Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 64
  1. #21
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,578
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Default Re: Wet 7018.
    Quote Originally Posted by mikehaugen View Post
    so, am I correct in assuming that 70xx is the only rod that really needs to be in an oven? I also use 6010, and on a very rare occasion 6013, and I have a little stainless laying around, but it is my understanding that at least 6010 is fine moist.
    I think you can weld with 6010 underwater ...
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  2. #22
    Silver Member SHORT KID's Avatar
    Join Date
    Feb 2010
    Posts
    180
    Poconos, PA
    Mahindra 2615 hst fel, bh
    After reading about rod ovens and keeping 7018's dry, I came up with a REDNECK oven at least for the winter. I have been away from welding for a long time so maybe I just need to visit the bathroom. I got a box of 7018's at Lowes to try them, made by Lincoln or at least have Lincoln on the box. The rod right out of the box, made me look like I never held a stinger. SOOOOOOO I got a big piece of tin foil and wrapped some rods in it and placed on top of my wood burner. When I got a chance try my luck again, the beads looked better. I guess the cardboard box they are in didn't do too well. So now I keep a couple on the stove, when I use them I put a couple more on.
  3. #23
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,588
    Lee, IL
    John Deere 1070
    Quote Originally Posted by SHORT KID View Post
    the "redneck" rod ovens I have heard of involved an refrigerator with a light bulb. Sounds easy enough, but I would like to have a little smaller box for them.
  4. #24
    Super Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    5,994
    Port Orchard, WA.
    John Deere, 4200
    Before I found good deals on rod ovens, I used one of those Little Chief smokers with a heat lamp in it that was given to me. 7018 just runs smoother when it is hot.
    Attached Thumbnails Attached Thumbnails Wet 7018.-smoker-1-jpg   Wet 7018.-smoker-2-jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse.
    Lincoln LF-74 wire feeder.
    Lincoln SG Spool gun.
    2 Lincoln LN-25.
    1937 IdealArc-300.
    Everlast PowerArc 200ST.
    3 Lincoln SA-200s.
    Vantage 400
    1800 Ellis saw.
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3.
  5. #25
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,703
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    All the stainless steel rods I have ever used required hot storage. 60xx just need to be kept dry.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #26
    Join Date
    Jun 2008
    Posts
    10,703
    Bismarck Arkansas
    Quote Originally Posted by Shield Arc View Post
    Keeping 7018 in a box with a light bulb will help keep them from absorbing moisture but unless the temps stay above 212F they wont completely dry. I had the same set up as your photo but after about a year the rods were forming a white powder on them and some rust on the ends. That is when I saw the Craigslist ad for a 350# Phoenix oven for $150 IIRC. I was in Nigeria at the time and had to get my daughter to go pick it up for me, but is works as it is supposed to. I keep the thermo on 350F and its on 24-7. I am still using up the 300# that I got from my next door neighbor in Houston before I moved up to Ark 3 years ago. It takes a lot of repairs to burn that many rods, and I have about 3 more unopened 50# cans of 7018 and a couple cans of 6010 that my brother gave me.
  7. #27
    Join Date
    Jun 2012
    Posts
    1,287
    Sno WA
    JD 950
    Quote Originally Posted by Gary Fowler View Post
    Did you get the $20 million out of the country OK?
  8. #28
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,588
    Lee, IL
    John Deere 1070
    hope he wasn't trying to find the tractor he found on CL for $2k.
    psst... it doesn't exist!
  9. #29
    Gold Member Piperflyer's Avatar
    Join Date
    Dec 2006
    Posts
    268
    USA
    Kubota3030HST
    Is it posssible to heat the rod that has been stored in its container for long periods with a torch to get the moisture out before using it and how will it run?
    'Life's Journey is not to arrive at the grave safely in a
    well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
  10. #30
    Join Date
    Nov 2012
    Posts
    1,527
    mansfield,Il
    john deere
    I really hate carpenters , especially trying to dig a hole and pour walls , They are the primo layout PEOPLE and always miss everything by a foot , too short .
Similar Threads
  1. Lincoln 7018 AC
    By deereman75 in forum Welding
    Last Post: 01-09-2012, 12:52 PM
  2. My wet-dry vacuum didn't tolerate getting wet !
    By JDgreen227 in forum Rural Living
    Last Post: 08-03-2011, 03:11 PM
  3. 6013 vs 7018 vs ??
    By Jay4200 in forum Welding
    Last Post: 06-17-2011, 12:19 AM
  4. Rake How wet is too wet for a rockhound/landscape rake?
    By jcims in forum Attachments
    Last Post: 08-29-2008, 11:14 PM
  5. 6011 instead of 7018
    By Rusty4242 in forum Build-It Yourself
    Last Post: 06-24-2008, 06:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
