Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Oct 2011
    Posts
    1,829
    Monrovia, California
    Kubota BX25
    Default Lincoln IDEALARC TIG 300/300
    Welders can I ask about this machine. Is it good bad ugly awesome or trash?
    I need to look up spec's I guess, I will be needin' it to plug into 220 Single Phase.
    I have 3 Millers w/ the biggest a VINTAGE machine, I so want to learn TIG.
    Thanx in advance for your comments...
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Apr 2011
    Posts
    646
    cx70,5510,4630,5005
    Default Re: Lincoln IDEALARC TIG 300/300
    i have welded with one many years ago.if it works it should weld.the newer ones have more more options.it is heavy ,should need 100 to 150 amp single phase breaker.
  4. #3
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,780
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Someone was just asking me about them in a PM. I know I've used them, but can't remember a whole lot about them. I know they are bullet proof! And Lincoln must have made a million of them.
    One thing you can count on, is a Christmas card from your power company every year.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  5. #4
    Join Date
    Oct 2011
    Posts
    1,829
    Kubota BX25
    Oh Man! I have read several places now where guys say they SUCK energy BIGTIME!
    Here is the deal, I can pick one up for $500.00 and I believe that is w/ all bells and
    whisltes less tank...I have seen where others think that is a fair price and others say
    I will pay more in electricity then what a newer Machine will cost in short order.
    So for 500 is it a steal or a deal or................................?
    Regards,
    Artisan
  6. #5
    Gold Member
    Join Date
    May 2007
    Posts
    432
    SW OH - near Dayton, OH
    Kubota L285
    Bullit proof machine. $500 is a steal if all the bells and whistles like you say. Lincoln still sells a new Idealarc model- price the machine alone. Do make sure it is single phase and not a 3-phase unit.
    As far as electricity, you will need 100 amp service to it. It will use some power yes, but electricity is reasonably cheap even in these times. Modern Welders of similar amp output might be 20% to 25% more efficient so it would take a casual homeowner type user DECADES to see any energy savings. Zero chance the modern welder will have the reliability of this machine.
    Businesses on the other hand that run their welders to capacity everyday 24 hours/7 days a week are about the only ones who can quickly realize energy savings.
  7. #6
    Join Date
    May 2005
    Posts
    986
    N. E. Florida
    If you are needing a lawn ornament buy it!
    I got a deal on one that even had the water tank under it and wheels. It was a 1978 model. I found that it had a bad board in it. I emailed Lincoln and was told machine was obsolete, no parts available!
    I talked to local repair guy who told me something about a small transformer on top of a large transformer circuit that always used excessive power. He said they were a dog.
  8. #7
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,944
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Make sure it is single phase before you buy it...
    You can probably get away with running it on a smaller service than the 100A rankrank noted, if you do not intend to use the full machine power, or perhaps for some initial trials, etc. 300A is a lot of TIG amps for hobbyists...
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  9. #8
    Join Date
    Jan 2009
    Posts
    2,780
    John Deere, 4200
    Quote Originally Posted by Artisan View Post
    If it comes with water cooled torch, foot pedal, flow meter, hose, and any kind of lead. I'd say that is a good price. I see them go for $800.00 to $1,000.00 all the time. Can you weld with it before buying? Never heard of Lincoln having problems with their high frequency capacitors, but the older Millers did! See if you can open the machine up and look for the capacitors. Here is a pictures of the high frequency capacitors for a Miller, (blue arrows).
    Remember now this is a bare bones Tig machine! You won't have the control over the puddle you'd have with an inverter.
    Attached Thumbnails Attached Thumbnails Lincoln IDEALARC TIG 300/300-high-freq.jpg
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  10. #9
    Platinum Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    918
    Ontario Canada
    Default
    Keep looking!
    ericher69
    IAFF Local 849
  11. #10
    Join Date
    Oct 2011
    Posts
    1,829
    Kubota BX25
    I am getting cold feet. I see it weighs like 890#'s and it is huge.
    That means once I plant it, it stays and I do not like that. I am
    leaning on passing on it and saving my pennies for a Miller. Heck
    I have 3 Millers now, no TIG. Can I TIG weld? I have never, Can I?
    Looks like somehing I will be able to do.
    Regards,
    Artisan
Similar Threads
  1. Replies: 6
    Last Post: 11-27-2011, 06:46 PM
  2. Lincoln IdealArc 250
    By 56FordGuy in forum Welding
    Last Post: 03-16-2011, 03:32 PM
  3. Lincoln Idealarc 250 value
    By sacsr in forum Welding
    Last Post: 02-24-2011, 07:53 AM
  4. Lincoln IdealArc AC-250
    By BloomingtonMike in forum Build-It Yourself
    Last Post: 03-04-2006, 08:51 PM
  5. new 300?
    By TimberXX in forum John Deere Buying/Pricing
    Last Post: 02-26-2005, 04:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
