recommend 23-24v, 420-520 ipm for 035 wire on 75/25 gas. I tried that, and then dialed the wire down to 250-300 ipm also. I got better looking welds at the low speeds, but it did not sound like normal MIG welding. I'd be concerned it was cold, but I can't be sure.
    I'm sure my technique is the fault, but I have no idea what to change after all this. I have tried everything that has been suggested and everything I can think of from what I know. Nothing looks good enough to pass in my vertical ups at this point. Open for suggestions, but not sure how much help I can get without it being in-person at this stage...
    -Dave
Similar Threads
  1. Replies: 1
    Last Post: 06-11-2012, 06:30 PM
  2. Vertical uphill w/Mig
    By Shield Arc in forum Welding
    Last Post: 03-14-2012, 09:26 AM
  3. 7710 fuel gauge trouble (need help trouble shooting problem)
    By pharmvet in forum New Holland Owning/Operating
    Last Post: 01-27-2011, 02:47 PM
  4. Vertical Exhaust
    By greene acres guy in forum Customization
    Last Post: 08-01-2010, 09:48 PM
  5. VERTICAL EXHUAST?
    By dirtworksequip in forum John Deere Owning/Operating
    Last Post: 08-02-2006, 04:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
