Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 64
  1. #11
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    Default Re: Wet 7018.
    I am not necessarily looking to do code work, nor do I care if I am doing things to code. I just want to make sure that I am not sacrificing in my weld quality for not having "perfect" rod. I have not noticed anything yet, but I obviously don't x-ray my welds or even do a bend test.
  2. #12
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    I built these two gooseneck adapters, first one for a buddy, the second one for my self. My buddy wanted his welded up with 7018, I had him buy a new can never been opened, when he got here I through the rod in the oven. My gooseneck adapter I mostly Mig welded everything.
    Now it may make some of you members nervous that these go down the hiway, but I'm not worried!
    My point is, if you are going to build a trailer, or something that someone could get killed if a weld failed, by all means buy new 7018.
    But can you imagine the loads that are placed on that bridge falsework? I don't think I've ever been on a job that didn't have at least one engineer on it, they never seemed to have a problem with us welding in the rain, as long as the office roof didn't leak they could care less what we did out in the field!
    Attached Thumbnails Attached Thumbnails Wet 7018.-powder-coat-jpg   Wet 7018.-complete-1-jpg   Wet 7018.-winch-mile-marker-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  3. #13
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Quote Originally Posted by Shield Arc View Post
    There is a little more to it than that, but close enough for now, but this is for code work! How many of us here are doing code work now?
    Oh yeah, more to it for sure, just wanted to give the Readers Digest version (not that I remember the finer points anyways) But it's a bit moot for me, anything "critical" being fabbed (production) that Ive been involved in was run MIG. SMAW was maintenance only except for a couple welds that couldn't be done any other way.
  4. #14
    Gold Member Piperflyer's Avatar
    Join Date
    Dec 2006
    Posts
    268
    USA
    Kubota3030HST
    Not so much on these tractor forums, but on the welding forums you can get into serious trouble mentioning you use 7018 that did not come right out of an oven. Well that's fine, if you're doing code work. But not all of us are doing code work 100% of the time! I can't tell how many times on the job site I had to pour water out of a can of 7018 because some carpenter type left the lid to gang box open. Even though I was building bridge falsework, never did any testing with wet 7018 until this morning.
    I worked on jobs where they would fire you if the rod was not in a rod can and plugged in.
    'Life's Journey is not to arrive at the grave safely in a
    well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
  5. #15
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by Piperflyer View Post
    For about 3-years I worked in a shop building nuclear tanks, we had a NRC inspector with us every minute we worked. I bet you can imagine how picky an NRC inspector can be!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  6. #16
    Silver Member firemanmike69's Avatar
    Join Date
    Dec 2012
    Posts
    243
    albany ny
    none yet
    Default
    That's it! Your banned from welding forever, now just drop off your sa-200's at my house and we can put this whole mess behind us
    Nice job :thumbsup
  7. #17
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    Quote Originally Posted by firemanmike69 View Post
    OK, but would you at least cover the diesel? That should be about $10,000.00!
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
  8. #18
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,955
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I just leave my 300# oven on all the time along with lights occasionally by accident. Once it and its contents are hot, it uses very little electricity and besides that, my shop is on its own meter and minimum bill is $30+ tax so unless I do a lot of work there, it just minimum charge anyway. Winter time it puts a little heat into the shop too.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #19
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    so, am I correct in assuming that 70xx is the only rod that really needs to be in an oven? I also use 6010, and on a very rare occasion 6013, and I have a little stainless laying around, but it is my understanding that at least 6010 is fine moist.
  10. #20
    Join Date
    Jan 2009
    Posts
    6,083
    Port Orchard, WA.
    John Deere, 4200
    Here is a good article by Lincoln.
    Soon as my 6010 or 6011 welding rods start finger nailing, or running erratic I dip them in water, and let them air dry for a day or two. Then they run perfect.
    Storing and Redrying Electrodes
    Miller Dynasty 300.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    JD2 model 3.
Similar Threads
  1. Lincoln 7018 AC
    By deereman75 in forum Welding
    Last Post: 01-09-2012, 11:52 AM
  2. My wet-dry vacuum didn't tolerate getting wet !
    By JDgreen227 in forum Rural Living
    Last Post: 08-03-2011, 02:11 PM
  3. 6013 vs 7018 vs ??
    By Jay4200 in forum Welding
    Last Post: 06-16-2011, 11:19 PM
  4. Rake How wet is too wet for a rockhound/landscape rake?
    By jcims in forum Attachments
    Last Post: 08-29-2008, 10:14 PM
  5. 6011 instead of 7018
    By Rusty4242 in forum Build-It Yourself
    Last Post: 06-24-2008, 05:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
