Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Join Date
    Dec 2003
    Posts
    94
    Northern VA
    Bobcat CT235
    Default What to weld rebar with for target frame
    I have some 500 Brinell 12" circle steel plates and I'd like to make a target frame for them. I'm thinking of rebar legs to push into the ground with a horizontal piece to press your foot on. Then rebar on the top. I'll either have pipe on the top rebar and weld a tab on the pipe to bolt to the belts holding the plate or just have the belts go over the rebar and back down to the plate.
    What is needed to weld the rebar together? I have zero welding skills and I've looked on my local craigs list and see a few Lincoln 225 for around 200 dollars. I'd have to use the dryer plug to power them but that should be fine. Or I could go cheaper and hit the local Harbor Freight and pickup their Wire Welder, 90 Amp Flux for 109 dollars and then use a 20% coupon. Its 110 volts so it would be easier to power but can it weld rebar for what I need?
    Thanks.
  2. #2
    Gold Member
    Join Date
    Sep 2012
    Posts
    338
    north shore MA.
    Default
    get the 225 amp welder.
    the HF welders are nearly useless.
    they should have DC output, but they are AC. junk junk junk.
    Dan H.
  3. #3
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    Default Re: What to weld rebar with for target frame
    Here is a target stand I built for long range rifle shooting.
    Sch40 pipe in the corners and rolled steel for legs.
    As far as welding I used a miller dc invert welder and 6011 rods.
    Depending on the condition of your rebar the harbor freight flux welder may not be hot enough to burn through nasty rusty metal.
  4. #4
    Join Date
    Apr 2012
    Posts
    523
    Thebes il
    07 kioti dk 45s
    Default
    If you using rebar it proBley rusty I'd get a cheap, but not too cheap stick machine, the odds are after you get the hang of it you'll have more projects you will want to do , preferably a ac dc machine like a miller Hobart or Lincoln. You can find these used for a couple of hundred, in welding if you go to cheap you won't be happy.
  5. #5
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,692
    Branson, Mo.
    Kioti DK35se Hydrostat
    Get the old Lincoln 225 buzzbox it is AC only, but it will do the job, you should be able to pick up one for 150 or less. As others have said I would use some 6011, especially if the rebar is rusty, which it likely will be. I have one setting in the corner I don't use any more. I would use my Inverter DC welder, but in welding the rebar you are not going to notice the difference in weld quality or care that much. Get a autodarkening helmet if you can swing it, it will make welding a heck of a lot easier. Harbor freight has them, so does northern tool. An autodarkening helmet allows you to actually see how to place your electrode to strike the arc instead of just guessing where the rod is.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  6. #6
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,679
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Be careful--not all rebar is easily weldable. I discovered that the stuff you get at Home Depot is difficult to weld with my stick welder (Hobart Stickmate LX AC/DC) on DC+, my usual weld setting.
    Check the info on this website.
    Rebar Info - Welding
    You may have to shop around to find the good stuff that you can weld without a problem.
  7. #7
    Join Date
    Jun 2009
    Posts
    7,692
    Branson, Mo.
    Quote Originally Posted by flusher View Post
    I have heard that before, and I have also heard that rebar can be a "trash" metal with different things in it. I acquired a bunch of it when I bought this place, it was left lying on the ground when I took ownership. I have welded a lot of it and had no trouble welding it with stick. Maybe I just got lucky.
    James K0UA
  8. #8
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,699
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    You should always use weldable grade rebar.
    I've welded tons of rebar, with Lincoln's NS-3M Innershield.
    Here are some welding joint designs from a AWS D1-code book.
    Attached Thumbnails Attached Thumbnails What to weld rebar with for target frame-re-bar-1.jpg   What to weld rebar with for target frame-re-bar-2.jpg   What to weld rebar with for target frame-re-bar-3.jpg   What to weld rebar with for target frame-re-bar-4.jpg   What to weld rebar with for target frame-re-bar-5.jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  9. #9
    Veteran Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    1,941
    Northern CA
    A quick suggestion for your target build. Rebar stuck in the ground will not hold very well, especially if your circular targets are heavy - even if they swing.
    A large caliber pistol or just about any rifle will impart enough energy to knock the target over and right out of the ground. I ended up using "shoes" made out 8" long pipe sized so the rebar would just slide through the pipe and be driven into the ground. A 18" piece of angle iron was the shoes' soles. They faced parallel to the firing angle and to the rear.
    A high powered rifle will blow a hole through 1/4" plate and the target won't even swing. Been there, done that. It is good welding practice for filling holes.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  10. #10
    Join Date
    Apr 2012
    Posts
    523
    Thebes il
    07 kioti dk 45s
    Default
    Even if you shoot v max varmint bullets made to explode it will still put neat holes in 1/4 plate carbon steel.
Similar Threads
  1. Broken weld on backhoe frame
    By Longbeard in forum Welding
    Last Post: 11-07-2012, 03:29 PM
  2. No weld frame for hard top shade
    By Matt_W in forum Build-It Yourself
    Last Post: 04-22-2012, 10:47 AM
  3. Rebar tieing
    By CTyler in forum Projects
    Last Post: 07-07-2003, 05:17 PM
  4. Frame Weld on 1983 Kubota
    By jacm in forum Buying/Pricing/Comparisons
    Last Post: 01-17-2003, 02:33 PM
  5. Target under fire
    By PitbullMidwest in forum Related Topics
    Last Post: 08-29-2002, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
