Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Gold Member rockshaft's Avatar
    Join Date
    Feb 2012
    Posts
    261
    Sterling, AK
    1026R
    Default Re: Weld strength with flux wire vs gas....
    My welds look close to that... After about 10min of grinding!
    The fluxcore i usually use doesn't produce nearly as pretty a weld as the solid wire i have, but the penetration of the flux core is also very apparent, so i usually go with it for any applications where i want extra strength. I'm no pro, just my 2cents
  2. #12
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    5,994
    Port Orchard, WA.
    John Deere, 4200
    I'm no pro either! When to comes to gas less flux core T-11 wires, my go to wire is Hobart's Fabshield 21-B. Then Lincoln's NR-212. I don't think Lincoln makes it anymore, one wire I would avoid is Lincoln's NR-211! I think Lincoln discontinued the NR-211 wire, and came out with the NR-211MP. I never took a test with NR-211, but have been told several times in testing facilities they have never seen anybody pass a bend test with NR-211. I've taken numerous 1-inch side bend tests with 21-B, and never failed one. 2 or 3 of them I walked out of the testing facility just knowing I failed, but a few days later the job site would get a call saying I passed.
    Attached Thumbnails Attached Thumbnails Weld strength with flux wire vs gas....-21b-jpg   Weld strength with flux wire vs gas....-nr212rf-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #13
    Join Date
    Feb 2012
    Posts
    261
    Sterling, AK
    1026R
    I don't have any reference point to compare. I've been using the Lincoln 211MP, just a fairly low cost wire I could find locally.
  4. #14
    Join Date
    Apr 2012
    Posts
    733
    Thebes il
    07 kioti dk 45s
    Default
    Personally when I want a really strong weld in something that bears a lot of stress I go to smaw.
Similar Threads
  1. My portable 24v Flux Wire welder
    By anickode in forum Welding
    Last Post: 04-01-2012, 12:51 AM
  2. Mig flux core wire
    By SARG in forum Welding
    Last Post: 01-31-2011, 07:50 PM
  3. price of .030, .035 flux wire
    By tawilson in forum Related Topics
    Last Post: 04-17-2005, 12:05 PM
  4. Flux wire welder
    By RHughes in forum Build-It Yourself
    Last Post: 03-15-2005, 04:10 PM
  5. Self Shielding Flux Core Wire Welders
    By MikePA in forum Related Topics
    Last Post: 08-16-2003, 08:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
