Page 3 of 27 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 268
  1. #21
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,347
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Thoughts on this used welder?
    Quote Originally Posted by joshuabardwell View Post
    Well, guys, I have done a lot of reading about the difference between stick welders and flux-core welders, and bottom line: it seems to me like this Ward AC/DC stick welder is a heck of a deal at that price, whereas I don't see much in the way of flux-core welders in the same price range, never mind the same apparent value-for-money. When I search around, it seems like people are asking $100-150 for AC-only stick welders in similar amp ranges. I checked this evening, and the Ward AC/DC I linked to above is still available a week later, so I bet I can get the guy to take a little less than $100 for it. But even if he sticks at $100, it seems like a real steal and I think I will go for it. What do y'all think?
    I also thought through the 220-volt issue, and I realized that the concrete pad behind my house would probably be perfect for welding. It's flat if I need to square up anything big; it's enclosed on three sides (leads to a daylight basement) so nobody will be inadvertently exposed to the arc; there's nothing flammable nearby, like there is in my barn/wood shop; and best of all, it is RIGHT by the electric meter and main service panel, so if I one day want to put an outdoor-rated 220 receptacle in, there should be absolutely minimal wiring. Maybe I'll have the electrician put in the generator transfer switch while I'm at it...
    I say buy the AC/DC welder, as long as it works, it is a steal at 100. I want more than that for my AC only tombstone. (I don't use it any more after getting my Everlast) Give it a go, and have fun.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #22
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by k0ua View Post
    You want more than that, like, in terms of output? How thick metal are you working with?
  3. #23
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    I welded with an AC only buzz box welder for about 15 years. You will thank yourself a thousand times over for buying the MW AC/DC welder. DC is so much easier to learn with.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #24
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    I think he means that his AC welder is worth more than $100 to him and it is AC only. So he is saying your find is a great deal.
    Randall
    1Timothy Chapter 2:
  5. #25
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by dex3361 View Post
    Oh! I see now.
    Well, cross my fingers it's still around tomorrow when I get back in town. Double-cross my fingers I can talk him into taking $80 for it
  6. #26
    Join Date
    Jun 2009
    Posts
    28,347
    Branson, Mo.
    I meant I want more money than $100 for my AC tombstone (it is for sale).. or in other words. the AC/DC machine you are looking at, is a good value, and a more desirable machine, (because of the DC capability) than my AC only machine. After getting my DC machine I had very little interest in welding any more with my AC only machine.. Sure it will weld, and the more experience you have, you can make pretty good looking welds with it. In my opinion a DC welder is a better start for a beginner than an AC only machine. Of course opinions may vary...but that mine.
    James K0UA
    James K0UA
  7. #27
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    Now you realize that machine is only 140-amps at 20% duty cycle on DC? So this means you're not going to be able to rock & roll with 1/8-inch 7018! 3/32-inch 7018, and 1/8-inch 6010 and 11 yes.
    First thing you're gonna want to do when you get that machine home is take some sand paper to the welding lead male lugs that plug into the welder. Maybe take a battery lug wire brush and clean the female ends in the machine too. And I'd pitch that ground clamp! In time you may want to add on to those welding leads, I always use this type of welding lead connector. I have yet to buy these on line, when you add shipping my local welding supplier is always cheaper!
    1-WPC Tweco Cable Connector No. 9425-1125 - Buyweld.com
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  8. #28
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Well, I bought it! Woo hoo! The story he told is that he got it from a buddy of his thinking to learn to weld but never got around to it. Anyway, I asked him if he could lay down a bead for me, just to see it work, and he said he couldn't. He doesn't even have a 220 outlet. But he said if I get it home and it doesn't work, he'll take it back. Only problem is, I don't have a mask or electrodes yet. So... I dunno... can I just, like, tap the two clamps together like jumper cables and see if there's a spark? Eh. I'll probably go get the other supplies this weekend.
  9. #29
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    I've done that a few times, but not on purpose!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  10. #30
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Question: the welder has a 3-prong 50 amp plug. My generator has a 4-prong twist-lock plug. Adapters are pretty dear, but it looks like the welder's plug would come right off with some screws. Can I just buy a 4-prong twist-lock plug and put it on the end of the cable (keeping the 3-prong for when I eventually get 240 service, of course).
Similar Threads
  1. Mig welder versus stick welder
    By mygoatboy in forum Build-It Yourself
    Last Post: 10-30-2014, 09:03 PM
  2. Which Stick Welder for a New Welder?
    By Cacinok in forum Welding
    Last Post: 11-16-2011, 05:20 PM
  3. Use of a welder/generator as only welder
    By HCJtractor in forum Welding
    Last Post: 06-13-2011, 03:23 PM
  4. Any thoughts on this welder?
    By arrow in forum Parts/Repairs
    Last Post: 12-02-2008, 09:47 AM
  5. Thoughts on buying an old Airco welder?
    By Bill_C in forum Build-It Yourself
    Last Post: 05-07-2006, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
