Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Jul 2004
    Posts
    152
    Western Michigan
    Yanmar 187D Bobcat 743 skid loader w/forks and homebuilt 6-way grader blade
    Default Weld shortened axles?
    How do I weld shortened axles like this? How strong will they be? The attached picture is of a Chevy truck axle that was shortened to make a small tractor. Are those axles case hardened steel? Besides alignment tricks is there anything special about welding these? Thanks
    DonmanWeld shortened axles?-chevy-rear-axle-jpg
    Don
    "The difference between spit and drool is mainly a matter of motovation"
  2. #2
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,021
    Port Orchard, WA.
    John Deere, 4200
    Default Re: Weld shortened axles?
    I can't ever remember doing anything like this before. I would guess you'll need a specialty rod, proper preheat, and post heat. Along with the post heat, it will need to be a controlled step down, most likely over at least a 24-hour period.
    I bet yomax4 or Gary Fowler will be able to help more!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #3
    Join Date
    Jan 2009
    Posts
    6,021
    Port Orchard, WA.
    John Deere, 4200
    Did a little Googleing and came across this.
    Welding: welding a broken axle, spring temper, laser thermometer
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  4. #4
    Elite Member
    Join Date
    Mar 2010
    Posts
    2,631
    Ontario
    CT235
    Axles are usually resplined when they are shortened. Depends on the axle taper if it is at all possible. With the width of that diff, it should be no problem.
    Rear Axle Modifications - Axle-Chop How-To - Car Craft Magazine
    Tim.
  5. #5
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    In the off road TV show I watch they will shorten the axle tubes, but they always buy the custom length axles.
    Dan H.
  6. #6
    Super Member
    Join Date
    Jul 2009
    Posts
    8,579
    SW WA
    Kubota BX2360
    I've seen lots of homemade garden tractors with welded axles. I don't think there is enough power or weight to break a decent weld. Just keep it straight.
    Bruce
  7. #7
    Bronze Member woodsmith's Avatar
    Join Date
    Jun 2010
    Posts
    93
    Manchester UK
    When I do mine the plan was to cut and weld.
    On the Land Rover Salisbury axles I have the axle is splined both ends and there is an internally splined drive member that bolts to the hub at the outer end.
    My plan was to cut the outer end of the axle and bevel it. Then grind out the splines in the drive member and bevel the outer rim.
    The axle will be pressed back into the drive member so that it is the right length and squared up. The beveled end of the axle can then be welded making the outer end of the drive member into a big plug weld. The inside edge will also be welded around where the axle fits into the inside of the drive member.
    I doubt that my electric tractor will produce enough power or torque to bother a welded axle (fingers crossed, after breaking two transaxles!).
    However, I am now thinking of allowing myself a little more width and just using the shorter standard axle shaft on both sides. It will just mean, for the sake of 6" extra width, my tractor won't fit in through my house doors anymore.
    I believe with your American axles there are plenty of places that have axles off the shelf or will respline. So much better and easier.
  8. #8
    Join Date
    Dec 2011
    Posts
    860
    Western Washington USA
    MM UTS and Homemade
    I welded the shortened Chevy axles on my 4wd garden tractor. They're case hardened and very hard on the outside. I used 308-16 stainless rod and a little preheat. I used my old Sears buzz box ac welder. I didn't see any cracks and the axles have not broken. I've had good results using stainless rod on hardened steel like grader blades and axles. I'm not a pro welder, so not an expert.
  9. #9
    Join Date
    Apr 2006
    Posts
    2,164
    western NC
    Ventrac, Steiner
    There used to be a old machinist close by that would weldup bushhog blades. I watched him do it once but I was a youngun and its been 40years ago. I do remember that he had some sort of crayon he would mark the metal with while preheating it. Different color for different temperatures. He used a torch for the heating. He would weld a bit and then heat, weld and heat, until he had it completely welded. Then post heat and quinch in oil and then bury in what I believe was lime, might of just been plain sand, and leave until the next day. Never heard of any of his blades breaking so I guess he knew what he was doing.
  10. #10
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by muddstopper
    There used to be a old machinist close by that would weldup bushhog blades. I do remember that he had some sort of crayon he would mark the metal with while preheating it. Different color for different temperatures.
    Yup. Called tempil sticks.
    Dan H.
Similar Threads
  1. Shortened Joystick to Ease Getting Off-BX
    By bxonthelake in forum Kubota Owning/Operating
    Last Post: 04-20-2014, 04:41 PM
  2. Shortened ROPS - WHY???
    By kebo in forum Safety
    Last Post: 06-30-2010, 11:10 AM
  3. FEL lever - shortened.
    By psvines in forum Kubota Owning/Operating
    Last Post: 02-11-2010, 01:04 PM
  4. AXles?????????
    By hoogy in forum Trailers & Transportation
    Last Post: 03-22-2009, 02:43 PM
  5. 2 or 3 axles?
    By Corm in forum Related Topics
    Last Post: 12-15-2000, 10:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
