Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Bronze Member LONGEVITYsimon's Avatar
    Join Date
    Sep 2012
    Posts
    72
    Hayward, CA
    Welding
    Default Re: My Longevity Mig200S
    Video Number 2: Setup of Machine and Knobs Described.
  2. #12
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Much better audio quality!
    And better editing(voiceovers).
    So nice to be able to hear clearly.
    I look foward to more of these better quailty videos.
    Dan H.
  3. #13
    Join Date
    Sep 2012
    Posts
    72
    Hayward, CA
    Welding
    Quote Originally Posted by CNC Dan View Post
    Thanks Dan, we will keep them coming!
  4. #14
    Platinum Member FredH's Avatar
    Join Date
    Jul 2007
    Posts
    846
    Ruch , Oregon
    N.H. TC-30
    Got home this afternoon and ended up building a new computer for BOL , But While windows was loading went out and played with a couple of pieces of tubing out of the scrap pile .
    My Longevity Mig200S-101_0055-jpg
    Above is before cleaning slag
    My Longevity Mig200S-101_0059-jpg
    These 2 were first and had welder a little to hot / high , was burning through the tube
    My Longevity Mig200S-101_0060-jpg
    This was after cleaning slag and getting adjustments a little better .
    Have to for sure retool my brain from welding with my 110/120 lincoln to this welder .
    Hopefully get to town in morning , want to pick up some rod to see if I can rekindle any brain cells from my high school days on stick welding . That could be Really entertaining !!
    In my case it was " Stick " Welding . Strike , Stick , Break loose , Strike , Stick , Break loose , etc.......
    Fred H.
  5. #15
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    You're getting there!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  6. #16
    Join Date
    Jul 2007
    Posts
    846
    Ruch , Oregon
    N.H. TC-30
    My pictures Suck !! I can build computers from scratch , but trying to take a close-up without blurring , UGH !!
    If I take my time , set up every thing " Right " , ( Clean dust off glass of helmet also helps ) , I am still a hack , but am able to stick things together . Last weekends 5 minutes of play was the first welding done since last spring's Land Plane build , It comes around with time .
    S.A. : I really Appreciate Your Help , Thoughts and Ideas , Makes Hacks Like me a better Welder or at Least Gives Me Hope .
    Fred H.
  7. #17
    Join Date
    May 2007
    Posts
    704
    SW OH - near Dayton, OH
    1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC
    Quote Originally Posted by FredH View Post
    Many digital cameras have a "macro" button that you push for focusing on picture close-ups or else you get blury pics. I imagine even some higher end phone cameras have the feature too. I would almost guarantee that the camera you are using does if the picture is blurry. My company's expensive high dollar camera that I must use at work absolutely will not take a close-up picture without blurring unless that "macro" button is pushed.
  8. #18
    Join Date
    Jul 2007
    Posts
    846
    Ruch , Oregon
    N.H. TC-30
    The Beauty of this Forum , Always Learning Something . Now going to have to research camera settings .
    Fred H
  9. #19
    Join Date
    Jul 2007
    Posts
    846
    Ruch , Oregon
    N.H. TC-30
    Well , Headed to town yesterday for some metal from my supplier . Couple of pieces of 1/4" plate and was also looking for some 1/4" square tube , maybe 2" x 2" but ended up getting a section of 2" x 5" or 2" x 6" , ( forget now ) what it was . Anyway , shot over to a welding supplier and picked up a 5# box of 6011 . Got home and ran 2 rods through the 200S . Welder works fine in arc mode , ( Meaning the MACHINE!! ) . Me on the other hand , ugh ! . First mig welding requires 1 movement , Horizontal , But Stick / Arc requires 2 movements , Both Horizontal and Vertical , ( Feeding rod is the vertical movement ) . Sorry People , Way to much Strain on this Brain at this point in my life . Did it years ago in high school but older now and Seriously Doubt Wiser , so I am reverting back to my favorite acronym ,
    KISS , Keep it Simple Stupid . ( Stupid meaning me ) . 1 Movement easier than 2 , Likely Why I don't Chew Gum either . Never would be able to walk any were .
    Fred H.
    P.S. Actually did better than I thought , never stuck the rod , Just Never burned more than 1" off the rod at a time either , So Shield Arc is right there also , " Moving to slow " .
  10. #20
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Fred;
    Where are the pictures of your stick attempts?
    Perhaps a seasoned pro could provide some constructive criticism.
    It does not take 30yrs to lose the hang of stick welding... A year or two will do it also!
    I guess I have gotten "spoiled" with MIG also
    ericher69
    IAFF Local 849
Similar Threads
  1. Clutch Longevity
    By gerard in forum Owning/Operating
    Last Post: 01-03-2010, 04:44 PM
  2. Tire Longevity
    By NewToy in forum Tires
    Last Post: 11-03-2009, 10:50 AM
  3. RPM vs Longevity
    By JerryG in forum Owning/Operating
    Last Post: 02-12-2004, 02:20 PM
  4. Kubota Longevity
    By RobS in forum Kubota Owning/Operating
    Last Post: 10-06-2003, 01:43 PM
  5. kubota longevity
    By Anonymous Poster in forum Kubota Buying/Pricing
    Last Post: 06-11-2002, 11:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
