OP
joshuabardwell
Elite Member
Well, my neighbor came over and we installed the receptacle today, and I finally got to weld a little bit. Here are the results.
One piece of equipment that I'm lacking is a stiff wire brush, so the slag is not as cleaned off as it could be. Striking the arc was harder than I expected. I kept either pulling away too far or sticking the rod. The non-auto-darkening helmet couldn't be helping with that. I learned another advantage of an auto-darkening helment: if you accidentally touch the work piece and strike an arc before you drop the hood, you will get an eyefull. Oops. It was just the briefest of flashes, as I slammed my eyes shut and pulled the rod away, but woo hoo. I kept seeing that flash for 30 seconds or so. When I went back to weld again, I couldn't figure out why I wasn't seeing the arc. It was because I still had my eyes closed!
The only other time I have had an afterimage like that was when some good ol' boys I know showed me how to use a garbage bag and some oxyacetylene gas to make a bomb. That one lasted way longer than 30 seconds.
EDIT TO ADD: I also wear eyeglasses, which have UV-protective lenses, so that should help to protect against the flash damage. But how much flash does it take to give you flash burn in your eyes? Would a brief one like I experienced do it?
EDIT TO ALSO ADD: Okay, I have wire brushes around the house, yes, but not one of those big stiff ones they use for cleaning welds. Didn't want y'all to get the wrong impression about my tool-cred.
