Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 71
  1. #11
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: A partial review of my new Everlast 250P welder.
    Quote Originally Posted by Shield Arc View Post
    I lied, I did play with the pulse some, but with aluminum.
    Shield Arc, What is a good Mig welder for someone learning to weld?
    Murph
  2. #12
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    You know I really couldn't tell you. I don't have a lot of experience with Mig welders. About 10-years ago I bought a Linde VI-206 at an auction, only reason I bought it is about 20-years before that I used them on a job sheeting an 80' x 80' x 70' tall building with 4' x 8' x 10-GA sheets. All open root 100% penetration. The Lindes worked perfect! Other than that all my wire feed experience as been with 400 + amps engine drives with an LN-22 or LN-25 attached to them running Innershield wire.
    Sorry I couldn't be of more help!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #13
    Gold Member
    Join Date
    Jan 2006
    Posts
    441
    Stone Mountain, GA
    Case 1210, Mitsubishi D2050
    And you are just playing around? Man, I wish my welds looked that nice ...
    That looks like a really nice machine. How are the wire guides/feed rollers? I looked at one major brand that had some sort of plastic feed rollers and it just looked like there is no way they would last.
  4. #14
    Veteran Member Markcuda's Avatar
    Join Date
    Jan 2011
    Posts
    1,277
    Clinton, Illinois
    2014 John Deere X534
    The feeder/roller assembly is very robust, IMHO.
    Check this out.
    A partial review of my new Everlast 250P welder.-power-i-mig-250-p_6-a
    Hours=(78)-2014 X534,bought May 29th,2 spinner knobs,brush guard,convert-a-ball front and rear,mulch kit,Gator blades,J/D 10P cart,4 suitcase weights,Brinly 24x36 poly lawn roller.Markcuda.com
    "if you like your healthcare,you can keep it"
    "if you like your doctor,you can keep them"
  5. #15
    Join Date
    Jan 2011
    Posts
    1,277
    Clinton, Illinois
    Another picture.
    A partial review of my new Everlast 250P welder.-power-i-mig-250-p_4-a
  6. #16
    Platinum Member Reyer Farms's Avatar
    Join Date
    Sep 2012
    Posts
    655
    Lena, ms
    Mahindra 5010
    Default
    Quote Originally Posted by Markcuda View Post
    Check this out.
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=300727"/>
    It will never weld!! Ain't got no wire in it!! Sorry couldn't help myself. I like the burn back knob and force knob. I like knobs instead of menus.
  7. #17
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    Man that is impressive, a 4-drive roll system on a machine that size!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #18
    Join Date
    Jan 2011
    Posts
    1,277
    Clinton, Illinois
    Ya, the burn back is kind a neat
    My big dollar welder at work doesn't even have one.
  9. #19
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    I have to give it to Everlast, the wire drives do look nice. The look about the same or better then miller. I do still think the machined aluminum of the high end lincolns look better, but not having run either, I am going just on looks. I am glad to see everlast doesn't cheap out on the wire drive, even low end lincolns, and I think some of the hobart have a mainly plastic wire drive. Doesn't matter how nice the power supply is, if the wire drive slips all the time. I know the 125 amp (POS) lincolns at school were terrible for that. Always atleast one of the three wasn't working.
    Never carry gasoline in your car trunk. If you do, atleast use some sort of container.
    -red green
  10. #20
    Join Date
    Jan 2009
    Posts
    6,063
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by deereman75 View Post
    Couple months ago I loaded up some 1/16-inch Coreshield 8 in my Lincoln LF-72 feeder. I could not keep it from slipping. I made up a spacer for the tensioning bolt, and it still slipped! So I had to pull out my LN-25. Don't understand why the LN-25 doesn't slip, but the LF-72 does.
    Attached Thumbnails Attached Thumbnails A partial review of my new Everlast 250P welder.-lf72-jpg   A partial review of my new Everlast 250P welder.-lf-72-drive-rolls-jpg
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
Similar Threads
  1. Everlast Welders - Welders and Plasma Cutters by Everlast
    By Mark @ Everlast in forum Welding
    Last Post: Yesterday, 02:15 PM
  2. Replies: 34
    Last Post: 12-29-2012, 09:04 AM
  3. Thinking about buying a Tig welder, Everlast?
    By JAS1966 in forum Welding
    Last Post: 12-15-2012, 08:03 PM
  4. NEW EVERLAST POWERARC 300 STICK WELDER!
    By gumshu in forum Welding
    Last Post: 07-01-2012, 11:55 PM
  5. Everlast PowerPlasma 70 review
    By gwdixon in forum Welding
    Last Post: 12-03-2010, 08:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
