Results 21 to 30 of 47
02-05-2013, 04:54 AM #21Elite Member
- Join Date
- Jan 2009
- Posts
- 2,713
- Location
- Figuring the picking points of jelly donuts.
- Tractor
- John Deere, 4200
Re: Shielding gases
This was in the 1970s, the shop dealt with a little independent called Oxygen Sales. Fast forward 20+ years then here comes Air Gas who bought up just about all the little independents.
I remember around that time Air Liquid had some stores in the bigger cities. Maybe Oxygen Sales got their gases from them?
02-05-2013, 07:51 AM #22
02-05-2013, 09:07 AM #23Elite Member
- Join Date
- Jan 2009
- Posts
- 2,713
- Location
- Tractor
- John Deere, 4200
Re: Shielding gases
With everything included, and even if it is the construction model that sounds like a really good deal.
02-06-2013, 12:14 PM #24
Re: Shielding gases
What do you mean "close"?lol. I have one (ESAB MM250), and it sprays easily with plenty to spare. It's a true spray without a single bobble on .035. (first picture on left.) It's actually 270 amps. I use C-18. I also use it for short circuit transfer with the Everlast i mig 160. It has plenty of character, but none of the spatter or costly cleanup time. (last two pictures)
Mark Lugo
Everlast Welders
http://www.everlastgenerators.com/
Need a welder? Give me a call at (877) 755-9353 ext 204!
02-06-2013, 06:43 PM #25
02-06-2013, 06:46 PM #26
02-06-2013, 07:48 PM #27
Re: Shielding gases
In some areas of the country it's hard to find. It's a proprietary blend from Airgas. It's 82% Ar, 18% CO2. It gives you the ability to spray, but doesn't make the puddle so wet from too high of an argon content that the puddle is completely uncontrollable. I love it. I fabricate sawmills and some farm equipment on the side, and it reduces my cleanup time enough that the mild extra cost pays for its self quite easily. It yields beautiful, "shiny" welds...without the ugly scaly look of the oxidized CO2 welds.
Mark Lugo
Everlast Welders
02-06-2013, 09:25 PM #28Veteran Member
- Join Date
- Mar 2007
- Posts
- 1,005
- Location
- Midwest
- Tractor
- Iseki TA 247. Husqvarna, Cub.Polaris ATV's
Re: Shielding gases
I meant Close to Spray with Stargon Gas. Never said your 250 amp units didn't have enough " power ". I've owned several old L-Tec Airco and Esab 250 Mig Masters back in the day. I had the 1st factory prototype Esab 251 power supply with a 4HD feeder. Also a 300I Integrated soft key inverter as well as a stand alone 300i power supply with 4HD. I know the capabilities.
02-06-2013, 10:53 PM #29New Member
- Join Date
- Dec 2007
- Posts
- 18
- Location
- Pacific Northwest (Washington)
- Tractor
- l3400
Re: Shielding gases
When I was running a welding business I had a free source for argon so I bought 2 flow meters and hooked them up together with one bottle of argon and one bottle of co2. I found I can mix what I wanted and found I could weld thin metal welds. I still have this setup and don't think I want to go back to the standard 75/25 mix.
02-06-2013, 11:08 PM #30Veteran Member
- Join Date
- Mar 2007
- Posts
- 1,005
- Location
- Midwest
- Tractor
Re: Shielding gases
I have a mixer and I agree. Nice to dial a mix.
Similar Threads
Liquefaction temperatures of gases.
By J_J in forum Power TracReplies: 24Last Post: 09-17-2010, 10:30 AM -
How do I get apart PTO shaft plastic shielding?
By sixdogs in forum Build-It YourselfReplies: 9Last Post: 06-30-2008, 02:39 PM -
Welding Gases At TSC
By SnowRidge in forum WeldingReplies: 11Last Post: 06-24-2004, 04:54 PM -
Self Shielding Flux Core Wire Welders
By MikePA in forum Related TopicsReplies: 6Last Post: 08-16-2003, 07:38 AM -
PTO shaft Shielding
By Rowski in forum AttachmentsReplies: 19Last Post: 05-28-2001, 09:36 PM
