Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 47
  1. #1
    Silver Member Bday's Avatar
    Join Date
    Dec 2012
    Posts
    166
    Lucerne, IN
    53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
    Default Shielding gases
    What gas do you guy's like for steel. I like the bead appearance you get with co2 , but they mention spatter as an issue. We used co2 in school, and I can't recall spatter as an issue. Since I have been in the industry, I have always used 75/25. I use this at my shop also. Thinking about getting a bottle of co2. I have read about different mixes out there. Anyone use something different. Thanks!
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member
    Join Date
    Oct 2010
    Posts
    322
    08 Cub Ex3200
    Default Re: Shielding gases
    We use CO2, cheap and readily available. Usually if I have spatter issues its because the metal isnt clean or my settings are off, dont have too much issue when all is right it seems. If anything a quick cleanup with a grinder takes it off easily and I usually pass the grinder around the workpiece anyway to deburr edges and such.
  4. #3
    Join Date
    Jun 2012
    Posts
    740
    Mt Crawford Va
    massey GC 2400 JD LA 145
    I used co2 on the things that looks did not matter as much, but used mix on things that had to look good. This is for mig only, I am told co2 wont work on tig as it will ruin the tungston.
  5. #4
    Join Date
    Aug 2004
    Posts
    1,463
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    I use CO2 because it's a lot less expensive and at my skill level I don't really notice much difference in appearance.
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  6. #5
    Join Date
    Jul 2012
    Posts
    94
    St.Albans,Maine
    TYM T451,bolens G214.John Deere 440CID,Shaver sc25 stunpbuster,woods750 backhoe,wallenstien splitter,woods bb60 mower,woods 60"tiller,countryline tiller,99 international 4700 car carrier
    Stargon gets better penetration than argonco2
  7. #6
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,125
    Westminster, MD
    John Deere 4110
    I always use 75/25 gas with my MM210.
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  8. #7
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,782
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    If you really want to turbo charge your welds, go with some C10. Or 98% argon, and 2% oxygen.
    This weld was made with C10.
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  9. #8
    Platinum Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    920
    Ontario Canada
    Default
    Quote Originally Posted by Bday View Post
    What size wire and input power are you using? (110 or 220?)
    I personally use CO2 but only do occasional repairs/fabrication.
    A med size bottle lasts me years.
    SA- that weld was done on spray transfer?
    ericher69
    IAFF Local 849
  10. #9
    Join Date
    Jan 2009
    Posts
    2,782
    John Deere, 4200
    Quote Originally Posted by ericher69 View Post
    Yes it was!
    Hey did you get my PM about the V350-Pro?
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  11. #10
    Join Date
    Dec 2012
    Posts
    166
    Lucerne, IN
    Quote Originally Posted by Shield Arc View Post
    Hey shield arc I like the spray transfer. I also like to see some character to the bead. When I was in school they taught us less heat and more technique. I personally like the mig welds that take on a Tig welded appearance. Man we could lay some pretty welds with the 3 phase units at work.
Similar Threads
  1. Liquefaction temperatures of gases.
    By J_J in forum Power Trac
    Last Post: 09-17-2010, 10:30 AM
  2. How do I get apart PTO shaft plastic shielding?
    By sixdogs in forum Build-It Yourself
    Last Post: 06-30-2008, 02:39 PM
  3. Welding Gases At TSC
    By SnowRidge in forum Welding
    Last Post: 06-24-2004, 04:54 PM
  4. Self Shielding Flux Core Wire Welders
    By MikePA in forum Related Topics
    Last Post: 08-16-2003, 07:38 AM
  5. PTO shaft Shielding
    By Rowski in forum Attachments
    Last Post: 05-28-2001, 09:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
