Page 2 of 27 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 268
  1. #11
    Gold Member cmore's Avatar
    Join Date
    Jul 2012
    Posts
    261
    nw tn
    traded MF135 for a 2605 4x4
    Default Re: Thoughts on this used welder?
    I would look at one of the flux core welders at Harbor Freight, if cost is important. I use a Weld Pack 100 Lincoln w/flux core. Unless u are trying to weld over 1/4 to 5/16" thick stuff, then would recommend a stick. Its a little harder to learn on a Stick welder than the wire feed. My stick welder has not been used in since I got the flux core, about 20 years back. The 70 amp would be fine for torch but not much of a stick welder.
    Would be nice have some one to help u get started or maybe check the trade schools around u to see if they are going to have a welding course any time soon (TN has several and if they get enough requests, they will set up a course, I took one even tho I was fairly good with the stick welder and to learn more about welding which had changed since the late 50s and early 60s). U can learn on your own, but is easier with some one to help u get started.
    Per the manual specs, it draws up to 20 amps. So if I figured it correctly, a 4500 watt generator to handle it.
  2. #12
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default
    If we assume I'm willing to put in the time and practice, what are the other reasons to choose stick over flux, or vice versa. I've done enough web searching now to know that's a hairy question, but give it a go if you care to.
  3. #13
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,159
    Branson, Mo.
    Kioti DK35se Hydrostat
    I will give it a go, but maybe some more of the pro's will weigh in..I am basically a hobby welder.
    Stick is a little harder to learn, both can weld outside, Stick is more flexible, lots of different electrodes, and can weld different materiel's easily and quickly. Just change sticks.. Less to go wrong with Stick.. No drive rolls, motors, liners, guns. etc.. Flux is easier , Makes pretty good welds, but typically to get good penetration on heavy materiel you need a heavy duty more expensive welder. Both have some downsides, no one process is perfect. (That is why you need to invest in multiple machines like Shield Arc). Some guys like one over the other, for lots of different reasons, they are not right or wrong. I have a nice DC stick machine that I also use to TIG with, it takes care of the larger heavier materiel's and the fine work with the TIG. If I was making something on a repeatable basis, like semi production work, I would have a MIG for inside pretty work and with Flux Core if needed to weld outside.. If I needed to weld Aluminum I would Mig it or get a good Dedicated AC/DC Tig rig. But what I have (Everlast PA160) works well for me. You have to start somewhere.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  4. #14
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    I spent the majority of my welding career running gas less flux core, but it was on 400 + amp machines! Personally, I wouldn't drag a 90-amps flux core welding machine home if it was free.
    You'll get more bang for your buck with a stick welder!
    Here is some welds I did awhile back, after digging my Montgomery Wards welder out of the back of the barn.
    Attached Thumbnails Attached Thumbnails Thoughts on this used welder?-7018-acdc-jpg   Thoughts on this used welder?-7018-dc2-jpg   Thoughts on this used welder?-aaaa3-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  5. #15
    Join Date
    May 2007
    Posts
    704
    SW OH - near Dayton, OH
    1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC
    I believe that I have that exact same 50 amp stick welder. In my opinion it is not a good learner machine at all. For a few dollars more you can get a decent 220 buzzbox.
    Only rods that I can burn on mine is either 1/16" 7014 easy strikes from harbor freight or quick strikes from Menards. I can also run 5/64" 6013 from with it. Thats it and i have tried many other brands and sizes. Forget 3/32 diameters.
    It can do some things even with only 2 rod choices but no way would i pay $65. I paid $8 for mine at a garage sale 15 years ago.
  6. #16
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    One advantage I can think of with flux core (and especially mig) is operatirg cost. Sticks can get expensive, but this really only comes into consideration if you are doing a lot of welding, otherwise it is negligible.
  7. #17
    Join Date
    Apr 2011
    Posts
    746
    cx70,5510,4630,5005
    i would recommend these welders for a beginner.if you get 220 get a miller thunderbolt acdc stick.for a 110 mig i like a lincoln 140 with tapped setting.for your generator you might try a everlast 140 stick on 220. it is easier to learn mig or fluxcore than stick.stick is much better for thicker metal.your wasting your time on a 110 stick machine.
  8. #18
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    Quote Originally Posted by cowski View Post
    100% agree
    My dad had a cheap ac lincoln 220 stick welder. We were trying to do body work with it He even bought some adapter to hold smaller rods and it brought the current even lower. Granted I was even less experienced then, but I found it impossible to try to stick weld with that low of current.
  9. #19
    Join Date
    Apr 2012
    Posts
    733
    Thebes il
    07 kioti dk 45s
    Default
    I would personally buy a stick welder if I was just learning, you need to learn the basics in stick then expand from there. If your just starting out wire feed welders are a pain because you have to deL with birdnesting. Which is a waste of precious time when your already stressed to learn a seemingly difficult skill.but a stick welder is definitely not made for body work.
  10. #20
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Well, guys, I have done a lot of reading about the difference between stick welders and flux-core welders, and bottom line: it seems to me like this Ward AC/DC stick welder is a heck of a deal at that price, whereas I don't see much in the way of flux-core welders in the same price range, never mind the same apparent value-for-money. When I search around, it seems like people are asking $100-150 for AC-only stick welders in similar amp ranges. I checked this evening, and the Ward AC/DC I linked to above is still available a week later, so I bet I can get the guy to take a little less than $100 for it. But even if he sticks at $100, it seems like a real steal and I think I will go for it. What do y'all think?
    I also thought through the 220-volt issue, and I realized that the concrete pad behind my house would probably be perfect for welding. It's flat if I need to square up anything big; it's enclosed on three sides (leads to a daylight basement) so nobody will be inadvertently exposed to the arc; there's nothing flammable nearby, like there is in my barn/wood shop; and best of all, it is RIGHT by the electric meter and main service panel, so if I one day want to put an outdoor-rated 220 receptacle in, there should be absolutely minimal wiring. Maybe I'll have the electrician put in the generator transfer switch while I'm at it...
Similar Threads
  1. Mig welder versus stick welder
    By mygoatboy in forum Build-It Yourself
    Last Post: 10-30-2014, 09:03 PM
  2. Which Stick Welder for a New Welder?
    By Cacinok in forum Welding
    Last Post: 11-16-2011, 05:20 PM
  3. Use of a welder/generator as only welder
    By HCJtractor in forum Welding
    Last Post: 06-13-2011, 03:23 PM
  4. Any thoughts on this welder?
    By arrow in forum Parts/Repairs
    Last Post: 12-02-2008, 09:47 AM
  5. Thoughts on buying an old Airco welder?
    By Bill_C in forum Build-It Yourself
    Last Post: 05-07-2006, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
