Page 8 of 15 FirstFirst ... 567891011 ... LastLast
Results 71 to 80 of 147
  1. #71
    Super Star Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    10,416
    Washington NC (Inner Banks)
    Kubota L5740HSTC3, MF 2615, MF 1230, IH Super A
    Default Re: weld grinding tips needed
    Quote Originally Posted by joshuabardwell View Post
    I noticed that too. Honestly, I don't know what he intends to do, but I'm surprised to hear him talking about 1/2" and thicker. I can't really imagine what "around-the-farm" repairs would involve metal that thick. That sounds a lot like structural stuff to me. I look at my trailer, my tractor, even my truck... hardly anything on there is over 3/8", and most is under 1/4".
    As for MIG, when I first started welding, I had to decide between stick or wire-feed, and I settled on stick. I can see now that if my main concern was just git-r-done, MIG would be the right choice. Not that MIG doesn't require skill too, but with MIG, you can really lay down the welds with an efficiency and ease that you can't do with stick. Oh, and did I mention no cleaning slag either? Yeah. Gotta love that. MIG machines can also get down to a thinness that stick struggles with. But I always have to do things the hard way, and I do like the simplicity of stick. No gas, no bottles, no gun, no feed wheels. Just an electrode, a stick, and a ground clamp. As for TIG, I just think TIG is a really beautiful process, and I mean that in every sense of the word too--aesthetically and everything. I look forward to learning TIG someday.
    just fyi: my subsoiler is seriously HD, and I guarantee you there are parts of it thicker than 3/8, the main shank anyway, and I was thinking of installing guides to lay pipe. Of course the guide is not that thick but it's going up against
    something thick, which was what I was trying to get across. But normally? Mower deck material and sometimes that can be double layered on big mowers, so there's some beef there too. I figured half inch was largest/worst case
    so that's the example I used. These mower decks could probably be repaired with a 50 dollar welder from HF.
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-p1010081-jpg
  2. #72
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    weld grinding tips needed-weld-gif
    Quote Originally Posted by daugen View Post
    for us unwashed and dumb, could you explain what makes a 6010 rod "special" and why a separate port would make it run better?
    General purpose rod? Do some rods work with AC and some with DC better?
    sorry, you guys are talking over my head, which clearly doesn't take much.
    different rods for different materials.. and the numbers mean different things.
    for instance the first digits 6 is for 60k tensile strength.. 7 for 70.. etc...
    this chart explains some of it...
  3. #73
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    So really put some heat on it during the first 30 days and then relax.
    In 1982 the company I was working for bought me a brand new Lincoln SAE-400 diesel drive. The machine wasn't working quite right, so I went to the superintendent and ask him to have the Lincoln repair tech come out and look at the machine. He said to shut the machine off, clamp the ground clamp and stinger together, turn the machine all the way up and re-start it, run it until the leads start to smoke! I about fell over, he replied just do it! I did, the machine worked perfect from then on.
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-sae-400-jpg   weld grinding tips needed-sae-400-fp-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  4. #74
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by Shield Arc
    Did you ever get that book? If so how do you like it?
    I did get it. It is helpful, but a bit dated with the trig tables. A lot of info I'm never going to use, but I like to learn about new things. Those few pages that you posted scans of on how to cut a header and branch...., I had already figured out an alternate way to lay it out using a calculator. But if you don't want to cut into the header, the branch layout needs to be a little different.
    (using the pipe as structure, not plumbing) But it's a good place to start. For smaller tube, I use a program that will give you a curve that you can print and cut out. But you are limited by your paper size.
    I liked the orange peel layout, but it didn't give the formula, just a table for some pipe sizes. No good for tubing. But with the book info I figured out the formula myself.
    Dan H.
  5. #75
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    Sorry about that, sounds like you are a little disappointed.
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  6. #76
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Just a little. But no regrets. It's a good reference. At arround $8 shipped how could I go wrong.
    After learning some new terms, I did a google search and found a good PDF of pipe welding from union carbide. I'm guessing from the '60s.
    Any other welding books you could recomend? I'm going too look for a beginners book on trig this weekend.
    Dan H.
  7. #77
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by CNC Dan View Post
    Oh yeah, lots of books!
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-lincoln-handbook-jpg   weld grinding tips needed-therory-practice-jpg   weld grinding tips needed-metals-how-weld-jpg   weld grinding tips needed-heat-shrink-jpg   weld grinding tips needed-gtaw-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #78
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    I have a one more, but the site won't let me unload it for some reason! Maybe later?
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-design-weldments-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  9. #79
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    Here we go!
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-tubular-steel-structures-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  10. #80
    Join Date
    Jan 2009
    Posts
    6,084
    Port Orchard, WA.
    John Deere, 4200
    I forgot about this one.
    Attached Thumbnails Attached Thumbnails weld grinding tips needed-pipe-welding-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
Similar Threads
  1. Ford 1220 4wd grinding clicking help needed
    By silverbk in forum Parts/Repairs
    Last Post: 09-13-2012, 08:52 PM
  2. Replies: 37
    Last Post: 01-24-2012, 07:29 AM
  3. Chipper Apache 240c chipper, shaft and box removal tips needed
    By wyzj in forum Attachments
    Last Post: 08-22-2009, 05:48 PM
  4. opinions needed on weld re-repair
    By Soundguy in forum Parts/Repairs
    Last Post: 01-02-2007, 09:23 PM
  5. Replies: 3
    Last Post: 04-03-2006, 06:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
