Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Member
    Join Date
    Mar 2008
    Posts
    31
    Default Re: Do it yourself exhaust system
    I was always going to build one myself. I got some blowers off some gas hot water heaters for the exhaust. Its a small squirrel cage, 115v. Then I was going to use dryer duct to build everything.
  2. #12
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    you can also get a nice blower from an old dish washer.
    Dan H.
  3. #13
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    dish washer have a blower? Maybe the more expensive ones?
  4. #14
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by chopped
    Blower and heater. To dry the dishes.
    Dan H.
  5. #15
    Member
    Join Date
    Mar 2008
    Posts
    31
    Range hoods have blowers too
  6. #16
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    The wife wanted to stop bye this liquidation store closing sale; boring but we where right there so in we go.
    I put my son in a shopping cart and was doing the rounds; killing time (probably 4 go arounds) when on the 5th something caught my eye...
    2 7 foot lock and tug vacuum hoses for my rigid shop vac. In the cart they go. Asked the cashier how much...$2/each!
    So for $4 I have my exhaust hose for my welding fume extraction via shop vac
    Pics 2 follow
    ericher69
    IAFF Local 849
  7. #17
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Here are the two 2 1/2 inch hoses I picked up for $4 joined together
    Rigid accessory hose kit piece with O-Ring and 2" Rubber plumbing boot
    And the HD $5 bucket with a 2" hole cut in the bottom via hole saw. Rigid accessory hard piece is cut down so that boot can hold O-Ring snug on the inside.
    Did a quick test and think it will work nicely!
    Will probably test run as is and cut the bucket down if needed
    Eric
    Attached Thumbnails Attached Thumbnails Do it yourself exhaust system-image-1893156632-jpg   Do it yourself exhaust system-image-1915343700-jpg   Do it yourself exhaust system-image-3060090749-jpg
    ericher69
    IAFF Local 849
Similar Threads
  1. Exhaust Removal System
    By glkingar in forum Build-It Yourself
    Last Post: 04-01-2012, 08:26 PM
  2. TL1900 Exhaust System
    By buddymay in forum Iseki
    Last Post: 02-18-2008, 11:43 PM
  3. Replies: 3
    Last Post: 08-23-2004, 10:24 PM
  4. B7500 Exhaust system
    By don716 in forum Kubota Owning/Operating
    Last Post: 08-13-2004, 09:05 PM
  5. Truck Exhaust System
    By JATO_RaT in forum Related Topics
    Last Post: 04-13-2003, 07:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
