Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 71
  1. #21
    Join Date
    Mar 2007
    Posts
    1,005
    Midwest
    Iseki TA 247. Husqvarna, Cub.Polaris ATV's
    Default Re: A partial review of my new Everlast 250P welder.
    Did the LN25 have a different gun on it? 1/16 or larger liner in the gun right? Many use knurled drive rolls for cored wire.
  2. #22
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,723
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Quote Originally Posted by yomax4 View Post
    yomax4, now you know this isn't my first rodeo!
    Same gun on both feeders, (K-126). Serrated drives rolls in both feeders too.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  3. #23
    Platinum Member Markcuda's Avatar
    Join Date
    Jan 2011
    Posts
    992
    Clinton, Illinois
    2010 John Deere X360
    Any one use these?
    Hours=86.4,bought June 12th,2010 J/D,X360,
    power steering,power 48 inch deck,tilt wheel,2 spinner knobs,brush guard,J/D 10P cart,4 suitcase weights,150 lbs RimGuard in rear tires,Brinly 24x36 poly lawn roller.2003 Harley Ultra Classic Electra Glide,220,486 miles,I have been in all the lower 48 states with it. No bible quotes here.
    Markcuda.com
    "you didn't build that"
  4. #24
    Join Date
    Jan 2009
    Posts
    2,723
    John Deere, 4200
    Don't use the ones with lube on them! An ear plug works just as good.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  5. #25
    Join Date
    Jan 2011
    Posts
    992
    Clinton, Illinois
    Wow, I like the ear plug tip ::::))))))
    Markcuda.com
  6. #26
    Join Date
    Jan 2009
    Posts
    2,723
    John Deere, 4200
    Reason I don't like the pads with lube on them is, all Mig wires flake as they go through the drive rolls. The lube has a tendency to glue the flakes together, and can really gum things up inside the liner.
    Innershield wire has a graphite lube on it, when the wire goes through the serrated drive rolls it really makes a big mess.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  7. #27
    Join Date
    Jan 2011
    Posts
    992
    Clinton, Illinois
    The wire I use does not have a coating on it=bare wire.
    It is ESAB.
    Markcuda.com
  8. #28
    Join Date
    Mar 2007
    Posts
    1,005
    Midwest
    Quote Originally Posted by Shield Arc View Post
    Hahaa. I know. Hard to believe that the drive rolls could be worn though. Not the Outlet guide right? Sorry.
  9. #29
    Join Date
    Jan 2009
    Posts
    2,723
    John Deere, 4200
    No, brand new drive rolls, guide plates, and brass bushing for the K-126 gun on the LF-72 feeder. Funny it feeds all other wires fine. Well up to .045"!
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  10. #30
    Join Date
    Jan 2011
    Posts
    992
    Clinton, Illinois
    Smile Re: A partial review of my new Everlast 250P welder.
    A couple of pictures of the cart work today.
    I welded on 4 nuts that the welder will rest on at each corner.
    Attached Thumbnails Attached Thumbnails A partial review of my new Everlast 250P welder.-02-02-13-welder-1.jpg   A partial review of my new Everlast 250P welder.-02-02-13-welder-2.jpg
    Markcuda.com
Similar Threads
  1. Everlast Welders - Welders and Plasma Cutters by Everlast
    By Mark @ Everlast in forum Welding
    Last Post: Yesterday, 09:32 PM
  2. Replies: 34
    Last Post: 12-29-2012, 09:04 AM
  3. Thinking about buying a Tig welder, Everlast?
    By JAS1966 in forum Welding
    Last Post: 12-15-2012, 08:03 PM
  4. NEW EVERLAST POWERARC 300 STICK WELDER!
    By gumshu in forum Welding
    Last Post: 07-01-2012, 11:55 PM
  5. Everlast PowerPlasma 70 review
    By gwdixon in forum Welding
    Last Post: 12-03-2010, 08:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
