Results 1 to 10 of 12
01-25-2013, 07:11 PM #1Bronze Member
- Join Date
- Nov 2012
- Posts
- 64
- Location
- Land Between the Lakes
- Tractor
- John Deere 3038e
Finally decided to get back into welding......
No thanks to this forum.....
Man, you guys got me wanting a welder....again......after 25 yrs(as a teenager on the farm)....using a lincoln tombstone.....
i have researched these new welders for about 2 months....and finally ordered a new welder....
Today i set it up in the garage... MAN....these things have come along way.....
I went to my local AIRGAS welders supply and ordered a Thermal Arc 211i.....took them about a week to get it in....
The guys there got me fixed up on rods/wire/gas..gloves, cart,clamps...etc.....
Ran my first bead in 25yrs.....
John Deere 3038e
Kentucky
01-25-2013 07:11 PM # ADS
01-25-2013, 07:15 PM #2Elite Member
- Join Date
- Jan 2009
- Posts
- 2,782
- Location
- Figuring the picking points of jelly donuts.
- Tractor
- John Deere, 4200
Re: Finally decided to get back into welding......
Need to turn it up, too cold.
01-26-2013, 04:22 PM #3Veteran Member
- Join Date
- Mar 2007
- Posts
- 1,030
- Location
- Midwest
- Tractor
- Iseki TA 247. Husqvarna 54", Cub Zero Turn.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
Welcome back to the Welding World. Nice welder choice and now you will be dreaming up all kinds of projects.. That machine has some nice features. Power factor for one lets you pull big amps out of a 115v 20 amp circuit. You actually got 3 machines. 3 in 1 as they are called. Good luck..
01-26-2013, 04:38 PM #4
I agree with shield arc, you can see at the edges it didn't dig into the plate, just kind of sat on top. It might help if we knew what you were running, at what power. Not knowing that, I would crank it up another 10 amps or so, and see if that fixes it. The other thing I find helps is moving the rod in little circles, so it really ties into both pieces well. That probably didn't help at all, I am useless at explaining how to do something, so much easier to show someone.
"If the women don't find you handsome, they should at least find you handy" - Red Green
01-26-2013, 05:05 PM #5Veteran Member
- Join Date
- Jun 2006
- Posts
- 1,286
- Location
- West Cascades Washington State
- Tractor
- PT 422
Nice start, warm it up a bit. Have fun!
I got my dads old tombstone going again. Now i just need to invest in a new helmet.
01-26-2013, 05:20 PM #6Elite Member
- Join Date
- Jan 2009
- Posts
- 2,782
- Location
- Tractor
- John Deere, 4200
Looks to me like it is some type of gas less flux core. With all that splatter, could be holding too long of stick out. Hopefully he is left handed!
01-26-2013, 05:25 PM #7
I guess I assumed it was stick seeing the spatter, I have never ran flux core, so it didn't really occur to me. I thought it was 6011 or 6010, at least that are what mije look like.
01-26-2013, 05:27 PM #8
Having a welder and being able to make repairs etc is good thing...I'm envious of the guys that seem to have an endless supply of on hand and scrap steel etc...
Good luck with your new machine..have fun
No scrap yards within 1.5 hr. min. of here...So if I want to fabricate metal project I'm stuck with the local welding/fab. shop (about 12 mi.)...but even at their cost for steel I can often find something already manufactured (including paint) and often a warranty...for what I would have in just materials and consumables...a lot of the scrap I have been able to salvage requires as much prep work as the rest of the project...i.e., dealing with rust, cutting old welds/joints and grinding etc...Slash Pine
blunt and succinct but sincere...in the immortal words of Popeye..."I yam what I yam"
01-26-2013, 05:34 PM #9
Slash Pine
01-26-2013, 06:11 PM #10Elite Member
- Join Date
- Jan 2009
- Posts
- 2,782
- Location
- Tractor
- John Deere, 4200
I have used Lincoln's NR-211 in Alaska with up to 90-MPH winds! Had to be very careful when walking around or we would be on our butts in a heart beat!
Here is a picture of the newer NR-212.
Similar Threads
Finally decided
By 2002fb in forum John Deere Lawn & GardenReplies: 2Last Post: 04-13-2011, 09:55 PM -
Buying Advice Finally decided
By sbohan in forum Kubota Buying/PricingReplies: 6Last Post: 12-21-2010, 09:50 AM -
Finally Markham welding gets back
By arrow in forum WeldingReplies: 2Last Post: 04-01-2008, 09:06 PM -
Finally decided on welding machine
By chim in forum WeldingReplies: 31Last Post: 10-18-2003, 12:20 PM -
Finally decided on the B2410
By seattle in forum Kubota Buying/PricingReplies: 3Last Post: 05-18-2002, 08:17 PM
