Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 96
  1. #31
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: HOW DOES AC WELDING DIFFER FROM DC WELDING
    cutting torch work too.
    He's told me some neat stories. he gets to do fun stuff.
    tanker hull inspections.. open see diving.. salvage and recovery... worked off the coast of texas a while before moving back here to fl...
  2. #32
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    I've worked with lots of divers over the years, on one project I had 8-divers and tenders working for me. We had 2-decompression chambers on board. Deepest dive was 215-feet. But they were on gas, at that depth. Spent most of their day staging up and down. Then hours in the chamber. 3 of the divers had worked in the north sea. Yep great stories they have!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #33
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Nice brother in law.
    If you buy yourself a tig torch set and lease an argon tank you can start learning how to tig weld also.(carbon and stainless)
    You won't have the best arc and heat control but you will have fun.
    you may never want to stick weld again.
    I have several mig welders, stick and tig.
    Just me, I prefer to tig most of the time.
    Congrads on your new welder.
    You need to buy your brother in law a beer.
    Tom
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  4. #34
    Elite Member oldpilgrim's Avatar
    Join Date
    Apr 2014
    Posts
    3,081
    SE Ma
    2014 Mahindra 3016HST
    Quote Originally Posted by Shield Arc View Post
    I didn't see it, but I was on the job not to far away when it happened. At the time there was so much work around here, you couldn't get enough weldors, or welding machines. We were building a big cofferdam with tie backs. The company rented a small engine drive I don't remember what it was, because I didn't want any part of it, I had a brand new Lincoln SAE-400, and no body was getting that thing away from me! Anyway this new hire came out to work, forgot his rain gear at home. In no time at all he was soaking wet. He and another guy had to roll his little welder to another location through the mud, the new hire rolled up his leads on the handle bars, and grabbed both handle. Well I guess the fool grabbed the stinger and ground clamp one in each hand. The guy helping him couldn't hardly stand up straight when telling us the story later! I guess the weldor went to his knees convulsing! Scared the helper! At first he couldn't figure out what was happening! Then he seen the guy was holding the stinger, and ground clamp. The helper reached around and shut the welder off. The weldor was so shaken up he had to go home!
    I was welding at 125 amp Ac, and it was an awful hot humid day. I had to change the ground cLamp positions and left the welder running while I did it. One very sweaty hand on the ground clamp and the rod holder in the other very sweaty hand. There is a hole in the grip of the handle where you can access the set screw that attaches the cable and the handle was also soaking wet with sweat.
    I could feel the current going in one hand, across my chest to the other hand. Everything went dark, I shook violently, it melted my wedding ring, burned my fingers, and caused a spasm in my finger muscles that dislocated a finger. I could not move, let out a loud "aaaaaaaàhhhhhhhhhh", my wife heard me,ran into the garage and flipped off the breaker but not before I fell backwards reaching the length of the cables, pulling them out if my hands
    I fell to the floor unable to talk shaking like crazy for several minutes. I felt a quivering thru me for hours.
    I went to the Dr as my heart seemed to be skipping for several days. He said it would. I've had skipper beats ever since.
    With the current going thru me I couldn't see and kept thinking that I was going to die..
    I since fixed the hole in the handle and do things much differently now.
    Would the same amps with DC have been any different?
    US Army 1967 - 1971
    Freedom used to be your birth right. Now it's whatever they let you do... and usually for a fee.
    Compromise is failure on the installment plan.
    Show me any gun law, past, present or future, that would have prevented any of the mass shootings in this country.
  5. #35
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,328
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by oldpilgrim View Post
    Wow, that didn't sound like much fun. I have never been bitten by a welder, but I have had a few hits from old tube type TV's back when I worked on them. One was near lethal. 330 volts from a supply capable of at least 1/2 an Ampere. The good news was the path was in a finger and out my forearm.. NOT across my chest..Thankfully. It still took a lot of starch out of my 19 year old body. But I believe your NDE (Near Death Experience) sounds about 10 times worse than mine.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  6. #36
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    WOW, oldpilgrim that is a horrible story!
    Working marine construction here is the North West we get hit all the time with DC welders running wire feeders, in the 300 to 400-amp range. Its more of a oh sh!t kind of thing. 30-seconds later you have already forgot about it.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  7. #37
    Veteran Member skyhook's Avatar
    Join Date
    Mar 2013
    Posts
    1,919
    Canada Ontario
    1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
    Here's my understanding ( and I could be wrong ), AC goes from a negative value to a positive value, doing so, it crosses the "zero value" line, making poorer welds than a DC welder which has a "steady" value of current. Expert welders compensate for this constant change in voltage/current drop on AC. Personally, I use my machine on DC only, I like the welds better.
  8. #38
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,994
    Waynesboro Va
    John Deere X310, JD LA 145
    I was working in a shop building stairs and railings. I was welding a couple big pieces of channel together with a DC stick welder and saw a symbol on the prints that I did not know and asked the bosses son what it was. We were leaning on the grounded welding table looking at the prints. I still had the stinger in my hand and he reached up and grabbed me by the front of my shirt and pulled me down closer to the prints. The end of the rod hit him between the shoulder blades and He started side stepping across the shop waving his arms up and down and shouting WOOOOP WOOOOP WOOOP. He did that about 15 feet across the shop and ended up between the pipe bender and a table and started cussing. After a bit he asked "How did I get over here?". That has been over 30 years ago and I bet he has not forgotten it yet, I know I never will. Ed
  9. #39
    Join Date
    Mar 2013
    Posts
    213
    Texas
    Not all the time, but sometimes I can feel the current when I touch the electrode and the grounded table.
  10. #40
    Join Date
    Mar 2013
    Posts
    213
    Texas
    Quote Originally Posted by skyhook View Post
    I thing i read somewhere that it does this 60 times a second and the DC if IIRC is like 60,000 but not sure probably need to look on that
    Everlast PowerARC 300
Similar Threads
  1. Not welding, per se but,
    By handirifle in forum Welding
    Last Post: 02-19-2012, 12:57 PM
  2. Welding
    By AGM in forum Welding
    Last Post: 12-02-2008, 08:49 PM
  3. welding ?
    By Jimbrown in forum Welding
    Last Post: 01-06-2007, 08:08 PM
  4. Welding???
    By wgbiii in forum Welding
    Last Post: 08-07-2006, 08:32 AM
  5. Welding
    By RocketJSquirrel in forum Build-It Yourself
    Last Post: 05-11-2002, 09:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
