Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
  1. #11
    Silver Member Bday's Avatar
    Join Date
    Dec 2012
    Posts
    164
    Lucerne, IN
    53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
    Default Re: Shielding gases
    Quote Originally Posted by ericher69 View Post
    What size wire and input power are you using? (110 or 220?)
    I personally use CO2 but only do occasional repairs/fabrication.
    A med size bottle lasts me years.
    SA- that weld was done on spray transfer?
    Hey Ericher, I run .035 hobart wire. When I was welding everyday for a living most all the factories I worked in used 75/25. I'm running a miller 252 I bought last weekend.
  2. #12
    Join Date
    Dec 2012
    Posts
    164
    Lucerne, IN
    Hey Shield arc, see you got the boys fired up over at the welding web over your wet 7018's. Like watching a soap opera!
  3. #13
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,709
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    Quote Originally Posted by Bday View Post
    Hey shield arc I like the spray transfer. I also like to see some character to the bead. When I was in school they taught us less heat and more technique. I personally like the mig welds that take on a Tig welded appearance. Man we could lay some pretty welds with the 3 phase units at work.
    I'm still not convinced of the structural value of that Mig like Tig technique, but it does look
    Yeah got a little fire storm going there didn't I? I knew Lawson was going to have a fit, we have had words before. After our screaming match on the telephone he finely seen it my way that not everybody works to code. Stickman and I kissed and made up through PMs, that was all a misunderstanding on my part! Come to find out he is a pretty good kid!
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  4. #14
    Join Date
    Dec 2012
    Posts
    164
    Lucerne, IN
    Quote Originally Posted by Shield Arc View Post
    Yep, technique is everything. Very easy to cold lap! We welded Sch 60 pipe open root in all positions. Etched and bend tested in all positions. Used Co2 for gas. If I remember right, I had a small lack of fusion on one of my downhill coupons. Not enough to fail though!
    Glad it cooled down!
  5. #15
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,588
    canada
    If you really want to turbo charge your welds, go with some C10. Or 98% argon, and 2% oxygen.
    This weld was made with C10.
    You forgot to mention the industrial machine needed to even get into spray transfer. From what I recall reading even a 250 class machine (linde and esab exempt) that can get into spray transfer will have such a low duty cycle at that point, that it is almost slower than short circuit mig. So it seems if your serious about spray transfer, you need something like your invertec or a 350 amp+ transformer.
    "If the women don't find you handsome, they should at least find you handy" - Red Green
  6. #16
    Join Date
    Jan 2009
    Posts
    2,709
    John Deere, 4200
    Very true! And it is very hard on equipment. The contact tip on my 200-amp Mig gun was soft and wanted to bend after a few beads. If I ever do much spray welding I'll have to use my 400-amp gun.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  7. #17
    Join Date
    Mar 2007
    Posts
    1,005
    Midwest
    Iseki TA 247. Husqvarna, Cub.Polaris ATV's
    Pulse Trumps Spray any day. You do need about 90% argon to get to spray but remember the old 75/22/3 Argon Co2 with 2-3% O2..You could get close to true spray with a smaller machine ( ESAB 250 ) but you suffer from adding Oxides to your welds. Some still believe in it. Praxair called it Stargon. Old School gas.
  8. #18
    Join Date
    Mar 2007
    Posts
    1,005
    Midwest
    C10 is a great gas for Stainless too. 2nd only to 85Ar/13HE/2Co2. <-- gives a sweet straw color to your beads as opposed to blackend/gray beads. The newer equipment out there runs CO2 very well and you can tell the difference but the spatter is nearly gone. Gun possition is a major factor with spatter too.
  9. #19
    Join Date
    Jan 2009
    Posts
    2,709
    John Deere, 4200
    Years ago I ran a lot of stainless steel Mig, we used a tri-gas. I think it was called Blue Shield, seems like it had argon, CO2, and helium, but I don't remember the ratios.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  10. #20
    Join Date
    Apr 2011
    Posts
    1,588
    canada
    Blueshield is air liquides house brand, almost everything they sell is called that. I know they do have a blue Shield tri mix, so that is likely it.
Similar Threads
  1. Liquefaction temperatures of gases.
    By J_J in forum Power Trac
    Last Post: 09-17-2010, 10:30 AM
  2. How do I get apart PTO shaft plastic shielding?
    By sixdogs in forum Build-It Yourself
    Last Post: 06-30-2008, 02:39 PM
  3. Welding Gases At TSC
    By SnowRidge in forum Welding
    Last Post: 06-24-2004, 04:54 PM
  4. Self Shielding Flux Core Wire Welders
    By MikePA in forum Related Topics
    Last Post: 08-16-2003, 07:38 AM
  5. PTO shaft Shielding
    By Rowski in forum Attachments
    Last Post: 05-28-2001, 09:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
