Page 2 of 15 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 147
  1. #11
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: weld grinding tips needed
    hit it with a lil angle grinder to expose any holes that need to be filled. refill then.. then grind mor ewith a angle grinder.. then hit the flap wheel.. depending on how much you want to weld and grind and work it.. you can make it anwhere from ugly but strong to perfect...
  2. #12
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,018
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by daugen View Post
    I didn't do the welding, the shop did.
    You mean a welding shop did that?!!!!!!!!!!!!!!!!!!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #13
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,737
    Branson, Mo.
    Kioti DK35se Hydrostat
    I have neither, I didn't do the welding, the shop did. So I need to buy a first welder, something basic to make repairs like this. And now I know the rods to use, thanks.
    So what you see is what I got, and now I have to finish it. When I saw that big opening on the one side, I knew I had more welding to do. My first welding actually.
    So I'm a pure newbie here, but I understand good penetration.
    I guess I misunderstood, I thought YOU did the welding. You mean that someone else did that welding? Oh.. dear..
    I would suggest you get one of the Everlast or Longevity DC stick inverter welders or try to find one of the older transformer based Miller or Lincoln or Hobart Ac/DC welders and with some practice and the proper rod, YOU can do a heck of a lot better than the "welding professional" that did that. I have a PA160 Everlast that I paid $269 for about 3 years ago, and it has served me well for repairs and fabrication. I even TIG with it after I added a scratch start TIG torch with valve, and a regulator on the argon bottle. Daugen you should get yourself a welder, learn how to weld, and never go back to where ever you got that done at...good luck.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #14
    Join Date
    Jun 2009
    Posts
    27,737
    Branson, Mo.
    Quote Originally Posted by Shield Arc View Post
    OMG. that is what I said.. I can't believe that a welding shop "Pro" would let something like that out the door. Holy Cow. I was going easy on the wormholes and bird turds, because I though this was HIS first welding project...Man oh man..
    James K0UA
    James K0UA
  5. #15
    Super Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    9,909
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    in fairness to the shop, they had a budget and more of an ugly but strong spec to work with, thanks Soundguy.
    They were supposed to fix the front part primarily, but knowing I don't own a welder, getting it back this way
    seemed kind of strange to me. It's a long time Gravely dealer and one I like, so I cut them some slack, they do other
    nice things for me. And maybe what they have just done is get me off my proverbial behind and get my
    first welder. I think an AC/DC stick setup would be just fine. I have a birthday coming up, hmmmm.
    So....be critical on the front welds, not the sides and rear. Course this is a strange mower and it's kinda hard to tell which end is which.
  6. #16
    Join Date
    Feb 2012
    Posts
    9,909
    I was going to do that, give it a rough grind to see if anything flakes off, falls out, whatever, then
    when you say "refill" you mean reweld, correct?
    I could make it all look perfect with Bondo or even plastic spackling, if it were a show queen, but I want to
    use the mower, if only a little.
    There's a field on the farm near the lawn area that is a perfect soccer field size area,
    level, and sometimes that gets mowed more like a lawn so grandkids can kick balls there. And not get too many
    ticks on themselves.
    When I'm done with it, it will look like new. Surface prep is so important, particularly with metal.
    But once I've ground it down a final time, if there are little dimples or cosmetic imperfections, tough. It's a mower.
    I'd rather spend more time on the thorough cleaning, priming, and top coats. And using lots of blue tape to keep the end
    result nice.
    To make my double trailing rig, I need to rework this latest mower's hitch so that it pulls from a different spot.
    Likely have some welding to do there too. I'm in no rush.
  7. #17
    Join Date
    Jun 2009
    Posts
    27,737
    Branson, Mo.
    Daugen, bondo would fill imperfections in a hurry, but since it is a mower, wouldn't the vibration and impact crack the bondo and have it falling out pretty quick?
    James K0UA
  8. #18
    Join Date
    Jan 2009
    Posts
    6,018
    Port Orchard, WA.
    John Deere, 4200
    OK, I'm new to all this, so please forgive the newbie question, but why do you think you need AC?
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  9. #19
    Join Date
    Feb 2012
    Posts
    9,909
    Quote Originally Posted by k0ua View Post
    Jim, sorry, of course, I was just making a point of how to do it "the wrong way", luckily, I'm dumb, but not THAT dumb...
    putting any kind of filler in something that vibrates is only asking for trouble. I only mentioned that because I don't (yet) know how to weld.
  10. #20
    Join Date
    Feb 2012
    Posts
    9,909
    I thought the tombstone stick welders came AC and DC was an option, albeit expensive but offering performance benefits (less splatter) in some applications.
    Clearly I know only theory and I'll defer to anyone else with knowledge.
Similar Threads
  1. Ford 1220 4wd grinding clicking help needed
    By silverbk in forum Parts/Repairs
    Last Post: 09-13-2012, 09:52 PM
  2. Replies: 37
    Last Post: 01-24-2012, 08:29 AM
  3. Chipper Apache 240c chipper, shaft and box removal tips needed
    By wyzj in forum Attachments
    Last Post: 08-22-2009, 06:48 PM
  4. opinions needed on weld re-repair
    By Soundguy in forum Parts/Repairs
    Last Post: 01-02-2007, 10:23 PM
  5. Replies: 3
    Last Post: 04-03-2006, 07:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
