Page 24 of 27 FirstFirst ... 1421222324252627 LastLast
Results 231 to 240 of 267
  1. #231
    Join Date
    May 2012
    Posts
    2,355
    Knoxville, TN
    Bobcat CT225
    Default Re: Thoughts on this used welder?
    ... and in case anybody is wondering why I'm using 7014: it was the only 3/32 rod that they had in stock when I went looking for something thinner than 1/8". On 1/8" thick metal, I have some trouble doing butt joints without blowing through if I use 1/8" rod.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #232
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    8,001
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by joshuabardwell View Post
    Nothing wrong with using the 7014,, it is called by some a "drag rod",, in fact if it is running right you can drag it on the workpiece without sticking. Burn it up, and you can try some 7018, 7018 is a little more difficult, and restrikes are difficult, you need to break the "corn" off of the end after you stop welding and before you commence again. You can sling it while it is hot, but I don't like to do that. I usually just let it cool for a few seconds and break it off with my thumb before resuming. On your 7014, it will typically need to be run a little hotter than say 6013 or 6011 for the same size rod. It will make a flatter weld with less of the "stack of dimes" look that 7018 will have. It will be a smooth flatter weld, and only good for flat work. It will lay down more metal faster than say 7018 or 6011 due to the iron in the flux.
    James K0UA
    Last edited by k0ua; 10-23-2012 at 06:57 AM. Reason: I meant to say 7014 not 7018 to run hotter
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks.Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  4. #233
    Join Date
    May 2012
    Posts
    2,355
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by k0ua View Post
    On your 7018, it will typically need to be run a little hotter than say 6013 or 6011 for the same size rod.
    When I bought my start-up welding supplies, I got them from a guy who no longer worked as a welder. Along with the jacket and hood, he gave me maybe 15 lbs of rods, of which, 10 lbs was 1/8" 7018. I have kind of been saving it though, because you're supposed to put it in a rod oven before using it and I don't have one of those. I guess for non-structural, non-code work it probably would work about as good as anything, but I've been holding back on it.
  5. #234
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,780
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Don't get to hung up on that rule! Back when I use to build bridge false work I can't tell you how many times I had to pour water out of a can of 7018 because some carpenter type left the lid of the gang box open when it was raining. Little trick for you, place the 7018 rod in the electrode holder, stick the end of the rod to the work area, do not even try to weld, just let it set there for a few seconds. You can watch the moisture boil out of the rod. Now the rod will be nice and toasty.
    Here is a link to some testing I did with 7018 that was never in a rod oven. In post #3 I state it took in the low 20s to break the same fillet weld with 7018 right out of the oven, it was actually 23 blows.
    http://www.tractorbynet.com/forums/w...reak-test.html
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  6. #235
    Gold Member
    Join Date
    Sep 2012
    Posts
    383
    north shore MA.
    Default
    At my local ACE hardware stoes, they have a small selection of welding rods in 3/32 size.
    Dan H.
  7. #236
    Join Date
    May 2012
    Posts
    2,355
    Knoxville, TN
    Bobcat CT225
    Did some more work on T-joints today. I watched some videos last night and decided one thing I was doing wrong was not pulling the puddle up the vertical face. Rather, I was trying to push the puddle up the vertical face via the rod angle, while moving the rod as if it was a flat weld. I made little diagonal zig-zags, moving the rod forward and up the face, and then backwards and to the flat piece. I also held the rod slightly longer at the top, because that was what the person in the video did. I guess that's supposed to allow more filler metal to pile up at the top of the bead.
    The beads are more evenly distributed between the vertical and horizontal wall than yesterday's. There is a ridiculous amount of slag inclusion and a LOT of undercut at the top of the bead (see detail below).
    All welds were done DCEP 100A 1/8" E6011.
  8. #237
    Join Date
    May 2012
    Posts
    2,355
    Knoxville, TN
    Bobcat CT225
    I did some more T-joints today, and a few lap joints. Just a bunch more junk, of course, but I finished this weld and when I went to strip the slag, the whole thing came off in one big clean strip. I looked at it and I thought, "You know. That looks like a weld." I still have some issue with undercut at the top, and probably a whole lot more issues that I don't even see, but this is probably the best looking joint I've done so far.
    My 7014 is 3/32" instead of 1/8" like my 6011, so it's not apples to apples, but man the 7014 seems to run really nice. The 6011 is really hard to keep the slag out of and to make a nice smooth bead. I should try some of that 7018 I have; I hear it's pretty smooth too.
  9. #238
    Gold Member
    Join Date
    Sep 2012
    Posts
    383
    north shore MA.
    Default
    Thats just the way 6011 goes. Heavy deep ripples. When you try the 7018 you can just let the flux coating rest on the metal. If you have a smart phone, miller makes a weld settings calculator that will give you the range of amps to use for different types of rods.
    Dan H.
  10. #239
    Join Date
    Jan 2009
    Posts
    2,780
    John Deere, 4200
    You're actually coming along pretty good, the last picture of the 7014 weld is really not all that bad for the amount of time you've been welding!
    Here's those calculators Dan is talking about. Remember these are only suggestions, there are so many variables to welding it's mind boggling!
    Miller - Welding Calculators
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  11. #240
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,491
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Click image for larger version.
Name:	2012-10-24 00.13.57.jpg
    So Josh, now that you are welding some with a functioning DC welder, do you notice what we are all talking about with how much better DC welds than AC?
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
Similar Threads
  1. Which Stick Welder for a New Welder?
    By Cacinok in forum Welding
    Last Post: 11-16-2011, 05:20 PM
  2. Use of a welder/generator as only welder
    By HCJtractor in forum Welding
    Last Post: 06-13-2011, 03:23 PM
  3. Any thoughts on this welder?
    By arrow in forum Parts/Repairs
    Last Post: 12-02-2008, 09:47 AM
  4. Thoughts on buying an old Airco welder?
    By Bill_C in forum Build-It Yourself
    Last Post: 05-07-2006, 10:38 PM
  5. Mig welder versus stick welder
    By mygoatboy in forum Build-It Yourself
    Last Post: 11-14-2005, 12:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
