Results 151 to 160 of 267
10-09-2012, 08:43 PM #151Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
10-09-2012, 08:46 PM #152Veteran Member
- Join Date
- May 2012
- Posts
- 2,237
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
10-09-2012, 08:48 PM #153Veteran Member
- Join Date
- May 2012
- Posts
- 2,237
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Re: Thoughts on this used welder?
Also: I thought the whole point of DC welding was that the voltage didn't pass through zero 60 times a second. But the image above shows the rectified DC hitting zero just as often as AC--just not ever going negative.
10-09-2012, 08:57 PM #154Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
Thats unloaded output. Put a heavy load on it and the inductance of the choke (coil) will keep the Current going. Kinda works like flywheel.
Originally Posted by joshuabardwell
Plus, the Voltage waveform and the Current waveform won't be in sync.
Isn't AC fun? You should see all the math that goes with it.Dan H.
10-09-2012, 09:08 PM #155Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
That's what happens with an un-filtered, un-regulated supply.
The meter is reading the peaks of the un-filtered DC. But those peaks are narrow so they can't provide much current. Under load, they flatten out.Dan H.
10-09-2012, 10:13 PM #156Veteran Member
- Join Date
- May 2012
- Posts
- 2,237
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Fascinating.
I'm confused though. The welder ought to be able to provide up to its rated 140 amps when welding, right? Does that not count as "under load"? Maybe not, since welding basically creates a short between the rod and the work piece.
Sounds like you're saying nothing is very anomalous about my readings. Yes?
10-10-2012, 12:42 PM #157Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
You are right, it should be able to provide rated amps, but not at the OCV. Usualy they are rated at 25 volts.
Can't figure whats going on with the super low volts at startup though.
Check all the connections on the DC side of the diodes. I still think something simple is out of whack.Dan H.
10-10-2012, 03:30 PM #158Veteran Member
- Join Date
- May 2012
- Posts
- 2,237
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Just to reiterate, the super-low volts are the AC volts, not DC. As far as I can tell, we have concluded that the AC voltage is just the result of the non-regulated rectified DC, and so it is not a problem or worthy of further investigation.
If the welder is rated at 25 volts, then I believe everything is nominal, since it drops to 27 volts with the bulb in circuit. What it seems we are shaping up to is that voltage is correct and the diodes test out good, but something in the circuitry is preventing delivery of full amps when welding. Someone made a suggestion to stick a rod on max output for ten seconds, then un-plug the welder (for safety) and look for a spot inside the welder that is hot. I think that may be the next step.
10-10-2012, 04:22 PM #159Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
I've done that on cars that wouldn't start due to a bad connection.
Have the welder all opened up so you can get to all the suspect connections quickly.Dan H.
10-11-2012, 07:52 PM #160Veteran Member
- Join Date
- May 2012
- Posts
- 2,237
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Well, I made something useful today!
I had some hooks from some ratchet straps that had to be retired, so I put some screw threads on them so they could screw into the wall and hang tools from and such.
Don't bother critiquing the welds. They are total crap and I know it. But I twisted and pulled on them and they didn't wiggle, so I think they'll do.
BTW: AC 1/8" E6011 at about 120-130 amps.
Similar Threads
Which Stick Welder for a New Welder?
By Cacinok in forum WeldingReplies: 125Last Post: 11-16-2011, 05:20 PM -
Use of a welder/generator as only welder
By HCJtractor in forum WeldingReplies: 20Last Post: 06-13-2011, 03:23 PM -
Any thoughts on this welder?
By arrow in forum Parts/RepairsReplies: 30Last Post: 12-02-2008, 09:47 AM -
Thoughts on buying an old Airco welder?
By Bill_C in forum Build-It YourselfReplies: 9Last Post: 05-07-2006, 10:38 PM -
Mig welder versus stick welder
By mygoatboy in forum Build-It YourselfReplies: 37Last Post: 11-14-2005, 12:04 AM
