Page 2 of 12 FirstFirst 12345 ... LastLast
Results 11 to 20 of 117
  1. #11
    Advertiser Mark @ Everlast's Avatar
    Join Date
    May 2010
    Posts
    2,226
    South GA
    Default Re: a good place to get angle steel??
    Quote Originally Posted by kw22614 View Post
    Thanks Mark for your reply, especially to a 'newbie' like me, but I didn't understand anything you just explained.
    Do you mean to tack flat bar just around the perimeter of the entire gate and not add anymore vertical angles?
    Yes...or you can get creative. Whatever you add, don't solid seam weld it unless you like dealing with metal distortion. When I say "tack", I mean 1 inch welds, multiple, all the way around about every 6-8 inches.
    Mark Lugo
    Everlast Welders
    http://www.everlastgenerators.com/
    Need a welder? Give me a call at (877) 755-9353 ext 204!
  2. #12
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,073
    Jarrettsville Maryland
    Kubota B3030 HSDC
    kw22614, do you get much wind resistance with your canopy top while going down the road? I know you don't have much clearance on the trailer but I wonder if you backed the tractor in you would have less chance of the canopy being lifted or bent backwards. Or maybe you could throw a couple of straps over the canopy and tie it to the front of the tractor. Or maybe I should mind my own business, ha!
    Stanley----Kubota B3030 HSDC
  3. #13
    Join Date
    Feb 2012
    Posts
    1,639
    Albany OR
    Case 580B, Long 460, Allis-Chalmers 160
    If you look at the pic, it seems that backing the tractor onto the trailer would put too much weight on the tongue - as it is, it's a marginal deal all around. Just by eye, I'd say the position of the tractor is as close to ideal as possible with just enough weight on the tongue to keep it from whipping but not breaking anything... Steve
    Oh, and Mark - I believe the term you were looking for is "stitch welding", those would be pretty heavy "tacks"...
  4. #14
    Platinum Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Quote Originally Posted by srs View Post
    No resistance at all, had the canopy strapped down while traveling. Too heavy on the tongue backing in. I think, as long as I keep up the correct and even tire pressure the tractor'll ride fine as I've placed her, though next time, if not needed, I'll remove the FEL, but the FEL arms did aid in cinching and holding her in place. All suggestions are welcome!
  5. #15
    Silver Member SHORT KID's Avatar
    Join Date
    Feb 2010
    Posts
    180
    Poconos, PA
    Mahindra 2615 hst fel, bh
    Do you have a Tractor Supply locally, they usually have an assortment of metal???
  6. #16
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Quote Originally Posted by Mark @ Everlast View Post
    Thanks, but seems like overkill to me. In talking with a couple neighbors today with similar situations they have welded angle vertically, directly under where the tires travel the ramp, and they have held up and been fine for years. As my welder can't weld anything over 3/16" I think I'll weld 2 angles back-2-back under the 'tracks'. I will keep your suggestion of using mutiple short welds to ward against distortion in mind as I progress with my skill, or lack of it. KW
  7. #17
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    7,987
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by SHORT KID View Post
    I was just going to say this. My local TSC, Home Depot, and Lowes carry both angle and flat steel in lengths up to 6' and up to 1/4" thickness. That covers most of my small projects. If you need longer then you need to go to a supplier.
  8. #18
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,017
    Port Orchard, WA.
    John Deere, 4200
    6 on 12 is a very common weld in the fabrication world. That is 6-inches of weld with a 6-inch gap between them. Or 12-inches center to center of the 6-inch weld. But you can substitute the 6-inch weld of 2-inches, 3-inches etc, etc.
    Attached Thumbnails Attached Thumbnails a good place to get angle steel??-6-12-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  9. #19
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    I do. I've gotten from them in the past and checking online they only have 1/8" angle - I'm trying to get 3/16".
    I was looking for a supplier who's maybe a little cheaper anyway.
    I never got time today to check out the 2 suppliers I found out about, maybe tomorrow. Thanks SHORT KID
  10. #20
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Quote Originally Posted by George2615 View Post
    Maybe I'll have to go and check them out in person. Thanks
    Just want 4 - 3/16" X 1 1/2" X 49 1/4" angle.
Similar Threads
  1. Any good place for old briggs carb
    By jmolwitz in forum General Lawn & Garden
    Last Post: 06-15-2011, 11:32 PM
  2. R4 tires (any good place to purchase)
    By sxs191 in forum Kubota Buying/Pricing
    Last Post: 09-30-2010, 09:12 PM
  3. Good Place to sell attachments?
    By SD_Dave in forum Attachments
    Last Post: 03-10-2006, 01:13 PM
  4. Anybody know a good place to get parts ?
    By ford351c in forum Parts/Repairs
    Last Post: 12-12-2004, 07:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
