Page 15 of 15 FirstFirst ... 512131415
Results 141 to 147 of 147
  1. #141
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,782
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Default Re: weld grinding tips needed
    Quote Originally Posted by joshuabardwell View Post
    Prove it! Let's see your junk welds!
    Oh I have lots of them!
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-3.jpg   weld grinding tips needed-6.jpg   weld grinding tips needed-9.jpg   weld grinding tips needed-12.jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #142
    Elite Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    4,578
    Nova Scotia
    BX 25
    Quote Originally Posted by daugen View Post
    EDIT: I see you got the everlast. Good luck with your purchase !
    Thanks Scooby. Not in yet, like a kid waiting for delivery at the moment. Have the helmet and gloves,
    and likely to get a five or ten pound fire extinguisher. I'm assuming ABC ? Ever any reason to want a pressurized water,
    like in lighting up farm combustibles? Once a fireman, always a worrier...
    And I got some inexpensive clamps, though I already have a lot of steel C clamps.
    And lastly, a cute little thwacker that chips off what needs to get chipped off, with a nice
    wood stove style metal handle on it. I have the grinders and flap wheels, etc, but I do wonder about
    spark shields/barriers, blankets, etc etc etc. I guess you never need the safety stuff unless you really really
    need it...
    I appreciate the feedback on protecting one's eyes. If I feel any discomfort at all with this 110 dollar helmet, I won't hesitate to spend more
    to save my aging eyeballs. I think this helmet was rated to react in one twenty five thousands of a second. Seems fast, but I'm sure what is more relevant is the quality of the reaction. The intellectual challenge for me now, since I don't have my welder yet..., is being able to see what I'm doing. It's so bright the lens has to be dark, really dark, so the videos I've seen remind me of groping around in a dark burning house, which unfortunately in SCBA I had more experience than I wanted.
    Is there a perfect "darkness", or is that open to opinion or simply each to his own eyeball?
    Water extinguishers are the best bet IMHO. I have one. It comes in very handy not only for any small fires but cooling as well, I use mine all the time. Not nearly as messy either! . Plus its as easy to fill as turning on the tap, unlike a ABC. That said you should have an ABC just in case.
    On the helmet. Try yours out first and see. You might not be susceptible. If your eyes are itching, crusty feeling or burning at the end of a bit of welding (or the next day) get yourself something else. These helmets are SUPPOSED to darken fast enough, but in practice, for my eyes, they didnt.
    And No, i wasnt getting flashed off my shirt or leakage around the helmet. It wasnt my first day welding But that is a good point. Wear dark clothing and watch for leakage around the lens and coming up by your chin. You can tape some leather (or something else non flamable) to your helmet for a better seal.
    As to "perfect" darkness.. There are different recommended "shade" levels for different processes and amperage levels. I like to go as light as possible yet still protect my eyes. http://www.lincolnelectric.com/en-us...dinglenses.pdf
    One last thing to consider re: helmets, is TIG can be a bit tricky for some AD's to recognize .
  4. #143
    Join Date
    Nov 2011
    Posts
    198
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    You can find decent cheapish helmets with a specific tig setting that work pretty good.
  5. #144
    Join Date
    Feb 2012
    Posts
    1,733
    Holland, PA
    2012 Kubota L5740HSTC3, 1986 Case IH 255, 1986 Gravely 8199G
    Quote Originally Posted by Shield Arc View Post
    to my utterly uneducated eye it looks like too much material on top, not always smooth.
    Not hot enough?
    Other than cosmetics, were these adequately strong welds?
    could be all go and no show...
  6. #145
    Join Date
    Jan 2009
    Posts
    2,782
    John Deere, 4200
    That pipe was done several years ago, so I don't remember any details. Most likely working on which rod I liked best with an Inverter welder, or working on which technique I liked best for small bore pipe. Either way it looks like dog sheet! I'm just like anybody else here, I make bad welds too.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  7. #146
    Join Date
    Jan 2012
    Posts
    68
    Mountaindale, Oregon
    Allis Chalmers ACD19, ACG; Kubota BX2200 FEL, B2710 FEL, L355SS FEL; Cat D47U, Ford 4600SU FEL
    Looks like 6011!
  8. #147
    Join Date
    Jan 2009
    Posts
    2,782
    John Deere, 4200
    You know the more I think about this. I think it was 6010 run like 7018. Someone mentioned running 6010 like 7018 on one of the welding forums. I think this was my first attempt. Here is what I ended up with.
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-6010-3.jpg   weld grinding tips needed-6010-6.jpg   weld grinding tips needed-6010-9.jpg   weld grinding tips needed-6010-12.jpg
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
Similar Threads
  1. Ford 1220 4wd grinding clicking help needed
    By silverbk in forum Parts/Repairs
    Last Post: 09-13-2012, 08:52 PM
  2. Replies: 37
    Last Post: 01-24-2012, 07:29 AM
  3. Chipper Apache 240c chipper, shaft and box removal tips needed
    By wyzj in forum Attachments
    Last Post: 08-22-2009, 05:48 PM
  4. opinions needed on weld re-repair
    By Soundguy in forum Parts/Repairs
    Last Post: 01-02-2007, 09:23 PM
  5. Replies: 3
    Last Post: 04-03-2006, 06:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
