Page 17 of 27 FirstFirst ... 714151617181920 ... LastLast
Results 161 to 170 of 268
  1. #161
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,356
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Thoughts on this used welder?
    Quote Originally Posted by joshuabardwell View Post
    Well, I made something useful today!
    Attachment 284385
    I had some hooks from some ratchet straps that had to be retired, so I put some screw threads on them so they could screw into the wall and hang tools from and such.
    Don't bother critiquing the welds. They are total crap and I know it. But I twisted and pulled on them and they didn't wiggle, so I think they'll do.
    BTW: AC 1/8" E6011 at about 120-130 amps.
    Hey it is a start, and you made something useful.. you should be proud... heck I am.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #162
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,089
    Port Orchard, WA.
    John Deere, 4200
    At this stage, that is all that matters!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #163
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by k0ua View Post
    I think I would have done better with a smaller-diameter rod and if I had removed all of the plastic from the hooks, instead of just the plastic where I was going to weld (for better grounding). I think with a smaller diameter rod, I could have kind of worked around the base of the screw a little. As it was, I just sort of globbed on from both sides.
  4. #164
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by CNC Dan View Post
    I've done that on cars that wouldn't start due to a bad connection.
    Have the welder all opened up so you can get to all the suspect connections quickly.
    Well, I gave it a go with the old IR thermometer, and nothing really useful came from it. I mean, some parts were warmer than other parts, over maybe a ten degree range, but nothing jumped out. I am kind of fed up and I think I am just going to focus on AC practice for a while.
    I can't decide if the next step in troubleshooting the DC, when I get around to it, should be to start pulling the DC side apart and looking for corroded connections or heat marks to indicate a bad connection, or whether I should roll the dice that, if anything has failed, it's probably the diodes (no matter what the diode test says) and just buy four new diodes and cross my fingers. I could always use this as an excuse to buy an amp clamp and track through the circuit path looking for where the current flow drops out, but that'd nearly be as expensive as just buying the new diodes.
    Or, heaven forbid, take it to a welding shop and see what it will cost to get it fixed.
  5. #165
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    I can't decide if the next step in troubleshooting the DC, when I get around to it, should be to start pulling the DC side apart and looking for corroded connections or heat marks to indicate a bad connection, or whether I should roll the dice that, if anything has failed, it's probably the diodes (no matter what the diode test says) and just buy four new diodes and cross my fingers. Or, heaven forbid, take it to a welding shop and see what it will cost to get it fixed.
    I would disconnect, clean, re-connect, any and all terminals in the DC section. If no joy, then go for the diodes.
    Note: sometimes diodes in welders are of two kinds. One has the cathode at the stud, the other has the anode at the stud. You will need two of each. Save some $ and get them from a electronics supply, or surplus place. Just needs to meet minimum volts and amps. More is better. And a good thermal connection to the heat sink they are bolted to is important too.
    Dan H.
  6. #166
    Bronze Member terraformer's Avatar
    Join Date
    Jul 2010
    Posts
    87
    N.E. Mo
    Mahindra 3510, Bolens G192/Iseki 1910
    When I weld with my Miller 225 thunderbolt on DC and use 1/8" 6011 I have it turned up all the way, 140A.
    I have a bunch of 7014 in 3/32" and they weld well at about 90 amps.
  7. #167
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Wait a sec. Wasn't there a fifth loose diode or something?
    Could someone else have replaced the diodes in the wrong way(lookup bridge rectifier)?
    Can you put a load on the welders DC output (two car headlights in series?), then measure the volts across each connection. A good connection should read near 0 volts.
    Don't forget the lead sockets.
    Dan H.
  8. #168
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Not sure what you're getting at, Dan. I have used a 12 volt battery and a tail-light along with my multimeter's diode test function to test the individual diodes. They checked out good.
    For someone to have replaced the diode the wrong way, they would have had to order a wrong-polarity diode and replace it. There's only one way to put in the type of diodes that are in here. They have a barrel that bolts to the aluminum plate and a lead that is soldered to a piece of wire. You couldn't reverse them if you wanted to. But, honestly, to my eye, it all looks original. The solder on the diode leads looks factory to me, and all the diodes are the same model number and match the model number that should have shipped with the welder. I suppose it's possible that someone disassembled it and put it back in the wrong order. Not sure how I would track that down, as I am not confident in my ability to translate a wiring diagram to real life. At least not a circuit this complex.
    There isn't a fifth diode that I can see. Four diodes, a choke, and a capacitor.
    You're saying to crank up the welder and put a load between the work clamp and the stinger, then measure voltage where exactly?
  9. #169
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    OK my mistake.
    Any and all connections. Set VOM to read volts, and apply probes to things that _should_ be in good contact with each other. If the connection is good, the meter should show near zero volts. I'm thinking bolt/screw connections.
    Diode to heatsink.
    Heatsink to choke.
    Choke to socket.
    Socket to cable.
    Diode in / diode out.
    Choke in / choke out.
    You're losing power somewhere between the AC output from the main transformer and the output of the DC sockets. I'm starting to think it's got to be a poor connection.
    Dan H.
  10. #170
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    I think I see what you're getting at. But will the loss in power translate to a drop in voltage? Or would I need something that measures current, like an amp clamp? Current = Volts / Resistance, right? So if resistance goes up somewhere in the circuit, current will drop while voltage will remain constant. No?
Similar Threads
  1. Mig welder versus stick welder
    By mygoatboy in forum Build-It Yourself
    Last Post: 10-30-2014, 09:03 PM
  2. Which Stick Welder for a New Welder?
    By Cacinok in forum Welding
    Last Post: 11-16-2011, 05:20 PM
  3. Use of a welder/generator as only welder
    By HCJtractor in forum Welding
    Last Post: 06-13-2011, 03:23 PM
  4. Any thoughts on this welder?
    By arrow in forum Parts/Repairs
    Last Post: 12-02-2008, 09:47 AM
  5. Thoughts on buying an old Airco welder?
    By Bill_C in forum Build-It Yourself
    Last Post: 05-07-2006, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
