Page 4 of 27 FirstFirst 123456714 ... LastLast
Results 31 to 40 of 268
  1. #31
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,346
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Thoughts on this used welder?
    Quote Originally Posted by Shield Arc View Post
    I've done that a few times, but not on purpose!
    Agreed... refrain from doing that at all costs.. hey the 50 dollar auto dimming mask from Northern tool is not bad for what it is.. I have one. Granted you can get a non-auto dimming mask for less. BUT.. you will weld SOOO much better and have SO much less frustration with an auto-dimming mask.. as a beginner.
    it is much easier to get the idea of striking an arc, if you can actually see...A lot of real pro's I think still weld with fixed glass hoods, but I ain't no pro.. and neither are you. yet..
    Wel-Bilt Auto-Darkening Welding Helmet | Welding Helmets| Northern Tool + Equipment
    Good luck.
    james K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #32
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    Well I'm not a pro either, and I was against the auto hoods for years. Main reason was the cost of the clear cover lenses, and the few I had tried I didn't like the head gear. But I bought a fixed shade auto lens that fits my hood, I couldn't be happier! Good thing I'm not a pro huh?
    Attached Thumbnails Attached Thumbnails Thoughts on this used welder?-pwingnut-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #33
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by joshuabardwell View Post
    Question: the welder has a 3-prong 50 amp plug. My generator has a 4-prong twist-lock plug. Adapters are pretty dear, but it looks like the welder's plug would come right off with some screws. Can I just buy a 4-prong twist-lock plug and put it on the end of the cable (keeping the 3-prong for when I eventually get 240 service, of course).
    This will work just make sure you trace out which is the ground and which is the neutral. Your welder doesn't use a neutral.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #34
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Thanks everybody for your assistance on this. I'd love to post y'all some pictures of my first crappy beads (because I know TBN's policy on photos) but the welder has cleaned out the last of my spending money for a bit. Before I can weld, I'm gonna have to get a 240 supply that can actually plug into the thing, and I'm gonna have to pick up a helmet and other various accessories. It looks like the "swap out the plug" plan isn't going to work. I found a twist-lock connector, but it only takes up to 8 AWG and the welder, if memory serves, is 5 AGW, so I think I would have to actually build a pigtail adapter, which would run around $50. So pictures and further progress will have to wait, but again, thanks so much for the assistance.
  5. #35
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Just got an estimate from a local electrician of about $150-175 to put a 240 receptacle in next to my meter. It's just a ballpark, as I didn't want him to come out for a proper quote before I was ready to pull the trigger, but at that price, I don't think I'll fuss around with adapters and pigtails. That's only 3x or so the cost of an adapter or pigtail to let me run the welder off my generator--at half capacity no less. Maybe I can get him to put a transfer panel in for my generator while he's messing around back there.
  6. #36
    Join Date
    Jun 2009
    Posts
    28,346
    Branson, Mo.
    Sounds like a good plan to me. I will be looking forward to you relating your experiences once you get a mask, some supplies, and your power supply set up. You have started down a new path, it will be interesting to follow along with you..
    James K0UA
    James K0UA
  7. #37
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Well, today's task is to take the welder down the road where a distant neighbor has a welding/fabrication shop. I'm going to ask him if he wouldn't mind just plugging it in and running a bead with it to make sure it works. I also have a line on a local guy who has a box of leftover supplies after he got out of welding: hood, jacket, gloves, hammer, a few boxes of rods, and some other misc. stuff. He's asking $40, so even if I can't talk him down a little, it's probably worth it. The helmed isn't auto-darkening, but maybe I can change out the glass or something.
  8. #38
    Join Date
    Jun 2009
    Posts
    28,346
    Branson, Mo.
    This sounds like a good idea.. check out the machine and the $40 for the supplies sounds good also.. I welded many years without an auto-darkening helmet, and fixed a lot of things, it is just easier with an AD lens. Also perhaps this person that can check out the welder, can help you a little now and then?
    James K0UA
    James K0UA
  9. #39
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by k0ua View Post
    Yeah. I figure I can always pick up an AD helmet later if I need to. The supplies are probably still worth $40. At least in the beginning, I'm just going to be running beads on scrap, which I suspect is not so critical.
    I'm not sure how to establish a relationship with the guy with the fab shop. I talked to him a bit over the phone once about doing some welding work, and he was kind of short and gruff. That's probably just a phone thing, but I'm not sure I'd feel comfortable asking him for instruction. I'm sure if the price was right, he'd do it though.
  10. #40
    Join Date
    Jun 2009
    Posts
    28,346
    Branson, Mo.
    Well a lot of professional tradesmen can come off as a little gruff at first. Sometimes it is because a lot of people try to take advantage of them, by wanting something they have to offer for free, or a "brother in law" price. See if you can become friends with him, maybe offer to do something for him, or bring donuts, beer or lunch or something.. A lot of times these ole "curmudgeons" can lighten up a lot, once he gets to know you a little better. Sometimes they can get downright friendly, when they see that you are a "giver not just a taker". Good luck on that front, but it is worth trying, as it can take years off of the learning curve to have someone to show you how to do things instead of just having to learn it all on your own.
    Good luck with it all..
    James K0UA
    James K0UA
Similar Threads
  1. Mig welder versus stick welder
    By mygoatboy in forum Build-It Yourself
    Last Post: 10-30-2014, 09:03 PM
  2. Which Stick Welder for a New Welder?
    By Cacinok in forum Welding
    Last Post: 11-16-2011, 05:20 PM
  3. Use of a welder/generator as only welder
    By HCJtractor in forum Welding
    Last Post: 06-13-2011, 03:23 PM
  4. Any thoughts on this welder?
    By arrow in forum Parts/Repairs
    Last Post: 12-02-2008, 09:47 AM
  5. Thoughts on buying an old Airco welder?
    By Bill_C in forum Build-It Yourself
    Last Post: 05-07-2006, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
