crash325
Elite Member
Actually built the wood rack last year or this spring. It is a fun project that will keep you out of trouble for a day or 2. Can be used inside the house or outside. This 1 is fairly small only about 36"X32", holds 2 or 3 days wood. That sort of depends on how much you burn.
Good practice for new or novice welders, nothing tricky or hard to do. Only place you need to be careful is welding the nuts on for the adjustable legs. By the time you get that far, your welding should be pretty good.
Also shown are a couple of stoves built last year. They were detailed in some posts about a year ago.
